Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
2002 Eddie Bauer Explorer air bag code 33
Reply
Thread Tools
Old 07-09-2008, 12:41 PM   #21
hotrod tommy
Los Angeles, CA
Metallic Dirt '02 XLT
Vehicle Specs
Quoted: 0 Post(s)
I was getting code 3-3. I looked under my driver seat, and saw 2 connectors, one for the power seat and the other (I figured) for the seatbelt pretensioner. I wiggled the green wires and one easily pulled out. These were the two thin green wires going into the green connector. I brought it to my mechanic and explained the problem; for $45 he pulled out the connector, disassembled it and re-soldered the wires. Bingo. Code cleared. He didn't even disconnect the battery, just started the car 5 or 6 times afterward and the code cleared (not sure if that's recommended though). Thanks for the help, EF!
hotrod tommy is offline   Reply With Quote
Old 02-24-2009, 08:22 AM   #22
cconboy
GA
03 Explorer
Vehicle Specs
Quoted: 0 Post(s)
Hello All,
This is an old conversation, but I'm having the same problem on my '03 explorer. Code 34.
I'm just a little confused because I'm seeing a couple of different answers for that code. In some places I've read that the 34 is "Driver Air Bag Circuit Resistance Low" . So I was leaning towards my clockspring because my cruise control has been out too. (horn works). On the other hand, info on this thread says it is the passenger seat pretensioner. I think what I've learned is that the LFC code list is not universal for every ford make/model.
I have not messed around with the yellow plug underneath the passenger seat. Perhaps I'll do that first.
Does anyone have any recommendations or thoughts?
Thank you very much for your help!
cconboy is offline   Reply With Quote
Old 02-27-2009, 06:06 AM   #23
cconboy
GA
03 Explorer
Vehicle Specs
Quoted: 0 Post(s)
any thoughts on my post above?
Thanks in advance for your help!
Old 02-27-2009, 07:08 AM   #24
rumpledoll
New Jesey
2002 Eddie Bauer V6 4WD
Vehicle Specs
Quoted: 0 Post(s)
I was getting the airbag code 4-2 (or was it 2 -4? ). It was not the drivers underseat resistor so I took it to the dealer. They replaced the drivers seat resistor, but still had the code. The problem was the airbag computer, which they replaced to fix the issue and it cost me $400. This is the only major repair my 2002 Explorer has needed since I bought it new but it still stings.
Rumple
rumpledoll is offline   Reply With Quote
Old 05-25-2010, 07:01 AM   #25
dagoninfinite
Ford Explorer 2002 XLT
Vehicle Specs
Quoted: 0 Post(s)
Question 34 here
Mate,
I've been getting the same error code on my Explorer since I bought it second hand. I believe I got the same model year as you but mine is manufactured in 2001. I also found conflicting info on the net -- some people say 34 is for air bag resistance, other passenger's pretensioner.
Did you get around fixing/diagnosing it?
dagoninfinite is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-25-2010, 04:31 PM   #26
hotrod tommy
Los Angeles, CA
Vehicle Specs
Quoted: 0 Post(s)
The 3-3 code was the connector under the driver's seat. I had to pull out and re-solder the wires (or replace the whole loom). I think 3-4 is passenger, check the thin wires under the seat at a connector. Mine were kicked loose by a passenger in the back.
Old 06-10-2010, 11:40 AM   #27
jpoprock
Kokomo, IN
2002 Explorer Limited
Vehicle Specs
Quoted: 11 Post(s)
How do you know what the code is? In my 2002 Explorer Ltd my airbag light just started doing this. It flashes, but I haven't bothered counting how many times (should I?), then it just stays lit.
I can check my wiring harnesses to see if one is loose, but I'm curious to know how to tell what the flashing is trying to tell me... besides certain death on impact! LOL!
jpoprock is offline   Reply With Quote
Old 06-10-2010, 01:37 PM   #28
miker104
N KY
miker104's Avatar
'04 XLT
Vehicle Specs
Quoted: 1 Post(s)
This chart lists the airbag codes:
http://wiki.answers.com/Q/Is_there_a...ht_error_codes
You will have to count the flashes
miker104 is offline   Reply With Quote
Old 06-10-2010, 02:43 PM   #29
dagoninfinite
Vehicle Specs
Quoted: 0 Post(s)
It's not very difficult. In case you haven't figured it out yet it there's a certain flashing cycle. It flashes an X number of times then there's a longer pause. That's the first digit in the error code. After this longer pause, it starts flashing again and you get your second digit for the error code. The whole cycle repeats 5 times or so. Write down the code and look it up on the net.
Old 06-10-2010, 02:55 PM   #30
dagoninfinite
Vehicle Specs
Quoted: 0 Post(s)
Quote:
I checked the connectors under the passenger's seat visually and they seem to be fine. There are three, none are disconnected, the wires no matter how thin don't have any apparent damage. Is there a way they can be tested with a multimeter?
Old 06-10-2010, 03:16 PM   #31
hotrod tommy
Los Angeles, CA
Vehicle Specs
Quoted: 0 Post(s)
Hmm, not sure. Sorry.
Old 06-11-2010, 01:17 PM   #32
jpoprock
Kokomo, IN
Vehicle Specs
Quoted: 11 Post(s)
My code is 34.
34=Driver Side Air Bag Circuit Low Resistance or Shorted
The lights flash in sequence I gathered. Mine flash three times, then four times, and it does this 5-6 sets then stays on. I looked under my drivers seat, and it looks like the harness with the green harness is a bit dodgy. Seems like the plastic houseing may be loose or something. I'm gonna have to disconnect the battery and pull seat to have a looky-loo.
Thanks guys!
Old 07-03-2010, 11:51 AM   #33
Dario
MN
'02 XLT
Vehicle Specs
Quoted: 0 Post(s)
This thread and others on the forum give conflicting info on what the code is for which seat, often within a single thread!
Ford's TSB for the 2002-2002 Explorer (Article No. 03-11-3 - 06/09/03 -ELECTRICAL - AIRBAG WARNING LAMP -ILLUMINATED WITH DIAGNOSTIC -TROUBLE CODE -(DTC) B2292), found in AllDATA, clearly states that 33 is the drivers and 34 is the passenger.
And yet the wiki.answers link that miker104 posted says the opposite.
Do I trust the TSB?
The next question is, since I have very little money (certainly not $400+), can someone who's done this let me know what tools I'll need. The AllDATA does help but I can't follow some of the instructions as they assume things that only a dealer would have.
Thanks!
Dario is offline   Reply With Quote
Old 09-29-2010, 03:12 PM   #34
INOUNV
Brooklin,Ontario
2002 XLT
Vehicle Specs
Quoted: 0 Post(s)
Anyone know how to remove the 2 wires in the resistor under the driver seat, I got a code 33 ans the one wire is broken off flush with the connector
thanks
Jeff
INOUNV is offline   Reply With Quote
Old 10-03-2010, 12:41 AM   #35
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 426 Post(s)
Welcome to this forum! Could you pull it out of the connector with a needle nose plier?
BrooklynBay is offline   Reply With Quote
Old 09-26-2012, 02:24 PM   #36
Manny68
San Diego, CA
2002 Ford Explorer XLS
Vehicle Specs
Quoted: 0 Post(s)
I had the same 3-3 code on the airbag pop up a few days ago and was driving me nuts.
I thought it had to do with the actual airbag until I read this thread and it all made sense. I recently had an interrior detail done focusing on the dirty carpet. These connectors under the seat must have been forced during the carpet scrubbing. After reading this thread I disconnected and checked for loose wire terminals. I re-connected and light went out. My hats off for ExplorerDMB! Thanks
Manny68 is offline   Reply With Quote
Old 10-05-2012, 05:32 PM   #37
BlackOut33
2003 Ford Explorer Ltd
Vehicle Specs
Quoted: 0 Post(s)
Hey guys mine does this 4 3 3 3 3 3 3 3 3 3 then steady light ?
Any ideas ??
BlackOut33 is offline   Reply With Quote
Old 10-05-2012, 06:13 PM   #38
BlackOut33
Vehicle Specs
Quoted: 0 Post(s)
Hi guys My SUV today started blinking the AIRBAG light when i TUrned on the suv it blinks 3 times then again 3 times and continues on about 27 times after that any ideas???
Old 10-05-2012, 06:34 PM   #39
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Quote:
Light Flash Code (LFC) 33 is for the driver side seatbelt pretensioner. Check the connections under the driver seat that go to the seatbelt buckle. There is a TSB about this issue. Check out this thread it's a good read: http://www.explorerforum.com/forums/...d.php?t=299020
Good luck.
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is offline   Reply With Quote
Old 10-05-2012, 07:16 PM   #40
BlackOut33
Vehicle Specs
Quoted: 0 Post(s)
Hey Guys I went in my SUV played wit the yellow plug wire cant unplug cant figure out how to remove it...So I jiggled the wire the light went off this is on passenger side tho?
As soon as I moved the seat back the light came back on any ideas???
I played wit drivers side to no difference
But it blinks 3 then 3
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
