| Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Appleton WI.
1994 Eddie Bauer Explorer
Somebody has had to have had this problem, absolutely no electricity
I have absolutely no electricity, no dome lights nothing.. I have had battery tested, R&R ground connections, replaced starter, starter solenoid,starter cable. Have checked all fuses.
I have been told that it is a relay on or near the steering column, however no longer have contact with the person who told me this and am not sure what this relay may be called or where it is located. This person had a brother who had this happen so I know its happened to others somewhere at sometime. Any help at all will be appreciated. Thanks. ![]() Does anyone know where the PCM relay and ICM relay are located |
#2 |
Calgary Alberta
98 XLT
Those relays are in the power block, under hood fuse panel passenger side. Check fusible links.
#3 |
Lake of the Ozarks Mo.
92 xlt 4x4, 02' EB 4x4
i'm not sure if my exlorer is set up the same as my F150 but it probably is.My ignition
switch went out of it about a month ago and I had the same symptoms as you. There was a box near the steering column on the upper right side about midway down with a rod run to it from the ignition switch.Instead of the ignition wires run to the key switch itself,they are run to this box and when you turn the key it pushes the rod down into this box and makes contact.In my case the ignition box cracked and seperated not letting it make contact and I had no power to anything including the dummy lights(check engine,ABS,etc.) when I turned on the key.That is probably what they were talking about near your steering column. Hope this helps, good luck... |
#4 |
Moderator Emeritus
Vancouver B.C, Canada
1992 XL Ex-Police
Check all the big fuses inside the Power Distribution box. There is one called IGNITION in there
__________________ *Explorer Family* 1992 XL Mine 1992 XL Sisters 1992 XL Dads 1994 XL Moms Ex-Moderator: Modified Explorations Drivelines New Member Forum ***Guest star poster.... |
| Thread Tools | |
