Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
4wd dis-engaging problem
Reply
Thread Tools
Old 05-21-2000, 02:01 PM   #1
Dctrdan
Visalia, CA.
1991 Sport
Vehicle Specs
(Original Poster)
Question
I seem to be having trouble dis-engaging my 4wd(91 explorer sport) after a period of wheeling. I can engage just fine, but cannot disengage the tranfer case. it's a long way home in 4low. Also the lights on my panel no lopnger work. Any ideas would be helpful. Thanks
Dctrdan is offline   Reply With Quote
Old 05-21-2000, 11:43 PM   #2
wabbit
Western Colorado
the white one...
Vehicle Specs
Post
Make sure you are stopped and in neutral when engaging or disengaging 4 low. Also, to disengage the auto-hubs, you need to back up 10-20 ft.
If this doesn't help, check the connection plug down by the tranny or the switch control mounted behind the driver's side rear panel.
Hope this helps...
'91 Explorer XLT 4WD
wabbit is offline   Reply With Quote
Old 05-22-2000, 10:42 AM   #3
Dctrdan
Visalia, CA.
1991 Sport
Vehicle Specs
(Original Poster)
Arrow
Thanks for the input. I'm sure it isn't a neutral thing, as I do this regurly. I can also here my hubs disengage when I back up. The transfer case simply won't let go! I will check the switch. Appreciate your feedback.
Old 05-22-2000, 01:59 PM   #4
TPLYNCH
Brewster, NY
1999 XLS
Vehicle Specs
Post
You may want to try disconnecting the battery for about 10 minutes. I know you'll lose all you preset radio stations, but the transfer case may reset itself. Worth a try.
Tom Lynch
99 XLS
TPLYNCH is offline   Reply With Quote
Old 05-22-2000, 04:20 PM   #5
Dctrdan
Visalia, CA.
1991 Sport
Vehicle Specs
(Original Poster)
Lightbulb
Thanks,
I'll give that a try.
Dctrdan--
Old 05-23-2000, 11:09 PM   #6
Ray Lobato
Moderator
Ray Lobato's Avatar
Vehicle Specs
Smile
Hi Dctrdan,
Welcome to the site.
Have you checked the connections on the 4x4 computer? It is in the back panel where the jack is, just in front of it on the wheel well. I had a simular problem like that on my 95. I reseated to connections and it worked. I see your from Visalia. Do you ever go up to Sequoia to go 4wheeling?
Happy Wheelin'
Ray L.
97 XLT 4X4 4.0L SOHC
Ray's Truck
Ray Lobato is offline   Reply With Quote
Old 11-26-2000, 03:14 PM   #7
BGN
Vehicle Specs
I just had the same problem with my 91 Sport(5spd and auto hubs). We drove about 15 miles today in frozen rain so I decided to put it into 4WD. When we got to where we were going pushing the button again would not disengage 4WD AND the LO RANGE button started flashing as well. I finally managed to get it out by backing up but does anyone have any further comments about a possible cause?
Barry
BGN is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
4WD System cpagan Under the Hood 7 01-28-2004 12:27 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
