Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
Transmission Problem Solved!
Reply
Thread Tools
Old 02-06-2006, 09:06 AM   #1
greg s
Gainesville,FL
1997 4wd sohc Explorer
Vehicle Specs
(Original Poster)
I have finally solved my transmission and transfer case problems! If you remember, my original problem was a delayed reverse sometimes followed by a loud bang. It was intermittent and did not follow any noticeable pattern. It also made some knocking noises as it down shifted as I came to a stop. I originally worked on the transmission feeling it was the problem and installed the updates from Ford, a shift kit and even swapped a used complete valve body with solenoids none of which solved the problem. I had reached the point a month or so ago that I was going to take it to a trans shop and see what they had to say, but I did a little more research and found complaints and symptoms that matched mine. It seems there are a number of failures and problems associated with the BW 4405 transfer case, and it turned out to be my problem. The problem is with the high-lo gear shifting in or out do to wear in the the cases and and the shifter cam. Also when checking a few things, I tried moving the rear driveshaft and it had up and down movement with very little oil seepage. I found a company (Omega Machine & Tool) that rebushes the case halves and improves the shifter by making the shift roller longer so that it engages into the shift cam completely. They put bronze bushings in the shift rail holes and sleeve the rear output bearing bore and add a shim to tighten everything up and it looked like they added a steel pin to the oil pump area to reduce movement. For about $300.00 you can get the front and rear case halves, improved shifter fork and shift cam, and from drivetrain.com you can get the seal kit for around $20.00. The only thing extra I had to get was the seal for the shift motor shaft. After disassembling the transfer case you could see all the wear and my truck only has 120,000 miles on it with the 4wd used very little. I suspect the magnesium cases must be a soft material that allows for the rapid wear along with a design issue on how it shifts. After replacing all the parts and reinstalling it, the truck drives like new. It is noise free and very smooth. It eliminated a vibration it had at 65 mph from the driveshaft, no more clunking noises when it shifts, no more delayed reverse just nice smooth shifts up and down! Finally the problem is solved and shouldn't be a problem again. I would definitely recommend repair your existing transfer case with these parts instead of putting in a used one, because it will only be a matter of time before the used one will have the same problems. Thanks for everyone's help and suggestions. Greg
greg s is offline   Reply With Quote
Old 02-06-2006, 11:05 AM   #2
Glacier991
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Vehicle Specs
Thanks for the update! I will be rebuilding a 4405 in the coming months, and will definitely follow your suggestion - especially since Dennis's company (Omega) is located here in Sacramento!
Glacier991 is offline   Reply With Quote
Old 02-06-2006, 11:31 AM   #3
greg s
Gainesville,FL
Vehicle Specs
(Original Poster)
I emailed them with the forum and suggested they advertise on it. Maybe they could put together a kit with the seals for one stop shopping. It looks like there are a number of 4405's that need repaired and this looks like a permanent solution. Greg
Old 02-06-2006, 12:42 PM   #4
Glacier991
EF Tranny Guru
1992 XLT
Vehicle Specs
I'll talk to Dennis about something along those lines.
Old 02-07-2006, 11:04 AM   #5
Opera House
Cincinnati, OH
97 Explorer XLT
Vehicle Specs
GREAT........Remarkably, my beer can shim I pounded in on that rear transfer case bearing is still working.
__________________
Rule #7: Believing and seeing are often both wrong. (FOW)
02, 97, 92 Explorer XLT 4X4 4.0L
Opera House is offline   Reply With Quote
Old 02-07-2006, 01:49 PM   #6
Glacier991
EF Tranny Guru
1992 XLT
Vehicle Specs
OperaHouse you get my vote for "the guy you'd most want to be stranded with car troubles with" and "most resourceful" as well ! <grin>
Old 02-24-2006, 12:51 PM   #7
Bigg_billy
Westford Mass
2000 Explorer XLS 4L AT
Vehicle Specs
As long as he has beer with him that is............
Bigg_billy is offline   Reply With Quote
Old 02-25-2006, 06:58 PM   #8
Glacier991
EF Tranny Guru
1992 XLT
Vehicle Specs
Or I have beer with ME!
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
