| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Modified 2006 - 2010 Explorers Modified 2006 - 2010 Ford Explorer Forum. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Rochester, NY
2006 Limited V8
Replacing stock halogens with HID's?
My '06 Limited has everything except my favorite option... HID XENON HEADLAMPS! I have seen replacement kits for cars hat come with halogens and I am curious as o the problems that might crop up if I replaced the halogen bulbs with a xenon kit. Does anyone know or have done this??
#2 |
Avondale, AZ
06 Explorer EB V8 4x4
I could be interested in this as well ...
__________________ ~~~~~~~~~~~~~~~~~~~~~~ 2011 Kia Optima SX (Turbo) 2011 VW Jetta Sportwagen TDI (Diesel) Gone -2006 Explorer Eddie Bauer 4x4 V8 / - 2001 Escape XLT 4x4 V6 / 2001 Focus SE Wagon |
#3 | |
disturber of the peace
calgary
99 eb 5.0 awd
There are many options available. Hit the search function and you'll see. Keep in mind that aftermarket HID kits are illegal in many locales ("for off road use only") and you won't pass inspections in many areas. Nonetheless, a LOT of people have done it before and they talk about it in past discussions. Pretty easy mod for the most part and lots of different options at your disposal.
__________________ '99 EB 5.0 AWD, Torque Monster Headers, 1" Trick Flow UI spacer, Custom Volant based CAI (incl C&L MAF body), SCT XC2 w/Henson tunes, Flo Pro catback, EE swaybar & airdam, Morimoto HID projector retrofit (4300K), Bilstein shocks, Powdercoating by Turdle, Amsoil everywhere, other stuff. Quote:
#4 |
Avondale, AZ
no inspections in Washington and these new bulbs (h11 i think, or is it the h12?? i dunno..) has hardly ANY aftermarket options...
#5 |
new jersey
06 Eddie Bauer V8 Navi
Ford of Japan sells the HID kit for the 2006 Explorer. They also have many other accessories they dont sell in the states. I found the link somewhere on this forum.
#6 |
Avondale, AZ
I could not find on the japanese site the HID's and the bulbs are H13's on the 2006's
#7 |
Rochester, NY
2006 Limited V8
I found the Japanese lights on the ford website but cannot read japanese or find an importer to get one for me. Does anyone know of a japanese parts importer?
#8 |
Rochester, NY
2006 Limited V8
btw the Janpanese lights are for the 2002-2005 Explorers and cost $1,100
#9 | |
Avondale, AZ
#10 |
Germany / Hessen
actually none
Orderer a HID conversion kit for my 2006 Eddie at the shop where I bought the kit for my 99´s H4. Will arrive Monday, will post some pics when work´s done.
btw : as far as i remember it´s H13. I pay r.a. 230 bucks for it. __________________ |
#11 | |
Dallas
'93 XLT
Quote:
That's assuming you don't do a lot of night driving on rural highways, where such things as grill-mounted searchlights would serve a purpose. __________________ Fixes since Aug. 2004: radius-arm bushings; driver's power-window motor; cleaned MAF sensor; replaced trans low-reverse servo "D" rings; new fan and fan clutch; ignition-switch lock & tumbler; new radiator; new Kumho tires; added heater-control valve; replaced trans modulator |
#12 |
Rochester, NY
2006 Limited V8
Crizz, the h13 kits I have seen are only low beams. I havent seen a bi-xenon kits for h13's at all, let me know if you have seen one.
__________________ 2006 Ford Explorer Limited Dark Cherry Metallic 4.6L V8 Navigation |
#13 |
Germany / Hessen
actually none
I´ve ordered the single-xenon-kit ( only lo-beam ) because I like it more than Bi-Xenon. The reason : on these conversion kits, the highbeam is only made by a moveable fader / shutter. There is no different current on the lamp, and what I have seen on H4-conversion kits with this systems, the Highbeam of the normal halogen bulbs isn´t a real big difference from the xenon-highbeams. But takes over 100 bucks more, in my opinion too much for too less ( and sparebulbs are even double the price than single-xenons : r.a. 90 bucks / each against 50 / each ).
But, i´ll try to figure out if H13 is available in bi-xenon too. __________________ |
#14 |
Rochester, NY
2006 Limited V8
Bi-Xenon kits on BMW, Audi, and Mercedes also use the "shutter" system. So how would replacement kits that use the same system be of less quality?
#15 |
Germany / Hessen
actually none
I wasn´t talking about quality - you need to remember that a factory xenon.-system has esp. designed headlights and are not only converted by using other "bulbs". A headlight constructed for halogen bulbs will be different with xenon-burners, but not the same like a sepcial designed unit. Thats the little difference, and I only told about my experiences with converted halogen-headlights.
( I don´t compare apples with pears ) __________________ |
#16 |
Rochester, NY
2006 Limited V8
I fully know that halogen units and xenon units are designed diffrently. I used to have an Audi with factory xenons and would post on audiworld.com. There were also discussions on converting and the diffrence between factory xenon and conversion xenon.
Your comment about the hi-lo not having much diffrence just struck me as odd simply because high class cars like the Acura TL and such use a shuttered bi-xenon system. I'd like to preserve the hi-lo on my Limited thats why I have held out and am waiting for a bi-xenon h13. __________________ 2006 Ford Explorer Limited Dark Cherry Metallic 4.6L V8 Navigation |
#17 |
Avondale, AZ
I had a 2006 Cadillac DTS rental this week and it also had the shuttered use of the xenon. Interesting and first time i had use of that system and seemed to work well.
only bad thing is that no flash to pass feature anymore since the lamp has to be on to engage the highs... __________________ ~~~~~~~~~~~~~~~~~~~~~~ 2011 Kia Optima SX (Turbo) 2011 VW Jetta Sportwagen TDI (Diesel) Gone -2006 Explorer Eddie Bauer 4x4 V8 / - 2001 Escape XLT 4x4 V6 / 2001 Focus SE Wagon |
#18 |
Rochester, NY
2006 Limited V8
There are drawbacks to the system but Xenons beat Halogens any day of the week. Plus it looks hot and would fit in well with all the chrome on my Limited
#19 |
Rochester, NY
2006 Limited V8
Crizz, since you live in Germany could you look around and see if Hella or Bosch or any of the other big name lighting companies produce a h13 bi-xenon kit? Thanks!
#20 |
Germany / Hessen
actually none
CEO, I checked Bosch and Hella for Xenons. Result : Bosch only manufatures normal Halogenlights, Hella uses D2S-System for projecting lights and D2R for reflecting ( like the Explorer has ). No H13 used over her : ((
But asked my dealer for H13 Bi-Xenon conversions, just waiting for reply. Will let you know asap. __________________ |
| Thread Tools | |
