Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer - Ranger Tires & Wheels
Notices
Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here.
Wheels: Offset, Backspacing, & Wheel Spacers
Reply
Thread Tools
Old 05-07-2007, 09:38 PM   #21
05kfx
WV
03 Sport Trac
Vehicle Specs
HI guys NEW Here. I have a ? 4 ya. I have a 2003 Ford Sport Trac and would like to install some new wheels and tires. The current wheels are 16x7 and if you measure like above from the back of the wheel to the back rim lip, I come up with 4.5inches. Now I would like to install 22x9.5 wheels and a 2" lowering kit in the front and a 3" in the rear. Just wondering what you guys suggest i get for a offset of wheel. I AM LOST.. Also I DO NOT want the wheel to stick out of the wheel well. Thanks guys.. Casey
05kfx is offline   Reply With Quote
Old 06-18-2007, 04:16 PM   #22
pcunningham42
NY
2003 XLT
Vehicle Specs
US Thank You!
Even I should be able to do this ..Thanks
pcunningham42 is offline   Reply With Quote
Old 08-01-2007, 01:27 PM   #23
85gt
NY
06 Limited
Vehicle Specs
I'd like to replace the wheels on my 06 Limited , can anyone tell me the factory 18" wheel offset ?
Thanks ,
Ronny
85gt is offline   Reply With Quote
Old 08-26-2007, 08:50 AM   #24
rck2drums
Illinois
1998 Mountaineer
Vehicle Specs
Sorry to bump this but are you saying that wheel spacers are bad or ok? I really want some but ifd they are dangerous then I don't. I can't be hauling around my family thinking my wheel might fly off.
rck2drums is offline   Reply With Quote
Old 08-26-2007, 02:20 PM   #25
BonesDT
Westchester, NY
BonesDT's Avatar
Red '99 Sport SOHC 4x4
Vehicle Specs
I think you'll get mixed answers to that question.
If you want to go the safest route, get the spacers with their own lug bolts. This kind of spacer bolts onto your hub using your existing lug bolts, but then you need to chop off the excess length of the existing lug bolts and you install the tire with the new lug bolts welded to the spacers. The downside is that this is more permanent.
The cheaper spacers will just use your same lug bolts, putting stress too far out on the end of the lug bolts.
__________________
Mazda M5OD-R1HD, Ranger FX4 shifter, BorgWarner 13-54 M, Aussie Locker rear, PA 3" body lift, 2" TT, Warrior shackles, hybrid leafs, Monroe Reflex, Goodyear DuraTrac 33x12.5x15, AR Mojave Teflon 15x8, Flowmaster Dual 40 Originals -> 50 SUV, Power Slot Cryo, Hawk LTS, Smittybilt Outland grille guard, APC clear lenses, Mustang FR500 steering wheel with Cobra airbag, Kenwood DNX9140, Valentine One, Dynamat Xtreme, Autel MaxiDiag US703
1989 Shelby Dakota Convertible 5-Speed under restoration
BonesDT is offline   Reply With Quote
Old 09-04-2007, 10:07 PM   #26
JCUZ
Canberra, Australia
JCUZ's Avatar
2004 XLT 4x4
Vehicle Specs
Lug bolts (or wheel studs) do not take the weight of the wheel, the centre hub adapter does that (or should). Wheel spacers that do not have a machined lip to support the centre of the wheel will mean that you break wheel studs.
__________________
2004 Explorer Limited 7 seater, LPG SVI powered 4.6L V8, 4WD (with BWM 2WD coming), Auto, Lukey mufflers, Roof mount DVD system, HID driving lights (high beam)22s with 265/35/22 Atturo AZ800s
JCUZ is offline   Reply With Quote
Old 09-05-2007, 12:18 PM   #27
BonesDT
Westchester, NY
BonesDT's Avatar
Vehicle Specs
Quote:
Good point. I forgot about that. Definately a must when buying a spacer.
Come to think about it, I don't think my new American Racing wheels rest on the center hub! I should look into that.
__________________
Old 03-19-2008, 05:50 PM   #28
Richie18
2009 STA White Suede
Vehicle Specs
The relationship between wheel back spacing and offset on here does not work for me when using numbers given by a website for any of their wheels.
Richie18 is offline   Reply With Quote
Old 03-19-2008, 10:42 PM   #29
storlied
Anchorage, Alaska
98 5.0L V8 AWD XLT
Vehicle Specs
bump
__________________
Lifted 98 302
Quote:
Originally Posted by joel903 View Post
These freaken explorers! Everything breaks
Ford: Fixed Or Repaired Daily. But still going, kicking and screaming all the way. =D Yeaaah.
storlied is offline   Reply With Quote
Old 03-20-2008, 03:36 PM   #30
Richie18
Vehicle Specs
Anybdoy have any info on this?
Old 03-20-2008, 03:53 PM   #31
storlied
Anchorage, Alaska
98 5.0L V8 AWD XLT
Vehicle Specs
Guess not, or we missed something... I think the Offset is half of the BS.. with some conversion?.. I don't know...
__________________
Lifted 98 302
Old 03-20-2008, 04:11 PM   #32
FROADER
Moderator
Huntington Beach, CA
FROADER's Avatar
Vehicle Specs
Quote:
Quote:
Originally Posted by First post...
To calculate offset is even easier, measure the wheel's overall width, subtract its backspace measurement, and divide that by two. You're done.
FROADER is offline   Reply With Quote
Old 03-20-2008, 05:52 PM   #33
rwenzing
Michigan
03 Ranger FX4 LII 5.0 S/C
Vehicle Specs
Quote:
The important thing to keep in mind is that a wheel's backspacing and its nominal width are not measured to the same place. This is what usually causes the confusion.
Width is measured to the inside of the flanges where the beads seat.
Backspacing is measured from the outside of the inboard flange to where the wheel mounts.
As a rule of thumb, most wheel flanges are very close to 1/2" thick each. So the overall width of a nominal 7" wheel is about 8".
Example: The offset of a factory Gen 1 or 2 Explorer wheel is +12mm, close to 1/2".
To find the backspace dimension of a wheel with a 7" nominal width and +12mm offset, start with the overall width (7" + 1" = 8"), divide by two and then add the offset (8"/2) + 1/2" = 4 1/2"
Pictures of a wheel with same dimensions as in the above example. notice that the measurement is being taken from innermost part of the inboard flange to the wheel's mounting surface. This is where the overall width is about 8" as opposed to 7" where the beads seat.
This is a good cross reference for offset, width and BS:
__________________
Bob
2003 Ranger FX4 Level II, 5.0L V8, 4R70W, BW4406 T/C, Aussie Locker front, Torsen rear
Torque Monsters, Magnaflow, duals; Explorer EATC, steering wheel controls, consoles
Bilstein 7100 reservoir shocks, Cadillac/Mustang SVO rear discs, Duff traction bars
CarDomain
Ford owners' manuals ONLINE, then click on "Glovebox"
rwenzing is offline   Reply With Quote
Old 03-20-2008, 06:36 PM   #34
Richie18
Vehicle Specs
Thanks for the clearing things up.
Old 03-29-2008, 09:14 PM   #35
Explorer_Phil
Clarksville, TN
'01 Sport
Vehicle Specs
US Rims Question
Ok, so, after reading all this great information, I feel as though I get the concept, but can't apply it.
I am looking at getting new rims for my '01 Sport and can't figure out if I need the 4.5" or the 3.75" backspacing. I am going to get 15x8 rims and put 31x10.5x15 tires on them. I would rather not accidently destroy my bearings or something, so any help on this would be appreciated. Thanks!
__________________
2001 Ford Explorer Sport; Help Me Upgrade It!
Done: TT, Shackles, 4-Door Leaf Springs, 31x10.5 BFG AT K/O
Short Range: FIX RUST(Done), Electric to Manual T-Case Mod (Fixed E-Motor), Body Lift
Long Range: 4.56, Rear Locker, 33's
Explorer_Phil is offline   Reply With Quote
Old 03-30-2008, 07:21 AM   #36
storlied
Anchorage, Alaska
98 5.0L V8 AWD XLT
Vehicle Specs
3.75 for 15x8
__________________
Lifted 98 302
Old 03-30-2008, 07:26 AM   #37
corkey
Elite Canuck, Eh ??
In the Great White North where winter never seems to end ,Ontario,, still ice fishing,,
corkey's Avatar
96xl,99xls,old Rangers
Vehicle Specs
and for 15x10 ??
is it 4 inches ?
__________________
Log Roller,, Fox Coilovers 35's and others, ,
Truck of the month
Ranger Of Danger,,,project truck,
also look for Blues Traveller Elite registry, ,
corkey is online now   Reply With Quote
Old 04-03-2008, 10:53 PM   #38
bill55az
Phoenix, AZ
Vehicle Specs
Alloy wheels usually have the offset cast into the inside of the rim, example is 16x7x12, where 12 is the offset and using the chart shown in a previous post, that means 4.5" backspacing on a 7" rim. If you have deep backspace and want to move the tires AWAY from the truck, go for less backspace. Again use the chart, there is negative and positive offset listed.
bill55az is offline   Reply With Quote
Old 08-21-2008, 11:13 AM   #39
Jd0gg919
Willow Spring, NC
'96 XLT
Vehicle Specs
I'm looking at a set of 17x9 wheels with 4.75 BS and -6mm offset. Could i run 33's with minor trimming? I've already got a 3in B/L, TT and shackles with 32x11.50x15 on the stock rims. I've read through this thread but it didn't really show different applications it only showed me how to calculate it. Preciate any answers.
-Justin
Jd0gg919 is offline   Reply With Quote
Old 03-02-2009, 01:32 PM   #40
SubLo
New York, NY
2003 Explorer EB v8
Vehicle Specs
Hi guys. Kind of new'ish here but a long time Interweb and forum veteran elsewhere. One of those places is LegacyGT.com as I also have an '06 LGT Spec.B. I bring this up in the wheel/tire area here because I'm shopping new 18's and Nitto Terra Grappler 255/55/18s.
Lots of great info here particurlarly in this thread but it's not specific to our trucks. If any of you have the kind of experience, perhaps you work at a tire shop , that is detailed for my other car here: http://legacygt.com/forums/showthread.php?t=4426, it would be fantastic if you could graciously share with me and everyone else on here.
Another one of my favorites there, which I think could be really useful to Exp wheel/tire shoppers is this one http://legacygt.com/forums/showthread.php?t=19741, a compilation of pictures of installed shoes.
Yep. I've searched exhaustively and there is some information quite scattered about here and I'm still having trouble finding exactly what I'm looking for.
<flame on>
SubLo is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
