| Offroad Drivelines Ford Explorer and Ranger Transmissions, Transfer Cases, Driveshafts and Axles. |
Thread Tools |
#1 |
Chicago
94 Limited
The time has come. By building my new project I'd like to do it right from the beginning. Before installing any additional lifts or lockers I'd like to explore the possibility of swapping the front axle. In the back I'd like to go with a newer 8.8 (disks) and flip the springs over. In the front I'd like to keep coil springs and not go any higher than 6" on the lift... will be running on 33's. I would also not want to go through the motions of narrowing the new axle, running a full width EB D44 is not really an option. Considering my choices I think that a D30 from a Wrangler would work best... or perhaps a D44 from a Waggy be better? See? I'm picky. Might start shopping for axle... your input would be greatly appreciated.
#2 |
Master Apprentice
Souderton, PA
1992 XLT
the question isnt if you should or not, at this point its a question of when. :p I dunno what your thinkin about a full-width Eb axle
... they match withwise
__________________ My Photos---Emily Rose---SAS Thread---My Mug 1992 4dr XLT. SAS'ed HPD44/9" 5.13's Locked F/R 36" SX 1999 4.0 5spd sport on 31" BFG Muds |
#3 |
Wannabe Elite Explorer
Syracuse, New York
96 XLT
SAS it...... since you would be running 33's you can really look into the D30 option.
__________________ 2005 F-150 |
#4 |
Moderator
Huntington Beach, CA
Dre, Dre, Dre, I think you know the answer to that question already...enjoy
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Just a few to wet your appetite.
__________________ COLIN IGNACIO FORUM RULES My 2010 Explorer - Explorer #1 (sold) - Explorer #2 (sold) - My F-150 (sold) - My Ranger (sold) - My Videos |
#5 |
San Diego,CA
97 XLT 2WD
^^^hahahaha, at least we know what Colin wants you to do
my vote is for a solid axle too |
#6 |
Syracuse, New York
96 XLT
i dont think it's a debate anymore...so go get an axle and start building already....
#7 |
Chicago
94 Limited
Now that was an easy question... what about the axle itself... which one? like I said I don't like anything over 6" with 33's for some reason. I want it to be a fairly decent DD if need be. What was that about an EB front axle? no cutting involved? how's that? I though that it has to be cut since it's a bit wider than explorer's axle but then again, who am I to know all that info? I would go with a Wrangler's axle but then again... I saw what they are asking for them and it almost caused a heart atack. I know people got some F150 axles, which for sure have to be cut unless I go full width front and get a Ford 9" for the rear... I want it to be fairly easy... no way I'll be able to make it by the anniversary run in Attica. I would still like the idea of coils... but would look into installing leaf springs as well... see how I am???
I need to do some homework. Reading all these posts about SAS confuses me... can't choose anymore... this one's good, that one's better... WTHeck? I've got a 93 XJ sitting in my yard... front axle's still there... I might use that but then again, question is will this thing be strong enough to support the weight of the "X" and occasional beating on the trail??? well? |
#8 |
Moderator
Say you use the 30 and then after your 33s wear down you realize you want a tire 35" or bigger. Then you'll want to get a 44 so you don't start breaking stuff, and so you should have used the 44 in the first place.
Mine is right around 6.5" of lift and I have 35s and want 37s. It's fine for a daily driver to me, but that also might just be me. The EB axle is a low pinion d44 that is already really close to the width of the explorer. DB_1 has one on his ranger and it performs really well. The high pinion d44 from the 78 and 79 bronco and 74?- 79ish F-150 are about 6" wider and need to be narrowed if you don't want full width. If you do narrow them you can then use the axle shafts from the eb on the narrowed side. The 8.8 is a strong rear end. I have never seen anything go wrong with it with even 37s on it and beating the crap out of it. I hope this all made sense... now I feel like you. :p __________________ COLIN IGNACIO FORUM RULES My 2010 Explorer - Explorer #1 (sold) - Explorer #2 (sold) - My F-150 (sold) - My Ranger (sold) - My Videos |
#9 |
sextion525
Red Bluff, Ca
1975 Ford Bronco 4x4
Is that DB_1's Ranger?
__________________ Support the Forum '13 3.5 Explorer '08 2.0 Focus '75 5.0 Bronco '04 6.0 Super Duty |
#10 | ||
Roll Over Posse Recruiter
Clarksville, TN
'00 XLT 4x4
Quote:
![]() Quote:
#11 | |
Moderator
#12 |
Lakeland, FL
'96 Ranger 4x4 XLT
If he only wants 33's I'd say stick with the TTB. That being said he'll almost definitely want to go with a bigger tire later on. I'd say try to find a EB D44 or if he can't find a Wagoneer D44 and set it up for coils instead of leafs. Good luck.
FROADER, can you e-mail me a copy of those awesome pics, thanks! __________________ '96 Ranger 4x4 XLT with some stuff....and more to come when I actually have some money |
#13 |
Chicago
94 Limited
I have never gone any higher than 6" on the lift... and never put tires that were bigger than 33"... but that's just me. Last time I went with a 6" Skyjacker and kept the TTB... It worked OK but had quite a bit of a body roll on an uneven surface at higher speeds - IMO due to the TTB's steering design.
Anyway, I have a few options I'm considering at this time: 2" budget Skyjacker on top of the 2" BL that I've got now plus longer shackles and 2" coil spacers - 33's with a bit of trimming - done that before; 4" Skyjacker - (would be fine with existing 2" BL) with new spring packs and new shackles in the back, extended radius arms up front and stiff shocks - 33's still - always wanted to do it for some reason; SAS with SOA which I'd like to keep at around 6" plus the 2" BL - still stay with 33's - challenge. Money wise - 2" budget lift Best mod for the money - SAS & SOA If I do something now I don't think I'll want to redo it later. SAS is something I was always eager to do on my own. I'm still considering tearing that D30 off my parts heep and crafting it under my "X"... |
#14 |
Master Apprentice
Souderton, PA
1992 XLT
IMo, either SAS it or lif it with the TTB, dont do both. I did a 5,5" superlift about 4 months ago, now I am a month into my SAS and wishing I had the money from my lift.
#15 |
Chicago
94 Limited
see, my options are "either"
either lift or SAS if I do decide on SAS I'll lift it some as well... it would be kind of useless to install a solid axle without lifting the rig some... |
#16 | |
tx
1998 ford explorer 4x4
Quote:
__________________ 98 sport sas full width dana 44 / 9" 38x15.50" TSL radial, locked f/r 5.13's http://www.cardomain.com/member_page...page_id=730638 |
#17 |
Chicago
94 Limited
you know what they say... "Never say never"
#18 |
Moderator
I remember seeing this somewhere else. The TTB lifts are just that, a lift. If you want to actaully off-road it and really use it, then SAS it. You can fit 35s with 6" lift easy too. You don't need that body lift if you SAS. Now I beat the crap out of my old one with the Trail Master 4" with 35s for almost three years and didn't have any major problems, but with the SAS on my current one...this thing is seriously bad ass!
zainyD, I'll give you a few links to a lot of sweet pictures. __________________ COLIN IGNACIO FORUM RULES My 2010 Explorer - Explorer #1 (sold) - Explorer #2 (sold) - My F-150 (sold) - My Ranger (sold) - My Videos |
#19 |
Salem CT
2000 Ranger XLT
if your going to use a D30 then the xj 30 you have is the one to go with. since it is HP. cut the coil pearches off and weld some wedges on and run your radius arms
__________________ Join the Resistance
#20 |
ELITE BRONCO2ERER
Crawlorado
B2 Mod
Drop bracket kits SUCK
![]() Solid or long travel, or both.......only way to go Anything else is just you avoiding the inevitable. Anyone serious about trails in an Ex or ranger is going to eventually end up with a solid axle. So you can delay it as long as you want, ignore it, or whatever.....or just do it ![]() yes I am a hold out, I will likely always run a TTB in the BII and LT A arms on the Explorer, but then my focus is not just trails and rocks..... __________________ 96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's 88 BII 5.0L conversion - BII 5.0l drivetrain thread My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates Wifes 07 FJ build - 2007 FJ cruiser locked and lifted |
| Thread Tools | |
