Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
2002 PO775 Code
Reply
Thread Tools
Old 03-19-2006, 02:22 PM   #1
Troy1839
PA
02 XLT
Vehicle Specs
(Original Poster)
2002 PO775 Code
Yesterday my 2002 xlt overdrive light stated to blink than the cheak engine light came on. The code that comes up is PO775 but I can not find any thing about this. The truck also started to hesitatet shifting from 1st to 2nd.
Thanks
Troy
Troy1839 is offline   Reply With Quote
Old 03-19-2006, 04:18 PM   #2
ExplorerDMB
Moderator/Technician
Mechanicsville, Virginia
2004 Acura TL
Vehicle Specs
P0775 - Pressure Control Solenoid "B"
I believe these transmissions have had issues with a few solenoids. There may be a TSB on it. Good luck
-Drew
__________________
My Useful Threads (38 Entries and Growing)
ExplorerDMB is offline   Reply With Quote
Old 03-19-2006, 05:57 PM   #3
daveleeander
Marietta, OH
02 XLT
Vehicle Specs
If you have to change the solenoid, they come in a block now. You can't change just one. The block from the stealership is around $290.00 (probably depends on the stealership).
I changed mine in about two hours. Be careful if you do, and get all the fluid back in. Don't just fill up the pan while the car is not running. You have to have the car running, in park, and have the fluid come back out the fill hole before you have enough in.
Dave
daveleeander is offline   Reply With Quote
Old 03-21-2006, 09:12 AM   #4
Troy1839
PA
02 XLT
Vehicle Specs
(Original Poster)
Thanks for you help. I signed up with a TSD survice through rock auto. Nothing was mentioned adout that identical problem. I also orded a manual for the transmission so I have an idea what to expect when droping the pan. Ill probally work on taking apart on Friday.
Thanks again for all you help
Troy
Old 02-08-2013, 10:19 PM   #5
Benylema
Vehicle Specs
I know it's been long time ... But did that fix the problem ?
Benylema is offline   Reply With Quote
Old 02-18-2013, 10:44 AM   #6
rocco123
Endicott, NY
rocco123's Avatar
1994 XLT & 2002 Limited
Vehicle Specs
The update that its fixed is appreciated.
Thanks
rocco123 is offline   Reply With Quote
Old 02-18-2013, 12:45 PM   #7
drew76924
03 mountaineer
Vehicle Specs
I had the same code and my solenoid block was good but my overdrive servo was broke
drew76924 is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
