Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer Audio & Navigation
Notices
Explorer Audio & Navigation Audio and navigation systems. CD, DVD, MP3, GPS, Video, Mobile Computer, Speakers, Amplifiers.
I have no more Bass
Reply
Thread Tools
Old 03-22-2006, 01:18 PM   #1
nickm347
'00 Eddie Bauer
Vehicle Specs
(Original Poster)
I have no more Bass
nickm347 is offline   Reply With Quote
Old 03-22-2006, 01:29 PM   #2
justin146
Oxford, MS-- home of the Ole Miss Rebels
justin146's Avatar
2000 XLT Sport 5.0 Turbo
Vehicle Specs
I am betting it is the sub itself. The stuff isnt that hard to change out, but you have to remove all of the rear panels on that side of the truck...and pull up the capret.
__________________
....used to own a Turbocharged 5.0 Explorer.
justin146 is offline   Reply With Quote
Old 03-22-2006, 01:39 PM   #3
cculter
Shake and Bake
Flatrock, Michigan
cculter's Avatar
'92 sport
Vehicle Specs
Unless you have had a wire come loose the sub would make noise still if it blew. The amp might have gone bad, in either case you would be looking at around $100.
cculter is offline   Reply With Quote
Old 03-24-2006, 06:24 AM   #4
mab668
manalapan mj
2004 xls
Vehicle Specs
I have two Rockford 12 inch subs in my truck blew both the magnets off the sub and the still made some noise not much but some I would start looking at the wiring or the amp first
mab668 is offline   Reply With Quote
Old 03-24-2006, 08:27 AM   #5
justin146
justin146's Avatar
Vehicle Specs
Quote:
The subs usually burn out the coil when they go, hence no noise at all.
__________________
Old 04-02-2006, 11:15 AM   #6
cculter
Shake and Bake
Flatrock, Michigan
cculter's Avatar
'92 sport
Vehicle Specs
Quote:
I have never heard of the coil going out on a sub before, I have always known them to "blow up". They make a scratch noise when you push on them.
Old 04-02-2006, 12:04 PM   #7
schimmel03
Ankeny, IA
00 Explorer Limited
Vehicle Specs
He is right. If the coil works too hard it gets hot. Too hot and it will burn out kind of like a light bulb. Which, yes, will give you the scratching noise when you push on it, but it depends on how bad the coil burned as to whether or not it will make noise. Best bet, check the wiring and smell the amp. If its not either of those, look at the sub. I'm gonna bet on the sub.
__________________
2000 Explorer Limited
4.0 SOHC V6
Mods: 3in Body lift
Coming Soon: Shackles and TT, 33x12.5x15's on 15" Diamond Backs, Westin Sportsman Grill Gaurd
schimmel03 is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
