Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Parking Brake Handle
Reply
Thread Tools
Old 03-22-2006, 10:17 PM   #1
konaboy
Ohio
1997 XLT
Vehicle Specs
Quoted: 6 Post(s)
(Original Poster)
Well this wonderfully constructed part has broken for the second time. The assembly is fine and works it's just that stupid plastic hadle you grab snapped off the rod that releases the brake. The first one was replaced under an extended warranty 2 years ago. I don't really want to spend the money (quoted $150 from local dealer) to replace the whole assembly since it works fine and it's just that stupid plastic part. Soooooooo I'm trying to be creative and come up with another part (something "T" shaped) I could substitute for it that would allow me to grip and release the brake. Figured the right part and JB Weld might hold it on. Any suggestions??
BTW the handle that broke is unusable, too many pieces to put it back together.
konaboy is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-23-2006, 09:21 AM   #2
zx6-guy29
Kaiserslautern, Germany
'96 Sport
Vehicle Specs
Quoted: 0 Post(s)
here is how i fixed mine:
Go to Home Depot or Home Base etc, and get a headless bolt that is the same diameter as the shaft for the brake release and about 2 inches long or so(not sure exactly how long it is) Next, get a knob that is threaded to fit the bolt. Finally, get 2 u-bolts with nuts. Secure the bolt with the knob on the end of it to the shaft for the brake release and you are home free! Just make sure the u bolts are very snug so it doesnt slide off. I did this myself, in about 10 minutes, and for a grand total of about $4.00. It has been this way for close to a year and about 13,000 miles and has worked great. Good luck!
__________________
"It takes 80,000 pounds of pressure to crush a car"
zx6-guy29 is offline   Reply With Quote
Old 03-23-2006, 04:14 PM   #3
Papa
Clearwater, FL
97 Eddy
Vehicle Specs
Quoted: 0 Post(s)
The U bolts sound good but if you want to kick it up a bit one of those Allen wrench T handles would give your fingers something to grip onto or a trip to the local junk yard.
Papa is offline   Reply With Quote
Old 03-23-2006, 05:28 PM   #4
SkanlaxJMO
Syracuse, New York
96 XLT
Vehicle Specs
Quoted: 0 Post(s)
ide say go to a junk yard and pull the handle off of a ford with the e-brake release in the dash also the ubolt idea sounds good....i cant help but notice you are from Phio...were abouts?
__________________
2005 F-150
SkanlaxJMO is offline   Reply With Quote
Old 03-23-2006, 07:45 PM   #5
konaboy
Ohio
1997 XLT
Vehicle Specs
Quoted: 6 Post(s)
(Original Poster)
Might give the ubolt a try. Curious to the placement of both ubolts though. Are you overlapping the screw with the brake assembly and clamping at the end of the screw and end of the PB assembly??
I was walking through sears last night killing a few minutes and saw a 0-1/4" tap handle and also the "t" handled allen wrenches and thought man those are almost perfect, now how to get them to work.
ScanlaxJMO I'm outside of Cincinnati
As always this place is full of great info!
Old 03-24-2006, 06:57 AM   #6
konaboy
Ohio
1997 XLT
Vehicle Specs
Quoted: 6 Post(s)
(Original Poster)
ttt
Old 03-24-2006, 12:09 PM   #7
zx6-guy29
'96 Sport
Vehicle Specs
Quoted: 0 Post(s)
Yes I just overlapped the bolt with the release handle shaft. The 2 u-bolts just have to be long enough to get around both the bolt and the shaft and still get the nuts on. (not too long!) The knob I used is actually similar to what you might see on a table saw or similar power tool that would be used to quickly loosen and tighten things that you would be adjusting. Its about 3/4" diameter, round, black knob. I looked for a t-handle with an allen bolt as mentioned above, but couldn't find a suitable one. (unfortuantely we have no Home Depot in Germany. Sometimes I really miss the US!!)
__________________
Old 03-24-2006, 05:37 PM   #8
konaboy
Ohio
1997 XLT
Vehicle Specs
Quoted: 6 Post(s)
(Original Poster)
Well it worked. THANK YOU, THANK YOU, THANK YOU!!!!!!
Used a piece of All thread rod 8/32 (2)ubolt/cable clamps and of all things a drawer pull normally used on cabinets or furniture. (nice brushed stainless so it looks good when the door is opened.) Gave it a few pulls and seems to be holding.
All thread .84 for a 2' piece
drawer pull $2.99
cable clamps $1.87 (came in a pack of 3)
Total $5.70 plus tax
Saved $144.30 and the aggravation of installing the whole PB assembly.
Thanks for the tip!
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
