Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
A4LD Governor Replacement
Reply
Thread Tools
Old 01-18-2009, 08:31 PM   #21
Willard
Elite tree-smasher
Bloomington, Indiana
Willard's Avatar
04 Ranger Edge
Vehicle Specs
So which one of those part numbers is for explorers? Or are they even the same?
I only ask because when I go about replacing mine I don't want to have to take it out to see which one I need, and then have to wait for parts.
__________________
Jesse
'94 Eddie Bauer DD/Beater
"Old Faithful" RIP
'04 Ranger Edge DD "Black Knight"
You want to see my face?
Willard is offline   Reply With Quote
Old 09-09-2009, 12:00 AM   #22
KevinCro
Vehicle Specs
I have this problem also (won't shift under acceleration). I notice some transmission fluid on the bottom of the tranny pan. My truck is a 2000 model 4X4 with 83k on it. The dealer said that they just had the transmission rebuilt. I took the truck back to the dealer and they kept it a week and it was doing the same thing when I got it back. Could the fluid leak and shift problem be related? My transmission is the 5R55E.
KevinCro is offline   Reply With Quote
Old 09-09-2009, 09:13 AM   #23
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Welcome to this forum! Your 5R55E doesn't use a governor.
BrooklynBay is offline   Reply With Quote
Old 09-13-2009, 11:54 PM   #24
zjrog
Tooele,Ut
Vehicle Specs
When I rebuilt my 94 A4LD, I was told to make absolutely certain that all the governor parts move smoothly. I spent a couple minutes very carefully smoothing the parts with some crokus cloth.
__________________
My Ranger project, the WARTHOG. Or, 1994 Explorer disguised as a 1990 Ranger
And the 94 EX. sacrificed for the Ranger
zjrog is offline   Reply With Quote
Old 02-26-2010, 02:20 PM   #25
nic092
Shreveport, LA
2006 Explorer XLS
Vehicle Specs
If I was to take the governor out, would it help with racing and faster shifting?
nic092 is offline   Reply With Quote
Old 02-27-2010, 09:16 PM   #26
BrooklynBay
Brooklyn, NY
Vehicle Specs
Your transmission doesn't have a governor.
Old 05-03-2010, 01:56 PM   #27
jd4242
va beach
jd4242's Avatar
92 SC
Vehicle Specs
will the governor cause problems if its warm?
__________________
92 xl 5.5"duff arms,3"BL,PJ 36x14.50,wrapped headers,side dump exhaust,.20 over,HF oil pump,422cam,45cc 95tm p+p 10.67:1 heads,p+p lower manifold,75mm TB,90mm maf,36lbs injectors,P+P GM M90 Supercharged & intercooled!!SCT tuned!!electric fan,4.88s aussie locked front & back!!next NOS&W/M
http://www.explorerforum.com/forums/...=double+vision
jd4242 is online now   Reply With Quote
Old 05-26-2010, 12:47 PM   #28
coreman23
Big Bear, CA
92 XLT
Vehicle Specs
I think I have a problem with my governor too. My transmission only slips when it is cold and just fired up. When the car is warm, it never does it. I'll put it into gear and it's like it slips out to neutral. Revving it get it to kick into gear again.
Once I'm up to about 20mph, I never have the issue, if it's still cold and I stop, it sometimes does it again, but once I'm warm, it's never does it.
My question is when replacing the governor, I see there is a spring, a valve, the valve body and the weight. Should I just replace all of these while I'm there?
I've looked for the parts on sonnax.com but it looks like they only have the weight. I also looked at the valve on the wittrans.com site, but they have a number of different valves on there. Do I have to take mine out to measure then order? Are they year specific?
Or am I way off, I have also been reading similar things happening with a bad vacuum modulator. Which should I try first?
coreman23 is offline   Reply With Quote
Old 05-26-2010, 01:21 PM   #29
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
As far as I know, a sticking governor won't cause "slipping". It will cause no 1-2 shift when it hangs.
When I bought a new governor years ago from a local trans shop I got the entire assembly, not just the weight and I didn't ask for anything special. I just told them I wanted to replace the governor and thats what they gave me.
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is online now   Reply With Quote
Old 05-26-2010, 04:05 PM   #30
coreman23
Big Bear, CA
92 XLT
Vehicle Specs
~Mark
Maybe "slipping" is the wrong word. It acts like it's in neutral in all the gears, reverse, od, d, 2 and 1. If I rev it up a little and back off, it drops into gear. Then when it's warm, doesn't do it again.
Old 05-31-2010, 08:41 PM   #31
coreman23
Big Bear, CA
92 XLT
Vehicle Specs
Anybody have an idea?
Old 05-31-2010, 08:43 PM   #32
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
To me, that sound more like the servos and seals and not the governor.
Hopefully one of the real trans experts will chime in now..
~Mark
__________________
Old 05-31-2010, 09:30 PM   #33
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quote:
Originally Posted by coreman23 View Post
Maybe "slipping" is the wrong word. It acts like it's in neutral in all the gears, reverse, od, d, 2 and 1. If I rev it up a little and back off, it drops into gear. Then when it's warm, it doesn't do it again.
It sounds like it could have bad valve body gaskets. Connect a 0-300 PSI pressure gauge to get some cold-hot readings in all gear ranges.
Old 06-01-2010, 11:23 AM   #34
coreman23
Big Bear, CA
92 XLT
Vehicle Specs
Quote:
I'd have no idea how to do that, I guess I'll have to take it to the shop and have it looked at. Thanks!!!
Old 06-02-2010, 12:29 AM   #35
BrooklynBay
Brooklyn, NY
Vehicle Specs
We have a sticky thread on using a pressure gauge: http://www.explorerforum.com/forums/...d.php?t=117998
Old 10-03-2010, 08:41 AM   #36
jw42
olney, il
1991 ford ranger
Vehicle Specs
Thanks for the information.jw42
jw42 is offline   Reply With Quote
Old 11-14-2010, 08:49 PM   #37
Fordexplorerguy1
NC
Fordexplorerguy1's Avatar
94 XLT 4.0 tow package?
Vehicle Specs
Now im new to this to remove the extension housing do you have to drain the fluid in the transmission? (dumb i know just making sure)
Fordexplorerguy1 is offline   Reply With Quote
Old 11-14-2010, 08:53 PM   #38
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
IIRC, No, you don't need to remove the fluid.. But some fluid does leak out when your doing the work.
~Mark
__________________
Old 11-14-2010, 09:12 PM   #39
Fordexplorerguy1
NC
Vehicle Specs
k and mine is a 4x4 too so would that change anything?
Old 11-14-2010, 09:15 PM   #40
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Nope.. Ours is too. . I just pulled the transfer case, pulled the governor and weight and put new ones in.. I don't remember lots of fluid coming out.. I do remember the transfer case being really stuck on since we use "right stuff" instead of a gasket between the case and the trans.
btw.. I didn't pull the tail housing.. I just reached through it.
~Mark
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
