EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
A4LD Governor Replacement
Reply
Thread Tools
Old 05-26-2011, 10:23 PM   #81
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Did you enter a part number into the search bar of the site? What about doing a Google search with the part number?
BrooklynBay is offline   Reply With Quote
Old 05-26-2011, 10:32 PM   #82
90Aero
90 Aerostar 4.0L
Vehicle Specs
Quote:
I did find one site that appears real that does have that part number:
http://www.fordpartsgiant.com/parts/...z-7c063-a.html
However, I'm not sure its truly the right part....I'm going on faith that the Ford parts guy provided the right part number
Since the body is aluminum and the piston is steel, I would imagine that the body is what would wear and going with a new body should do the trick
90Aero is offline   Reply With Quote
Old 05-26-2011, 10:40 PM   #83
BrooklynBay
Brooklyn, NY
Vehicle Specs
The price isn't bad from that link. I think that you should contact them before ordering it just to be safe.
Old 08-10-2011, 10:49 AM   #84
90Aero
90 Aerostar 4.0L
Vehicle Specs
Question
After my governor failed again, I never did go back in and fix it...yet. I called a trans shop to see what they wanted to R&R the governor and they said that the governor fails when something else in the trans starts to come apart and there is a lot of debris. The debris that I found in the trans I would call minimal for a trans with 114K miles.
However, when I did remove and clean/polished the governor originally, it only worked for maybe 40 miles and then seemed to gradually stop working. The issue might be that the governor is worn and debris can now jamb it easily, or the trans shop could be right and there is a larger issue. Personally I felt that the governor after polishing was perfectly good with little wear....but perhaps the tolerances need to be extreme for the governor to function in the presence of normal transmission wear debris?
Any thoughts?
Old 08-10-2011, 02:14 PM   #85
BrooklynBay
Brooklyn, NY
Vehicle Specs
The stalk eventually wears out, so it has to be replaced just like any other part that ages with mileage.
Old 08-10-2011, 02:51 PM   #86
90Aero
90 Aerostar 4.0L
Vehicle Specs
The stalk?
Old 08-10-2011, 02:52 PM   #87
BrooklynBay
Brooklyn, NY
Vehicle Specs
I was referring to the shaft on the governor where the weight rides.
Old 08-10-2011, 03:50 PM   #88
90Aero
90 Aerostar 4.0L
Vehicle Specs
That is the aluminum portion which also contains the piston.
When I originally took it apart, the weight seemed to move freely, however, the piston was frozen. Even after I unfroze it and cleaned it, it would not move freely. So I used fine steel wool and soon after it seemed like new.
I'm at a loss to understand why it has again stopped working.
My plan was to buy the new aluminum piece rather than attempt to continue to make the original work. But my issue is that I don't really know why it has frozen again......wear or debris.
But then the front seal starting leaking and I starting considering just donating the vehicle.
Old 08-11-2011, 01:29 PM   #89
90Aero
90 Aerostar 4.0L
Vehicle Specs
Question
The 1995 Aerostar was the last Ford vehicle to use an A4LD transmission.
Will the 1995 Aerostar A4LD bolt right in to the 1990 Aerostar?
The wiring and linkage is all the same?
Old 08-11-2011, 10:35 PM   #90
BrooklynBay
Brooklyn, NY
Vehicle Specs
The bracket for the column shift is different than the bracket for the floor shift, but they are easy to swap. The 95 doesn't have a VSS on the extension housing since it has an ABS sensor on the top of the differential.
Old 08-12-2011, 09:00 AM   #91
90Aero
90 Aerostar 4.0L
Vehicle Specs
Question
What is the latest A4LD that will bolt right in to the 1990 Aerostar, assuming a Aero and/or a Explorer donor?
Old 08-12-2011, 11:31 AM   #92
BrooklynBay
Brooklyn, NY
Vehicle Specs
1995 for the Aerostar, and 1994 for the Explorer.
Old 08-12-2011, 01:11 PM   #93
90Aero
90 Aerostar 4.0L
Vehicle Specs
Didn't you say that the 1995 Aero A4LD does not have the Speed sensor?
I certainly have no problem with moving my sensors or brackets to a later trans, but if the later trans does not have the right holes, then its not a drop in replacement and probably more than I want to tackle. My plan is to go to the wrecking yard and grab a trans and torque converter and replace my trans as painlessly as possible.
Old 08-12-2011, 04:01 PM   #94
BrooklynBay
Brooklyn, NY
Vehicle Specs
The 1990 extension housing, and the internal gear for the VSS could be transferred over to the 1995 transmission.
Old 02-23-2012, 03:55 PM   #95
flatland180
west valley city, UT
1994 Ford Explorer
Vehicle Specs
Hi I have a slight problem I'm in the process of taking the transfer case off and down to one bolt that is slightly striped and slightly out of reach I need some advice on how to get this last bolt off please help.
flatland180 is offline   Reply With Quote
Old 02-23-2012, 07:44 PM   #96
BrooklynBay
Brooklyn, NY
Vehicle Specs
Welcome to this forum! Is the head stripped or the threaded part? S-K Tools, Craftsman, and Harbor Freight sell bolt out stripped head bolt remover tools.
Old 02-24-2012, 12:46 PM   #97
flatland180
1994 Ford Explorer
Vehicle Specs
The head was stripped I eventually got the bolt off by getting the transfer case low enough to fit a wrench over and break it loose. Now another question I have installed the new governor is there anything i should keep an eye on any symptoms? the truck seems to be running just fine no rough drops from first to second.
Old 02-24-2012, 02:19 PM   #98
BrooklynBay
Brooklyn, NY
Vehicle Specs
You don't have to do anything unless the shift quality degrades. Was the replacement new or used? I would recommend the Sonnax weight.
Old 02-24-2012, 02:51 PM   #99
flatland180
1994 Ford Explorer
Vehicle Specs
The replacement was used and better then the piece(s) in the truck. What does the sonnax weight do that the stock one doesn't? How much does it cost and do they have facilities or is it order only?
Old 02-25-2012, 07:53 PM   #100
BrooklynBay
Brooklyn, NY
Vehicle Specs
It's a heavier weight, so it won't stick as easily. WWW.TransmissionPartsUSA.Com sells it. A used governor might have wear on the stalk. You could purchase a new one from WWW.Wittrans.Com.
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
