| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Elite Explorer 911! 911! is for situations where your truck is currently out of commission and the owner is in a crisis situation. Members will try to answer your questions asap, no time frame is guaranteed. Only Elite Explorers can post new threads in this forum |
Thread Tools |
#1 |
Wannabe Elite Explorer
R.I.
92 xlt
Installing new power sterring pump
A friend just called asking me to go over and help him change his power sterring pump. Its NOT an EX, its a general motors V-8. I haven't changed one in 30 years or so.
Question is do I just break the lines and change? No pressure lurking? Do I have to bleed it after installing new pump or just add fluid? Sorry but I just can't remember its been so long. Any tips? Waiting to hear to go over and help do the job, thanks. |
#2 |
Aerostar Forum Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
You will need a pulley remover/installer kit. After you remove the lines, and reconnect everything, refill the reservoir, and turn the steering wheel from left to right a few times to bleed any air out of the system.
#3 |
R.I.
92 xlt
Thanks. We alwready did it. Sorry I didn't post back earlier. It came back to me as we went along. Pulling off the pully came to me as soon a I saw the new pump without the pulley. Then filling.
#4 |
Brooklyn, NY
How long did it take to change? Did you have any difficulty, or was it pretty much a straight forward job?
#5 | |
R.I.
92 xlt
Quote:
Was kinda easy and straight foward. Took some fluid out of the pump, drained some antifreeze , removed belt and heaterhoses bla bla a, pulled the whole pump with the bracket and all then took bracket off. My buddie took it to another friend to remove and replace the pulley so I don't know how long that took. I came back a couple of hours later and he had alwready started installing and we finished up. Probably a couple of hours+ inbetween beers. LOL. |
#6 |
Charlotte, NC
'92 Sport 4x4
i wonder if there is a way to adapt the a chevy (or any brand for that matter) power steering pump to the explorer pump pulley?
The explorer pump works fine, its just freaking noisey... Its definatly hard to kill, it will just whine foooorrrreeever |
#7 |
Brooklyn, NY
I converted my 88 to an electric/hydraulic pump about 12 years ago. I designed the electronic control module, and the steering column sensor set up. The module in there now is my second design that has been improved with some new features compared to the first one. I could steer with the engine off, since it is electric. Since then, a lot of manufacturers have done this kind of stuff in different variations. Some use an electric pump with the manual pump for a little extra boost pressure when parking, also known as VAPS, or variable assist power steering (1988 Continental), some have all electric (Toyota MR2) with a variable pressure in proportion to the VSS' output signal, and others have variable valves to regulate the pressure along with magnets to regulate the steering effort (1996 Delphi Saginaw Magnasteer). Magnasteer doesn't use any solenoids, or stepper motors. Now, TRW has a completely electric rack, and pinion that is similar to a linear actuator. By the way, all of these companies claim that there is a small increase in gas mileage, and horsepower, since it doesn't have a pump loading down the engine.
#8 |
Brooklyn, NY
Here is a good article about the subject: http://aolsearch.aol.com/aol/redir?s...+Larry+Carley+... Here is that article:
Servicing Variable-Assist Power Steering Systems By Larry Carley Variable-assist, variable-rate or variable-effort power steering is used on a growing number of vehicles. Variable assist is a way of providing the best of both worlds: finger-tip parking maneuverability at low speed and reduced assist at higher speeds for greater stability and road feel. As a vehicle’s speed increases, less effort and assist are needed to steer the wheels. Variable-rate steering, by comparison, applies more assist at low speed when it is needed most and reduces assist at higher speeds when it is needed least. FORD Ford’s Variable-Assist Power Steering (VAPS) which was first used in 1988 on the Lincoln Continental, and in 1989 on the Ford T-Bird and Mercury Cougar, uses a stepper motor actuator valve to vary steering assist. The valve in the older Lincoln applications is mounted on the steering gear while one on the T-Bird replaces the outlet valve on the power steering pump. The VAPS control module receives two sensor inputs: A vehicle speed signal from a transmission-mounted sensor, and an optical steering wheel rotation sensor in the steering column. At speeds up to 5 mph, the control module’s output to the actuator valve is zero milliamps (mA) and the actuator valve is wide open allowing full assist as required. As the vehicle’s speed increases above 5 mph, the module starts to close the actuator valve to reduce power assist in direct proportion to speed. At 20 mph, module output to the actuator valve is 225 mA and the actuator is partly closed to reduce steering assist 20 to 25 percent. At 80 mph, the module’s output reaches its maximum of 550 mA closing the actuator valve to its minimum orifice opening. Assist is now reduced 50 percent from its maximum level. As the speed drops back below 80 mph, the actuator valve starts to open again to gradually increase power assist in proportion to speed. The steering wheel rotation sensor also modifies the amount of power assist depending on how quickly the driver is turning the wheels. A sharp sudden turn will cut power to the actuator valve allowing full assist. On Ford’s later "Electronic Variable Orifice" or EVO system (1991 models & up), a small stepper motor is also used to open a variable orifice valve on the steering rack. GM MAGNASTEER In 1996, a more sophisticated type of variable-assist power steering developed by Delphi Saginaw Steering Systems, named "Magnasteer," was introduced on: Buick Electra, Le Sabre, Park Avenue and Reatta; Cadillac Eldorado, Seville STS and DeVille Concours; Chevrolet Corvette; Oldsmobile Aurora; and Pontiac Bonneville. In 1997, Magnasteer became standard on all Cadillacs and has since been added to a wide range of other GM makes and models. Unlike EVO power steering systems, Magnasteer does not use an orifice valve to reduce pressure to the steering gear. There’s no solenoid or stepper motor involved. Instead, Magnasteer uses magnets to assist or resist steering input. The Magnasteer control valve assembly is mounted on the steering rack in the same location as a regular control valve assembly on an ordinary power rack. Inside the base of the Magnasteer unit is a large electromagnetic coil. Just above the coil is an inner and outer pole assembly with a permanent magnet in the center. Steering feel is varied by changing the strength and polarity of the magnets, which in turn, is controlled by changing the pulse width and direction of the current to the coil. On 1996 and 1997 applications, Magnasteer has its own separate control module. But on 1998 and newer applications, the Electronic Brake Control Module (EBCM), which also oversees the operation of the anti-lock brake system, handles the Magnasteer control function. On most applications, the only input the control electronics uses for Magnasteer is the vehicle speed sensor. At zero mph, a negative current of approximately two to three amps flows to the Magnasteer coil. This causes the magnets to repel each other, which in turn allows more deflection in the torsion bar inside the spool valve assembly. This increases fluid flow through the spool valve to the steering gear for maximum power assist when it is needed most. As vehicle speed increases, current flow to the Magnasteer coil is gradually reduced. At about 45 mph, current flow to the coil hits zero and Magnasteer has no effect on the amount of power assist (which is determined only by the torsion bar and pump flow). Above 45 mph, the direction of current to the coil is reversed and continues to gradually increase up to a maximum of about three amps at 75 to 85 mph. Reversing the polarity of the coil causes the magnets to attract each other, which has the effect of stiffening the torsion bar. This reduces the amount of deflection in the torsion bar that normally occurs when the wheels are steered and causes an increase in steering effort for better road feel and high-speed steering stability. On some Magnasteer systems, such as that used in the Corvette, the Electronic Brake Traction Control Module (EBTCM) also looks at input from a steering wheel position sensor to determine if more or less steering assist is needed under certain driving conditions. The main purpose here is to reduce oversteer by reducing assist when excessive G-forces are detected. Compared to conventional power steering systems, Magnasteer gives the driver a much broader range of power assist with a smooth transition from low to high speed. What’s more, the system can be recalibrated to modify steering feel using a Tech 2 or equivalent aftermarket scan tool. There are three settings: factory, firmer and less firm. Just follow the scan tool prompts and that’s all there is to it. In 1998, a second generation "Magnasteer MAGe" system was introduced on some GM vehicles. This version of the system does not use a permanent magnet, but uses a redesigned electromagnet that has one pole mounted on the input shaft and the other on the pinion shaft. At low speed, there is no current flow through the electromagnetic coil. The level of steering assist depends solely on the calibration (stiffness) of the torsion bar. As speed increases, current flow to the coil is gradually increased up to a maximum of several amps to decrease assist and increase steering effort. Magnasteer MAGe uses vehicle speed as its only input, so there are no changes in steering effort during sudden steering maneuvers. DIAGNOSIS Problems with electronic variable-assist systems include all of the same things that can go wrong with a conventional power steering system (leaks, center wear in the steering gears, pump & hose failures, etc.), plus problems with the control electronics including the vehicle speed sensor circuit, the solenoid valve and control module. Accurate diagnosis, therefore, is essential to minimize warranty returns. Most of these systems provide diagnostic fault codes that can be accessed with a voltmeter, test light or scan tool to pinpoint the nature of the fault (if the fault is electronic rather than mechanical or hydraulic). If power to the solenoid or control valve actuator is lost, the valve keeps the bypass circuit closed so full power assist is provided under all driving conditions. The only indication of trouble, therefore, might be a loss of road feel and/or increased steering sensitivity at highway speeds. It’s important to remember that variable-rate power steering only reduces the amount of pressure that reaches the steering gear at higher road speeds. The only way it could reduce power assist at low speed would be in the unlikely event the actuator or solenoid valve failed in the open position. This could cause a noticeable reduction or loss of power assist. If the control solenoid fails on a Ford EVO system, or the control circuit for the solenoid is lost, the valve is designed to keep the bypass circuit closed so full power assist is provided under all driving conditions. The only indication of trouble would be a loss of road feel and/or increased steering sensitivity at highway speeds. However, if the EVO solenoid valve jams in the open position, there would be little or no power assist at any speed. On GM’s Magnasteer racks, loss of current to the magnetic coils would cause a loss of power assist at low speed. Coil resistance can be checked with an ohmmeter, and should read about two ohms. An infinite (open) reading indicates a bad coil (requires replacing the rack since the coils are not serviceable). Checking for shorts between both sides of the coil assembly and rack housing is also recommended. The system does have self-diagnostic capability, but there is only one fault code: C1241 (Magnasteer circuit malfunction). The code is set if the module detects an open or a short in the coil circuit. If this code is present, the Magnasteer system is disabled and will not vary the steering effort as vehicle speed changes. The C1241 body code can be read with a Tech 2 or equivalent scan tool. The Tech 2 tool can also be used to perform a Magnasteer function test. The test varies the current to the coil so you can check for a change in steering effort when turning the steering wheel. Replacement racks for variable-assist power steering applications are available with or without an EVO control solenoid. As long as the original EVO control solenoid is working OK, it can be removed and installed on the replacement rack to save your customer a few bucks. There’s no need to replace the whole rack if only the EVO solenoid valve is defective. On GM Magnasteer applications, the whole rack must be replaced if the rack or control unit is defective because the Magnasteer unit is part of the rack. Handle with care because the permanent magnets inside the Magnasteer valve assembly and connector are fragile and can be easily damaged. |
#9 |
R.I.
92 xlt
Those all seem good however I really can't remember having to replace a PS pump on any of my vehicles Ford, Gm or Dodge with 100,000 to 200,000 miles on them. Well not with vehicles from the 80's and newer anyway. Years ago it was fairly common to hear all the autos winning as they turned. People were ordering new vehicles without PS. And yes, my Ex whines too. LOL. When I first drove it I thought it was the trannie.
| Thread Tools | |
