Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
4x4 Transmission Problems
Reply
Thread Tools
Old 04-02-2006, 01:21 AM   #1
tmorrison83
CA
92 XLT
Vehicle Specs
(Original Poster)
Angry 4x4 Transmission Problems
Hi just bought a 92 XLT with auto tranny w/ overdrive and the transmission sticks in 2nd gear when it gets warmed up. The transmission has about 160K on it so I am thinking it could be a clutch problem. I was told it also could be a 2/3 accumulator and that that was a bad problem on these things. Can someone point me in the right direction?
Thank You
TMORRISON83
tmorrison83 is offline   Reply With Quote
Old 04-02-2006, 01:29 AM   #2
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Welcome to this forum! The correct place to post future transmission questions would be in the transmission section. You do have clutch plates within the transmission, but it shouldn't be confused with the clutch that is used on a manual transmission. The valve body has the accumulator that somebody mentioned to you. When was the last time the fluid, and filter were replaced? Did you try to adjust the intermediate band? This is the middle adjustment. The first one in the front is for the overdrive. Did you check the vacuum hose going to the modulator? If fluid is in there, then the modulator is no good.
BrooklynBay is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
