| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Explorer Audio & Navigation Audio and navigation systems. CD, DVD, MP3, GPS, Video, Mobile Computer, Speakers, Amplifiers. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Lincoln, Nebraska
1989 xlt
I just joined the site because I am a little in the grey about how i go about hooking up 2 10 inch punch subs and an amp to my factory cd/casset player. the model # on back is F87F-18C868-AE and it is in my 1998 Ford Explorer xlt. Im hoping that someone on the site has been through this problem and can help. Im not sure if there is a factory amp or not in my car. I know that there are 2 or so boxes with wiring comming out in the back storage box where the jack is located. If I do have a factory amp how do I go about making my subs work with it or is that even possible? do i need to hook up after a aftermarket amp and if so where is the REM wire located for that in the factory harness and what is the color sceam. Suggestions on what to do would be greatly appriciated being as I am spending way to much time trying to figure it out with my limited knowledge on working with aftermarket cd players and not a factory one like the explorers have but i would like to keep it in there because it is pretty nice for a factory cd player and a aftermarket would clash with the dash i think. thanks guys
#2 |
san diego, ca
01 SPORT
i hooked up two 12's with an aftermarket amp to my oem deck. first of all i dont think its possible to hook up subs to the factory amp if you do have one. even if you did it wouldnt sound that good because the amp is powerful enough at rms to puch those subs so you would have to max out the amp to push the subs.
i recomend just buying a decent amp and wiring kit for those subs. youre also going to need to buy a RCA adapter for the oem deck at any car audio place or best buy/circuit city for around $20. after that you can find a wiring diagram for oem stereo systems online, pull up the diagram for your car, and you can do it. as long as you know how to spice wires and connect wires you should be able to do it. your gonna need to run your amp kit wires(power, ground, RCA, and remote turn on wire). the remote turn on wire connects to the remote turn on wire for the deck(you will know what wire when you get the diagram). to power wire connects to the battery, ground is grounded to the frame somewhere, and the RCA wires will connect tot he RCA adapter you need to buy. After that you need to connect the RCA adapter to the right wires in your decks wiring harness(left+. left-, right+, right-). That is all you need to do to hook up the amp to the deck. wiring the amp to the subs depends on how many ohms you want to operate on. if you dont know how to do this stuff then i just recomend you take it to a privately owned car audio shop because they will know what they are doing and will be cheapest. |
#3 |
Lincoln, Nebraska
1989 xlt
alright thanks man
#4 |
chula vista, ca
'98 XLT 2WD
hey, guys. just jumping in here because i am doing the exact same thing. My buddy gave me 2 of his 10's and all i need is a amp. they are 250 wat amps so should i get at least a 500 wat amp? as u can see i am just barely putting my foot in the audio world now. im looking at stuff on ebay and prices arent bad. thing is their seems to be different types (2-channel, multy, and mono channel) what does this mean? thanks alot
__________________ ,¸¸,ø¤º°`°º¤ø,¸¸¸¸,ø¤º°`°º¤ø,¸¸,,¸¸,ø¤º°`°º¤ø,¸¸¸¸,ø¤º°`°º¤ø,¸¸, pimpin the explora Cardomain FS: Suspension parts, axle parts, more... |
#5 |
chula vista, ca
'98 XLT 2WD
bump
#6 |
Pasco, WA
'99 Mountaineer
I am trying to do the same thing. I have a box with 10's powered by a Nakamichi amp. I would like to connect this to my system without loosing any of the factory speakers. I have a '99 Mountaineer with the AM/FM CD Tape deck and 6-disk changer in the center armrest console. It also has the 8" sub in the back. Are there outputs on the stock stereo I can tap into for the sub without disconnecting any of the stock speakers?
#7 |
Central PA
2001 F350 7.3
__________________ 2001 F350 Extended Cab Long Bed Lariat 7.3 Powerstroke 4x4 1999 Mustang GT 5spd vert
#8 | |
Pasco, WA
'99 Mountaineer
Quote:
Now do you have something usefull to add, or are you just a jerk who has been in the forums sooooo long you believe you are "above" helping others???
#9 | |
Towing Moderator
North East Arkansas
2012 F150 4x4
Quote:
__________________ -Evan Febuary 09 Feature Truck - Elite Registry - Photo Gallery - Feedback - Go Elite! - My Write Ups - EF Vendors |
#10 | |
Pasco, WA
'99 Mountaineer
Quote:
So, there are NO other outputs on the factory system that will NOT limit the bass output? |
#11 |
Towing Moderator
North East Arkansas
2012 F150 4x4
No you would not have to disconnect the rear speakers, just tap into them. The line out converter will still allow you to use the speakers.
Since you have the factory sub, you can potentially connect to that output, but you will probably need a wiring diagram and a good understanding of how it works. I haven't had any experience with those setups so I can't offer much help. If it were me, I would pull the factory head unit, put in a nice aftermarket with sub controls and be done with it. I believe you can still run your factory amp and sub and with some interface modulators your disk changer. __________________ -Evan Febuary 09 Feature Truck - Elite Registry - Photo Gallery - Feedback - Go Elite! - My Write Ups - EF Vendors |
| Thread Tools | |
