Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
1992 X - Transmission MELTDOWN!!!
Reply
Thread Tools
Old 04-10-2006, 12:08 PM   #1
Maverick0007
Vehicle Specs
(Original Poster)
I have just taken my X to the tranny shop because of a Code 629 - and they said that they found my transmission harness melted in quite a few spots from the exhaust manifold, so that is probably what is causing the problem. Does anybody know where to get a new harness from?
Maverick0007 is offline   Reply With Quote
Old 04-10-2006, 01:06 PM   #2
techieman33
Topeka, KS
techieman33's Avatar
00 V8 Mountaineer
Vehicle Specs
There are lots of people on the forum parting out first gen's all the time, i'm sure one of them would be able to get you one.
techieman33 is offline   Reply With Quote
Old 04-10-2006, 05:30 PM   #3
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Which wires are melted? is it the ones that connect to the round connector or the one that is the 3 wire connector (I thinks its 3)..
I have a 700r4 in mine, and depending on how much wire you need from the harness I may be able to get your the connectors, but...
If its just the wires you can just replace the wires from between the connector and somewhre under the hood where it is melted.. Especially if it melted right at the exhaust manifold (my wires were already fixed there since they were resting on the manifold for a while). If its melted up high enough, just replace the wires (splice in new ones where they melted).
Otherwise, its a junk yard item.. but you have to find one that will let you take just that part of the harness.. and I don't think there is a connector at the upper end, so you would end up with the entire harness (engine/trans) which will cost more.
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is online now   Reply With Quote
Old 04-11-2006, 11:06 AM   #4
Maverick0007
Vehicle Specs
(Original Poster)
Thanks. I ended up splicing the wires and put new tubing around them, and ziptied it away from the exhaust manifold. Nice and neat job. I am so proud.
Old 04-11-2006, 11:54 AM   #5
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Here is a similar thread that was just posted: http://www.explorerforum.com/forums/...d.php?t=156706
BrooklynBay is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
