I have been researching this issue but haven't quite found a direct answer. I'm assuming the electronic control module must have failed but basically same issues I see everyone else had. I put my X in 4 high while on the beach but it actually got stuck in 4 low. I crawled under my X to look for this brown wire but didn't find it. Maybe I was looking in the wrong place. I took it to a mechanic and he was able to bypass something and get in 4 high but wouldn't do anything else with out charging more. So now my X is in 4 high but taking sharp turns sounds so bad and I'm sure it's gonna screw something else up. Do I just need to find this brown wire and hope it goes back into auto or am I missing something here? By the way my 98 explorer sport is a 5 speed manual, not sure if that makes any difference at all. The mechanic disabled the switch on my dash too so it does nothing now and my 4wd high and low lights will flash from time time which to my understanding means the 4wd is messed up (obviously since i'm stuck in 4 high)
Been reading up on the brown wire mod thread. Not sure that I want to "mod" the entire thing I just want to be in 2 wheel again so I don't have to hear my car binding up anymore. Also everyone is saying the switch says 4auto, 4 high and 4 low, mine just says Auto, 4High and 4Low. The mechanic tried tapping on the transfer case but it didn't free anything up. At least it looked like that's where he was tapping.
