- January 11, 2001
- McVeytown, PA
- '18 XLT
As many of you know, I recently sold my wheeling vehicle and bought a stock '94 Explorer. Weeelllll, I just couldn't leave well enough alone....
As I bought it:
As it looked after about 8 hours of work yesterday:
I put a Superlift 4" system on the truck. I've got a set of 33's sitting out in the shed I need to get mounted, and now I'm looking for 4:10's and lockers....
NOTES TO ALL DOING THE SUPERLIFT 4": I found that the suspension angles are much better when using the 5.5" lift holes in the drop brackets for the 4" lift. My camber was waaaaaayyyy off in the 4" holes, so we moved to the 5.5" holes and it's just about right. A little spring settling and it should be right on. Also, buy the extended brake lines...especially for the front. The stock lines fit...but if you flex it out you can kiss your lines goodbye...
As I bought it:
