saxon
- March 30, 2006
- seattle, wa
- '91 & '93 EB, 4WD, 4-door
Installed the heavily rebuilt valve body earlier today. Added fluid and LubeGard.
It still wants to go forward in Park and Neutral. I did get Reverse to do something new: Now I can make the X almost hop up and down. In Reverse it wants to go forward and now backwards, too. Needless to say, it doesn't move in Reverse (it did when I started this project).
Neutral behaves exactly like Drive does. I think it only works in first gear, too. If it moves on to 2nd, I can't feel it. If I try to hold the pedal constant, it slips like crazy; RPMs increase. If I roll off throttle, it coasts about like it should. If I stomp on it, it hooks up okay.
So sad. Glacier991 mentioned that something internal might have become welded together (I'm sorry but I forget what at the moment). That's my theory now. The transmission shop where I bought the LubeGard thought that something had become welded together, too.
Now I have to decide between a) buying a used one now and rebuilding my existing one later this fall after the racing season is over or b) buying and installing a rebuilt one ($999 - $1,350). The used one would only need to last until early October.
Do commercially rebuilt ones ever last more than 40k? It doesn't seem like many do. I'm pretty sure I could rebuild one to last 100k+. That being said, my existing one might not be a great candidate for a rebuild. It seems pretty messed up.
