| Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35 |
Thread Tools |
#101 |
Aerostar Forum Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
According to page 51 in this PDF: http://ratstangrestoration.com/5r55w-complete.pdf, it says that you tighten the bands to 120 In/LBS, then back them off 2 turns. This link has some information on your code: http://www.explorerforum.com/forums/...22&postcount=1
#102 |
Wannabe Elite Explorer
Baltimore, MD
2003 Explorer 4.0L
Thanks for your reply. I'm going to adjust the bands and see where that gets me. Do I need to get new lock nuts or can I reuse the old ones?
Thanks, Mark |
#103 |
Brooklyn, NY
You could reuse the old ones if the seals are still good. Sometimes they tend to leak. New lock nuts with seals are not that expensive. You could get them from WWW.TransmissionPartsUSA.Com.
#104 |
Columbus Ohio
01 Ranger
Hello my name is Ryan, and I'm new on here. I have a question about my transmission. I have a 2001 Ford Ranger 2wd 4.0L and the trans has been slipping in high gear. When I get up to around 55 60 it will kick a few times and then all the sudden go. I noticed it does it when I'm going 65 and hit the gas kind of hard like I'm going to pass someone same thing it will kick and then take off. The same happens on a hill when I'm going 55 60 and when it goes to kick into 4th out of OD it slips. I'm pretty sure my bands need to be tighten, but I would like to be sure.
I would really appreciate it if someone could explain step by step to me how to do this. I am pretty sure I got it, but need to make sure. It seems simple enough, but one mistake could really cause a problem. Thanks in advance for the help. Ryan |
#105 |
Brooklyn, NY
Welcome to this forum! The first page of this thread has a detailed step by step procedure with photos.
#106 |
Columbus Ohio
01 Ranger
Okay thanks for the reply I just wanted to make sure it was the same for all different years of trans.
Thanks. |
#107 |
Florida
03 Eddie Bauer 4WD V8
Should the lock nuts be changed every time you loosen them up? It looks like a teflon seal, and those don't always do so well with being reused.
Also, is band tightening the kind of thing that the average joe might wish he had never gotten into? Or is it a nice, simple can't-miss situation? Great thread! |
#108 |
Baltimore, MD
2003 Explorer 4.0L
It's not that hard, but on my '03 explorer it was a pain to get to the bolts and they were rusted. I had to spray them good then work them a bit to get them to where they would turn easily. New locknuts are probably a good idea since they are so cheap. There is a really good step by step instruction on here that shows you how to do it. Good luck.
Mark |
#109 |
Florida
What was stuck, the locknuts or the studs? I want to count the turns on the studs, to see how much wear there is on the bands, so hoping not to have to work them in and out.
#110 |
Baltimore, MD
2003 Explorer 4.0L
Locknut.
#111 |
Pasadena, California
99 XLT
great thread, my symptoms are as follows.... tranny rebuilt 12,000 miles ago, it has done this since i got it back. hard 1 to 2 shift possibly 2 to 3 as well, but a smooth shift at the end. could a band be causing this problem, and would i need to pull the tranny to get to the adjuster bolts or is it possible with the tranny installed. i have checked the tps cleaned MAF and checked u-joints to im trying to eliminate one thing at a time. thanks in advance
#112 |
Brooklyn, NY
The adjuster studs are located on the driver's side of the transmission, and you don't have to remove anything to get to them.
#113 |
Middleburgh, New York
1994 Splash
94 Ranger - type tranny?
Where does someone look to find the transmission type? Does it need to be on lift? I have 1994 Ranger Splash 3.0 - 4 Wheel Drive, 3 speed auto/OD - slipping in low and reverse after changing Torque Converter. Had no problems until then.
Thank you... If I can save truck by adjusting bands - That would be great! Jay |
#114 |
Brooklyn, NY
You have a 4 speed A4LD transmission.
#115 |
Norway
'96 XLT
After several DTC's I tried to adjust the bands on my 4R55E today.
The OD band went fine, but when trying do adjust the intermediate band, the bolt just disappears inwards without any resistance. I had the bolt out to clean the threads, can anything have got out of it's place because of that, or can I assume that the band is totally worn out ? |
#116 |
Brooklyn, NY
Drop the pan, and check for broken band parts.
#117 |
Norway
'96 XLT
I will have to drop the pan, seems like removing the bolt completely was a bad idea, and the "part" in the red circle has moved out of it's place.
#118 |
L.A. county, CA
2004 Explorer Sport Trac
If my 5R55E (w/60K miles, last flush at 55K, dealership rebuild at 28K) is slipping discretely and intermittently in 2-3 at 2300 rpms, does this sound more like a VB rebuild is in order, or just band adjustment?
Just to reiterate; dropping the pan is unnecessary in order to adjust the band? (I have an 04, 2WD, Sport Trac). Thanks! |
#119 |
Brooklyn, NY
You don't have to drop the pan to adjust the bands. Try the band adjustment first. It could have leaking servo pistions.
#120 |
L.A. county, CA
Thanks again, Brooklyn'. Pardon my ignorance, but this leaking servo piston...is it fixed by adjusting the bands? If it's not related, what do I need to look for visually?
| Thread Tools | |
