Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
Transmission Band Adjustment Specification Chart
Reply
Thread Tools
Old 03-17-2009, 08:38 AM   #121
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 427 Post(s)
(Original Poster)
The servo piston engages the band, so if it's leaking, it might not engage or it could engage, then slowly pinch off, and cause a shift flare.
BrooklynBay is offline   Reply With Quote
Old 03-17-2009, 12:00 PM   #122
J-Vee
L.A. county, CA
2004 Explorer Sport Trac
Vehicle Specs
Quoted: 0 Post(s)
The servo piston I take it is internal, so if it is indeed leaking there would be no way for me to verify through an external inspection of the trans, right? Please correct me if I'm wrong.
Many thanks!
J-Vee is offline   Reply With Quote
Old 03-17-2009, 04:53 PM   #123
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 427 Post(s)
(Original Poster)
It's on the passenger's side of the transmission under a round cover which is held in place by a metal snap ring.
Old 03-24-2009, 08:15 PM   #124
WoodrowUSMC
Carlsbad, CA
2002 XLT 4WD
Vehicle Specs
Quoted: 0 Post(s)
5R55W Band Adjustment
Not to hijack this thread but I have a 2002 Explorer 4.0 4WD with a 5R55W transmission. I know the procedures to adjust the Overdrive and Intermediate Bands. What I would like to know is there a need and procedure to adjust the Low/Reserve Band. I have the ATSG 5R55W manual and it only gives procedures to adjust the Overdrive and Intermediate Bands which is the same information I've found on this site. Any help/information would be appreciated. Thanks
WoodrowUSMC is offline   Reply With Quote
Old 03-24-2009, 08:31 PM   #125
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 427 Post(s)
(Original Poster)
Welcome to this forum! The low/reverse band doesn't have an adjusting stud.
Old 03-24-2009, 09:03 PM   #126
WoodrowUSMC
Carlsbad, CA
2002 XLT 4WD
Vehicle Specs
Quoted: 0 Post(s)
Low/Reverse Band
B2,
Thanks for the welcome and rapid response. Since there is no Low/Reverse Adjustment Stud, is there any type of adjustment or check to verify correct Low/Reverse band adjustment/operation? I'm assuming that the Low/Reverse Servo Assembly actuates the Low/Reverse Band. Is there any need to check and/or adjust the Low/Reverse Servo Assembly? Thanks again.
Old 03-24-2009, 09:12 PM   #127
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 427 Post(s)
(Original Poster)
Check the servo tip to see if it's broken. There is a repair part called an extendo tip for repairing broken servo tips, but you have to be careful since a tip that is too long will cause the band to drag. You could check the length with a depth gauge.
Old 04-01-2009, 03:17 PM   #128
Ryancbj22
Columbus Ohio
01 Ranger
Vehicle Specs
Quoted: 0 Post(s)
I have a question the other day I adjusted the bands and had some issues. Actually I had my dad do it....He has been a mechanic for 20+ years and he's the only one who touches my truck. Well anyways he loosened the first nut and placed the torque wrench on the bolt after several turns it was apparent that the bolt was not going to tighten down. He continued and eventually the bolt tightened down to 10ft lbs. The same was for the second adjustment, but when we went to drive it.....it wouldn't move in reverse at all and forward it had to be revved up to 3 grand and it barely moved. So we backed them off until it finally moved.....It didn't "solve" the problem but made it better and not as frequent. Anyone ever had this problem? Should I just keep adjusting them in until it stops and forget about the 10ft lbs? The bolts would turn with your fingers it wasn't like it was being cranked on with a wrench....
Thanks in advance.....
Ryancbj22 is offline   Reply With Quote
Old 04-01-2009, 07:14 PM   #129
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 427 Post(s)
(Original Poster)
Always adjust the studs to their proper torque.
Old 04-02-2009, 09:01 AM   #130
Ryancbj22
Columbus Ohio
01 Ranger
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Yeah we did that with 2 different torque wrenches and it wouldn't move....??
Old 04-09-2009, 12:25 AM   #131
98formulaLS1
Virginia Beach, VA
00 XLS
Vehicle Specs
Quoted: 1 Post(s)
quick question so i dont have to read through 7 pages of posts.
When it says, 2 turns back, that means two complete revolutions correct? as in 720* of rotation?
__________________
1995 Ford Explorer EB 4.0L 4x4
1994 Honda Civic EX d16z6
SOLD - 1998 Pontiac Firebird Formula w/ LS1 & 4L60E
98formulaLS1 is offline   Reply With Quote
Old 04-09-2009, 09:13 PM   #132
WoodrowUSMC
Carlsbad, CA
2002 XLT 4WD
Vehicle Specs
Quoted: 0 Post(s)
Yes, it means [U]exactly two turns (720 degrees) back/out.
Old 05-09-2009, 04:10 PM   #133
dallasmef
Dallas, TX
1997 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
I went out and bought a torque wrench to perform this operation. When I crawled under the Explorer, I was surprised to find the gear shift cable and mounting bracket were in the way of the adjustment bolts and locknuts and have to be removed to do this adjustment. I should have known it sounded too easy to be true.
__________________
1997 Explorer XLT-2 Wheel Drive
6 Cyl. 4.0L SOHC -5R55E+OD Transmission
dallasmef is offline   Reply With Quote
Old 05-26-2009, 12:35 PM   #134
dallasmef
Dallas, TX
1997 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
Correction to my previous post. I went back to the band adjustment immediatley above the gear shift selector and tried to get to the locknut from the back side with a wrench. There is more room from that angle to work.
__________________
Old 07-02-2009, 09:43 PM   #135
mrdsweet03
cincinnati oh
97 ford explorer xlt
Vehicle Specs
Quoted: 0 Post(s)
today i replaced two side servo's and the valve body tomorrow i will find out if it fix my first to second flare
mrdsweet03 is offline   Reply With Quote
Old 07-02-2009, 11:17 PM   #136
Pontisteve
Florida
03 Eddie Bauer 4WD V8
Vehicle Specs
Quoted: 11 Post(s)
Please everybody update us with your results!
Pontisteve is offline   Reply With Quote
Old 07-05-2009, 04:08 PM   #137
mrdsweet03
cincinnati oh
Vehicle Specs
Quoted: 0 Post(s)
today i filled the transmission took it for a test drive the same problem does not shift in to second gear right its a soft shift feels like it shifts again finelly to third i just dont know has to be something i did when i rebuilt it
Old 07-06-2009, 02:06 AM   #138
Pontisteve
Florida
Vehicle Specs
Quoted: 11 Post(s)
Did you put that repair kit they make in the servo bore? Adjust the bands?
Old 07-06-2009, 10:52 PM   #139
mrdsweet03
cincinnati oh
Vehicle Specs
Quoted: 0 Post(s)
the bore is perfect also has larger servo bands been adjust twice once i justed it od two turns out immediated two and a half turns no change i even turn it to two turns nothing happen the immediate cluches was brunt out two frooze together when i bought it now i believe i might have put the seal on the piston wrong
Old 07-06-2009, 10:58 PM   #140
mrdsweet03
cincinnati oh
Vehicle Specs
Quoted: 0 Post(s)
im sorry im wrong it was direct clutchs burnt together
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
