Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
A/C Works only on MAX-Air
Reply
Thread Tools
Old 05-14-2006, 07:56 PM   #1
Badspell68
NJ
97 XLT 5.0 AWD 4-Door
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hi all,
My AC only works on Max-air, any other setting it blows hot and when I turn the know with the blue and red I do not hear the baffle move anymore. It also blows hot on vent. I was told this could cost $600 to fix as the whole unit may be bad.
What do you guys think?
Ford Explorer XLT $door all wheel drive 1997
Badspell68 is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-14-2006, 07:59 PM   #2
Brans Freestyle
Northridge, CA
'01 Ranger 4x4
Vehicle Specs
Quoted: 1 Post(s)
try searching for "blend door" sounds like that's your problem.
Brans Freestyle is offline   Reply With Quote
Old 06-01-2006, 11:42 PM   #3
robert Milner
Sydney Australia
2000 limited
Vehicle Specs
Quoted: 0 Post(s)
I have a 2000 Limited with the same problem and was told $1000Aust . Blend door actuater has bolts holding it not the clips (how do you get it off) no room for spanners.
It will work on max only and cool air the rest of the settings. Does anyone know how to do a selftest on this climate control system.
robert Milner is offline   Reply With Quote
Old 06-02-2006, 09:35 AM   #4
Badspell68
NJ
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
FREE FIX for the AC problem
I found a simple and free fix for the AC problem posted on the net! All you need is a small nail, drill and some time. I'll look for the link again and post it.
Old 06-02-2006, 10:39 AM   #5
Badspell68
NJ
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Here is the link to the Free Fix
Here is the link to the Free Fix:
http://www.blenddoorfix.netfirms.com/
Old 08-21-2014, 03:11 PM   #6
Teddd
2006 Ranger
Vehicle Specs
Quoted: 0 Post(s)
A/C blows cold in max setting only.
I know this is a very old post but I recently had the same problem on a 2006 Ranger. After some troubleshooting, the problem was with the blend door actuator motor module. The actuator quit with the blend door being partially open which was blowing warm out of the vents when in the a/c mode. It did blow cold air though in the max mode. I simply changed out the actuator motor module by going through the glove box door and all is well now. Once the problem was found, it was a ten minute fix.
Ted Eaton.
Teddd is offline   Reply With Quote
Old 08-21-2014, 09:24 PM   #7
Badspell68
NJ
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
The motor on my explorer's blend door worked, but...I discovered the gearing attached to the motor was all plastic and it had disintegrated. I was told the whole unit needed to be pulled and replaced for $1,200. So, I fixed the problem for free.
Here is a link to the fix:
http://www.explorerforum.com/forums/...d.php?t=214163
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
