Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Street Truck & Performance Forums > Street Trucks
Notices
Street Trucks Do you have an Explorer Street Truck? Something setup for the road with handling more of a priority than ground clearance? This is the forum for you.
Rear end gear ratio?
Reply
Thread Tools
Old 03-07-2000, 10:29 AM   #1
k1ckb0x3r
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Question
How do you tell what gearing you have? I have a 98 Sport 4.0L SOHC, I think it has the towing package if that makes a difference.....
k1ckb0x3r is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-07-2000, 01:29 PM   #2
FMNavajo
Fairfield, CA.
92' Navajo
Vehicle Specs
Quoted: 0 Post(s)
Post
You should have a metal tag that's attached to one of the the rear differential cover bolts. This tag will show what size axle and what ratio you have installed, (example;8.8 3L73 would be an 8.8 inch Ford rearend with 3.73 ratio the "L" will mean it has a locker of some sorts). The only way it wouldn't be there is if someone already changed the gears and didn't replace the tag. If so, your going to have to open it up with someone that knows gears or start counting teeth!
Hope this helps,
FM
FMNavajo is offline   Reply With Quote
Old 03-07-2000, 08:14 PM   #3
V8Pete
Cupertino, CA
'06 XLT 2WD V8
Vehicle Specs
Quoted: 0 Post(s)
Post
The other way to check is to count the number of times the driveshaft rotates for each revolution of a rear wheel. If you have limited slip (both wheels turn in the same direction when you turn one of them by hand), count as per above and round off to nearest ratio. For instance, if you count approximately 3 3/4 driveshaft revolutions for each wheel revolution, you have 3.73s. If you get approx. 3 1/2 revs, 3.55s. 3 1/4 revs, 3.27.
If you DON'T have limited slip (wheels turn in opposite directions when you turn one by hand), then double the number of driveshaft revolutions, i.e. 1 3/4 revolutions x 2 = 3 1/2 revolutions, or 3.55s.
Hope this helps!
Pete
'96 XLT 2wd V8
K&N, drilled airbox
Flowmaster 50 series w/ 3" pipe
Explorer Express 1 1/2" lowering kit
Edelbrock IAS
Michelin 235/70 X-One
V8Pete is offline   Reply With Quote
Old 03-03-2008, 03:08 PM   #4
trj360
1999 XLT SOHC
Vehicle Specs
Quoted: 0 Post(s)
found these, hope it helps
http://www.explorerforum.com/forums/...d.php?t=197163
http://www.explorerforum.com/forums/...11&postcount=2
are you sure that's what your axle tag says?
trj360 is offline   Reply With Quote
Old 03-03-2008, 03:12 PM   #5
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
Quoted: 0 Post(s)
Post the axel code found on the driver's door and someone will give you the answer.
__________________
Al Franklin
My truck
My Quest for 30
RIP Al Franklin! 1947-2010. Gone but not forgotten! :(
aldive is offline   Reply With Quote
Old 04-03-2008, 09:19 AM   #6
madogsmike
West Mifflin, PA
'00 Sport
Vehicle Specs
Quoted: 0 Post(s)
any idea where i can get a cheap 4.10 diff? i saw it was optional from ford when it was made
madogsmike is offline   Reply With Quote
Old 04-06-2008, 02:31 PM   #7
01export
Brunswick, Maine
'01 Explorer Sport 4x4
Vehicle Specs
Quoted: 0 Post(s)
The plate on my rear axel says S614E73881F07 I think. My wife went and checked it for me b/c im in another country. I hope you guys can help.Thanks!-Erik
__________________
The roads gotta end sometime....
4in Superlift, 3in 01-03 Sport Trac BL, 2in TT, Warrior Shackles, 35x12.5x15in BFG MTs
01export is offline   Reply With Quote
Old 05-20-2008, 01:47 PM   #8
sav's trac
Jeanerette, Louisiana
01 XLT 4.0 SOHC 4X4
Vehicle Specs
Quoted: 0 Post(s)
wassup, quick question... i have a 01 sport trac with 33" tires and 18" rims and i want to get my tac meter back down a little. i no my tac is a little high b.c when i'm going about 60 mph. my rpm. is at 2,000. so i was looking into getting me some new gears. what yall think i should get?
__________________
O1 sport trac XLT 2WD
3'' fabtech suspension, 2'' TT, 33'' mudgrapplers on 18x9.5 incubus rims, and K&N cold air intake.
sav's trac is offline   Reply With Quote
Old 01-05-2009, 02:37 PM   #9
Togman
Va Beach
2000 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
Mine turns 2100rpm at 60mph with a 4.10 rear end.
__________________
2000 XLT 4x4
2005 XLT (Gone & glad it is-POS 3rd Generation):
1999 XLT --Gone, but was one great truck!
1992 XLT 4x4 - Gone, but was Unstoppable!
Togman is offline   Reply With Quote
Old 01-05-2009, 04:15 PM   #10
HahnsB2
Battle Ground WA
88 Bronco II
Vehicle Specs
Quoted: 0 Post(s)
Quote:
No it mean's it has a limited slip, a trac loc. A LS is NOT a locker in any way.
Quote:
You have 3.73s, the "3" was covered by the bolt.
__________________
88 Bronco II EB, 4.0L, M5OD, 4.56s, Aussie Locked 8.8, Aussie Locked D35 w/e-clip eliminator, Manual 1354, 3" PA Body Lift, 34x10.5 Swamper LTBs, Warn Hubs, U-Joint Drive shaft, OBA, Custom bumpers front/rear, 2 1/2" Exhaust w/flowmaster 40 series.
95 Dakota Sport CC, 5.2, 5-Spd(Hurst), 4x4, M1, HS 1.7 RR's, Aero Turbine 3030/Side Exit, 50mm TB, 30x9.50s on 15x8 Ultra 50 Series, 3.55s.
HahnsB2 is offline   Reply With Quote
Old 10-09-2010, 01:37 AM   #11
1Byounkin
Gallatin, TN
'91 4x4 XLT
Vehicle Specs
Quoted: 1 Post(s)
Quote:
I know my door tag has the stock axle code NO. I think It has the stock gearing. Also Stock tire size (235/75/R15). I run 3000rpms at 65mph. Could the gears been changed before I had it??? It is 4WD.
I might try the counting method to see what it is.
__________________
.:1991 Explorer XLT 4x4 Sliver / Black - Alabama Cylinder Heads - MOOG Bushings
- Screamin' Demon ~.065 Gap NGK - Flowmaster 40- Seal-4-Good Gaskets - 300,000 Miles and up:.
1Byounkin is offline   Reply With Quote
Old 10-09-2010, 05:36 AM   #12
MrQ
Take the Bull by the Horn
Stafford, TX
MrQ's Avatar
'98 Eddie Bauer
Vehicle Specs
Quoted: 22 Post(s)
The highest (lower numerically) the 4x4 ratios went were the 3.27's. A regular 2wd could go as high as a 3.08. I know my 3.73's turn about 2500rpm at 65 so its possible you have the 4.10's.
__________________
-Dan
"ROADS? Where we're going, we don't need roads."
Red Flyer II -1998 Explorer Eddie Bauer 4x4 (1.75" TT, 1" BL, WS w/ AAL, 33's, Spartan Locker, 5.0 V8, 4406M, 4.10's)
Copperhead -2012 RAM 1500 Express (SCSB, 5.7L Hemi, Tow Package, 4x2, Tequila Sunrise Metallic)
MrQ is offline   Reply With Quote
Old 10-09-2010, 09:02 PM   #13
1Byounkin
Gallatin, TN
'91 4x4 XLT
Vehicle Specs
Quoted: 1 Post(s)
Would this also tell me why my speed is five miles off on the speed. Compared to a gps and another car. If my gearing is 4.10 what can I do that would be an easy fix to run the right rpms.
__________________
Old 07-08-2012, 01:37 PM   #14
stack34
Canton,Texas
1991 ford explorer xlt
Vehicle Specs
Quoted: 0 Post(s)
i have a 1991 ford explorer xlt 2wd with a 4.0L v6 that i am going to build into a prerunner. right now i have 33/12.50/15 tires on it and want to put better gears and axles in it so they will turn better and the truck will run better but dont know what gears to put in or what i have. the tag on the diff cover says (S624B 08 88 0J12). anyone have any idea what this says and suggestions on gears and axles to run? i was thinking about 35 spline G2 axles and 4.56 gears? any good?
__________________
~stack 34~
stack34 is offline   Reply With Quote
Old 08-05-2012, 03:26 PM   #15
desertsky
Castle Rock, CO
'99 XLT 4X4
Vehicle Specs
Quoted: 0 Post(s)
S613E vs S614E
Per the title, what is the difference between these two? Both are 3.73 ratios and 8.8" gears. The tags are different as well.
The tage that was on the original:
S613E
3L73 88 8L16
The replacement rear end tag:
S614E
73 88 9B22
desertsky is offline   Reply With Quote
Old 08-05-2012, 04:39 PM   #16
snoranger
Jackson, NJ
snoranger's Avatar
94 limited on 35's
Vehicle Specs
Quoted: 68 Post(s)
S613E
3L73 88 8L16
S614E
73 88 9B22
Looks like your replacement rear is an open rear and the original was a LSD.
__________________
94 limited: 4.0l, 5spd swap, 6" skyjacker lift, 35x14.5 thornturds, 4.56s. 5.0 swap started (94 cobra 5.0, zf 5spd, np205)
95 xlt: stockish (SOHC swap, 30,000miles and I blew up the 3rd 4r55e...now collecting parts for a Cummins swap.)
Cummins 4BT swap thread
Ranger bed trailer build
snoranger is offline   Reply With Quote
Old 08-05-2012, 07:14 PM   #17
desertsky
Castle Rock, CO
'99 XLT 4X4
Vehicle Specs
Quoted: 0 Post(s)
Open? LSD? My rear end was on acid??? Oh well. Since 99% of my driving is on dry pavement it won't make much difference. The only reason I have 4WD is for the small amount of snow we get in Denver.
Old 08-05-2012, 08:48 PM   #18
snoranger
Jackson, NJ
snoranger's Avatar
94 limited on 35's
Vehicle Specs
Quoted: 68 Post(s)
Dont worry. As long as the ratios match, it will work.
__________________
Old 08-06-2012, 02:12 PM   #19
desertsky
Castle Rock, CO
'99 XLT 4X4
Vehicle Specs
Quoted: 0 Post(s)
thanks. The old one was getting noisy so I took it to a 4WD shop to have a look. They said that there was one inch of gear lube left in it and about 1 inch of metal shavings! $1500-1600 for a full overhaul with new gears, new clutches, new bearings and seals. I saved about $1200 and got a used one from teh wreakers off another '99 with 50k miles on it! One day to get the old one out and new one in. Good to go!
One thing I had to figure out was how to get the parking brake cable out of the connector under the frame (where the cable from the pedal meets the splitter). I found that there is a small hole in the connector that lines up with a hole in the frame. I poked a small screwdriver through both holes and grabbed the end with vice grips to keep it from falling out. Then used a screwdriver and hammer to drive the cable end out of the connector. It helps to unbolt the bracket from the frame to give you some slack to work with.
Old 10-01-2012, 06:32 PM   #20
pack_derik
gatlinburg tn
1998 ford explorer
Vehicle Specs
Quoted: 0 Post(s)
Dk Exp ford explorer
i have a 1998 ford explorer 4x4 4.0 v6 sohc need to find out the axle ratio is on the back. on the door it has axle D4 can someone tell me wut it is
pack_derik is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Black Ox Solid Axle Swap 1991 Randall Explorer/Ranger Solid Axle Swap Registry 36 03-04-2010 12:45 AM
95 Ex front and rear end, What's it worth? jeremy white Explorer - Ranger Shocks, Suspensions, Lift Kits 3 01-12-2003 02:37 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
