#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > New Members - Photo Gallery- Explorer Registries - Features - Reviews > New Member Introductions
Notices
New Member Introductions The place for new members to introduce themselves to our family of Ford Explorer enthusiasts Welcome aboard!!
freeze plugs fell into water jacket
Reply
Thread Tools
Old 06-21-2006, 03:26 PM   #1
cashark
rogers,ar.
1996 xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I did something bad, hears the reader digest virsion,..I was replacing a freeze plug that fell out of my explorer (1996 4.0 engine) I never done this before butt i looked easy enough, it took me three trys to get it in, my problem is the first two fell into the water jacket of the block. ( i know stupid!) is their any way to get them out? my explorer run for a while ( few weeks) then overheated ... I was told i cracked the heads or head gaskets. I used some " steel seal" which i bought online for the cracked head or gaskets which seemed to work just fine, but now it overheats right away and coolant does not seem to be flowing. I removed the t-stat to see if coolant was flowing in the rad. but it just comes out the top of the cap. could these freeze plugs that i dropped into the water jacket be blocking the flow?
cashark is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-21-2006, 11:28 PM   #2
old mechanic
R.I.
92 xlt
Vehicle Specs
Quoted: 0 Post(s)
Anything is possible but there are probably millions of vehicles riding around with freeze plugs inside their blocks.
old mechanic is offline   Reply With Quote
Old 06-22-2006, 10:05 PM   #3
cashark
rogers,ar.
1996 xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
That's what I was thinking (that I wasn't alone in dropping a few in the water jacket) I'm still having problems with overheating, I've flashed the rad. and I dissconnected both rad. hoses then I ran water through the upper hose and it run out the lower. I ran water through the top of block where the t-stat is and water ran out the lower hose. But when I tried to run water through the lower hose it seem to be blocked? water just ran out of it (lower hose) My next questions are can a water pump block the flow of coolant going into the engine? And can a water pump go out without any leakage from the weep hole? the fan turns normal so should'nt the inside of pump turn and push the coolant through? or can the inside stop pushing the collant even if the fan is turning?
Old 06-25-2006, 10:00 PM   #4
old mechanic
R.I.
92 xlt
Vehicle Specs
Quoted: 0 Post(s)
Quote:
You need to check the usual problems first like bad thermostat (put the thermostst in a pan of HOT water and see if it opens up), fan belt slipping, bad hoses, pluged radiator, bad water pump,
I have seen many times that when everything seems to be ok, the lower hose usually, but the upper sometimes, will be weak and as you drive it will close up and you will overheat.
As for the water pump, usually it will leak out the bottom hole when it goes. The only thing that really goes on a water pump is the bearing.
Disconnect the negative battery cable, grab the fan blades top and bottom and rock back and forth, if it moves your bearing is gone.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
