97 AWD front u-joint ? | Ford Explorer Forums
Dan Whitaker
One fast putty tat
Raytown MO (Kansas City suburb)
No Mounty no more.
I did a search bit did not find the answer I need.
I need to replace all the u-joints on my 97 AWD Mountaineer.
The thing that has me stumped is where the front drive shaft connects to the transfer case.
It is not a u-joint or cardane(sp) type. It has a flange around the outside & looks to be more like a CV joint.
I have not called any parts stores yet but was looking on their web sites & did not see this listed. All I saw was a regular type u-joint for 4wd which called out one u-joint for the front shaft where it connects to the front diff but nothing listed for AWD or 4wd where it connects to the transfer case :confused:
Yes, it's essentially a CV joint. No, there is no u-joint on that end of the driveshaft.
AFAIK, it's a 'better design' for 97 that disappeared in 98.
So is the CV one replacable or do I just replace the three standard u-joints?
The 98's have the same front driveshaft - I put a 98' front driveshaft (mine) in a '97 (my brother's).
The CV is not replaceable
i could sell you my double carden for 50 bucks :D
Thank You IZWACK.
So does the CV end have a splined shaft that I just slide out or do I have to remove the flange from the T-case?
the CV end of the front driveshaft (the end thats closest to the trasnfer case) is bolted to the transfer case's front output flange/"cup" by I think 9 or so small but very long bolts. just unscrew these bolts and the CV end should pull out (it may require a little tug).
Thank You again IZWACK.
That's what air ratchets are for :D :D :D
I am going through that with mine right now. A driveshaft shop could not even rebuild the stock unit. They would have to make me a custom unit to replace it, and that was more expensive than buying a shaft through Napa.
