How to install Sonnax crankshaft spacer? | Ford Explorer Forums
saxon
seattle, wa
'91 & '93 EB, 4WD, 4-door
Does this part fit in the center of the flywheel (flexplate)? (between the crank and a 1993 A4LD; 6-hole crankshaft).
Should I take this to a machine shop to be pressed out and the new Sonnax one pressed in? The Sonnax (2nd) link below claims that it is a simple drop in replacement but when I removed the flywheel last Tuesday, no parts were such that they could be "dropped" in. Tap it out with a hammer? Am I even talking about the correct part?
http://www.transmissionspecialty.com/parts/parts/56000-CS6.htm
http://www.transmissionpartsusa.com/ProductDetails.asp?ProductCode=400-056000CS6&CartID=2
I didn't see you post anything in a while. How have you been? There is nothing special about connecting these spacers. They are a direct bolt on part. You could see from the picture below that it has the same amount of holes as the flywheel:
They can get rather wedged into the flywheel sometimes. A BFH or a press can be useful. Support the flywheel well around the spacer so you do not bend it.
