| Bronco II Our Ford Bronco II forum covers maintenance, problem solving, 4x4 issues, and all topics regarding the 1984 - 1990 Ford Bronco II. |
Thread Tools |
#221 |
Wannabe Elite Explorer
Windsor NS
95 XLT
So im going to start on my D35 this weekend, (if it does not rain)
I know you have told me I can use my D-shaft, but on a different site its telling me to cut the d-shaft to make it fit. IS this because they used the ex d-shaft? Also will the Drive Shaft from my D28 just slide into the D35? __________________ Rectum, Damn Near Killed Em! 1994 XLT |
#222 |
ELITE BRONCO2ERER
Crawlorado
B2 Mod
the dana 28 driveshaft should fit the Dana 35 TTB possibly with a hybrid u joint
When I did mine I used an explorer style shaft because I also have an explorer transfer case (the 1354 t case has a different front output yoke then the 1350 like yours) __________________ 96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's 88 BII 5.0L conversion - BII 5.0l drivetrain thread My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates Wifes 07 FJ build - 2007 FJ cruiser locked and lifted |
#223 |
Windsor NS
95 XLT
okay I found a hybrid u-joint at lordco, I am going to go check it out today. Now I know the shock mounts are different on the D35 radius arms, my shocks are shot as it is now, so if I buy some new shocks for a D35 rather than the D28 will I need to still change the shock mount on the D35?
#224 |
ELITE BRONCO2ERER
Crawlorado
B2 Mod
what makes you say they are different?
I installed a 3" lift kit when I went dana 35 so I used new shocks for the lift, but I dont think the shocks are different from dana 28 to dana 35? the coil bucket is the same not sure about the shock mount on the radius arm, but your dana 28 shocks should fit. __________________ 96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's 88 BII 5.0L conversion - BII 5.0l drivetrain thread My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates Wifes 07 FJ build - 2007 FJ cruiser locked and lifted |
#225 |
Windsor NS
95 XLT
aaahhh n/m I was reading it wrong, its the radius arm stud, but I will be using the D35 RA's.
this is what I found about the d-shaft "Special Fabrication! - You'll need to shorten the front drive shaft about 1 to 1-1/2 inches. This will require a reputable driveline shop." But does not say if he used a ex d-shaft or not. This was in a Ranger V8 aswell.... __________________ Rectum, Damn Near Killed Em! 1994 XLT |
#226 |
ELITE BRONCO2ERER
Crawlorado
B2 Mod
ranger v8 is completely different
#227 |
Windsor NS
95 XLT
Strangest thing happened today. When I turn my truck off, the relay clicks for around 5 to 10 seconds, and while it does that my fuel pump on the frame rail is running. ( I can hear it) Than it just stops when the relay stops. One time it would not start so I connected it myself with a screwdriver and it started. So I go get a new relay and put it in and it does the same thing. Any ideas what that could be?
#228 |
ELITE BRONCO2ERER
Crawlorado
B2 Mod
the signal to the relay is controlled by the computer, if the computer is powering up the pumps when the truck is off I would guess this is a computer issue, UNLESS your key switch is bad, meaning even though the key is off the computer is being told its still on. There is a relay in the keyswitch (column) that controls this
#229 |
Windsor NS
95 XLT
I took the battery cables off to put my new relay in and when I hooked up the cables back on to the battery it set off the relay. This was with out keys in the truck at all! So would that rule out the keyswitch relay?
#230 |
ELITE BRONCO2ERER
Crawlorado
B2 Mod
hmmmm when you hook up the new battery you may hear a relay click, but the fuel pumps should not run.
#231 |
Windsor NS
95 XLT
yeah its not a relay click, its many clicks. it goes on for around 5 to 10 seconds. One time the truck would not start, and I had to bridge the connection with a screw driver... Thats why I went and got a new Relay, I was thinking there was just a problem with the relay.
#232 |
Moderator
Huntington Beach, CA
Not necessarily. Mine can turn just enough for the door ding to go on with no keys.
__________________ COLIN IGNACIO FORUM RULES My 2010 Explorer - Explorer #1 (sold) - Explorer #2 (sold) - My F-150 (sold) - My Ranger (sold) - My Videos |
#233 |
Windsor NS
95 XLT
okay great, HUGE snowstorm, I am coming home from work, truck dies out....................... AGIAN! hahahaha, so I left it there, it now has two tickets. Getting it towed home right now, 3rd tow in 2 weeks.... Decided to get a new truck, but I am keeping this POS and working on it and only using it as a trail rig. Not somthing that needs to be towed to go in a trail but somthing I can slap a weekend pass on when I want to go out.
#234 |
Windsor NS
95 XLT
What are some things I can do to my truck now that it is off the road. Things I can take off that made it street legal. Keep in mind I will be driving it to places on the road when I go wheelin. I can get a day permit or weekend etc...
Only thing I know to do is take off the cats. __________________ Rectum, Damn Near Killed Em! 1994 XLT |
#235 |
Lima, Ohio
'97 mounty 5.0 4x4 baby!!
Hey. I was in Surrey yesterday. You guys got soo much more snow and ice than vancouver. I was out around drifting in my friends yota all night.
__________________ 1997 Mercury Mountaineer 4x4 V8 ![]() 3" bl, manual t-case. Dana 60/14 bolt combo with 36x13.5x17 iroks on H2 rims. 5.13's. Future plan: 3.9 or 5.9 Turbo diesel cummins |
#236 | |
Windsor NS
95 XLT
#237 |
Martinsburg WV
84 BII "Li'l Samson"
My original B11 DS 84 with a 1350 transfer and using a 94 Ex. TTB35 it was a straight bolt in with no driveshaft mods. This is with a 302 also.
__________________ "2012 & 2011Truck Nationals" At Carlisle Extreme 4x4" First Place winner. "2012 &2011 All Ford Nationals" At Carlisle First place winner Bronco Trail Truck Featured in 2012 Bronco Driver Mag. Petersen's 4Wheel mag ROTM. Voted 2008 Bronco II of Year |
#238 |
Windsor NS
95 XLT
First thing I am going to try is replacing the computer.... See if that helps any.
Now when I go looking for one of these, what type of range can I go with the years? ranger? 2wd or 4wd? do these things matter. I assume it does but good to know it it does not matter as much. I am going to be doing the D35 swap as soon as the snow is gone... its BC so it will rain soon enuff and take it all away. Its been 50/50 with people telling me about the D-shaft either being cut 1 - 1.5" or not needing anything... __________________ Rectum, Damn Near Killed Em! 1994 XLT |
#239 |
ELITE BRONCO2ERER
Crawlorado
B2 Mod
You are talking about a 4.0L donor?
93 is my favorite year of the OHV 4.0L because it has two 02 sensors, updated heads, NO EGR, and no CAM sensor. You can use 91-94 to make your swap easier (basically identical to your 2.9L layout and size wise under the hood) the OHV 4.0L was used from 89-2001, so any year block will work The 91-94 computer is the one that will make your swap easier If you plan to get a transmission with your new 4.0L then yes 2wd or 4x4 does matter __________________ 96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's 88 BII 5.0L conversion - BII 5.0l drivetrain thread My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates Wifes 07 FJ build - 2007 FJ cruiser locked and lifted |
#240 |
Windsor NS
95 XLT
hahaha nah not for a 4.0L swap. I still have my 2.9L in the truck. I am going to get gears before 4.0L.... So with that said, I was talking about a 2.9L computer in my 88BII now
| Thread Tools | |
