Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer Audio & Navigation
Notices
Explorer Audio & Navigation Audio and navigation systems. CD, DVD, MP3, GPS, Video, Mobile Computer, Speakers, Amplifiers.
Installed an Alpine head unit, But getting turn 0n thump from factyory subamp??
Reply
Thread Tools
Old 08-20-2006, 08:46 AM   #1
New Ford Guy
Moncton, New Brunswick, Canada
2003 Eddie Bauier
Vehicle Specs
(Original Poster)
Dk Exp Installed an Alpine head unit, But getting turn 0n thump from factyory subamp??
Hi Members, I installed a Alpine 9835 head unit in my 2003 Eddie Bauier with the proper Metra wiring harness with the factory sub input. But i'm getting turn on thump from the factory subwoofer amp. It Only thumps when turned ON not when turned off. I tried manually delaying the amp turn on with the blue amp turn on wire....we still had the THUMP?? So I unplugged the RCA's from the head unit to the subwoofer connection(to check for ground loop)...we still had Thump?? Anybody else had this problem? Anybody have a Solution?
I Have the Audiophile factory system with factory Sub.(only the sub has the factory Amp). I just need to get rid of the THUMP !!!
Thanks in advance...New Ford Guy
New Ford Guy is offline   Reply With Quote
Old 08-20-2006, 10:07 AM   #2
snocross1985
Explorer-less
South Hampton, NH
snocross1985's Avatar
2002 Sentra SE-R Spec V
Vehicle Specs
I used to have the same problem when I had my old system in my truck, have no idea what caused it. Gonna be putting a new system in my truck and am curious as to what causes the turn on thump.
__________________
Scott
My Mug
snocross1985 is offline   Reply With Quote
Old 08-20-2006, 12:26 PM   #3
New Ford Guy
2003 Eddie Bauier
Vehicle Specs
(Original Poster)
Anybody have any answers????
Old 08-20-2006, 01:20 PM   #4
Brandons
Ontario, Canada
Brandons's Avatar
06 F150 SC 5.4
Vehicle Specs
I dont think its anything to be concerned about, start a computer on with the speakers on and you usually get a thump. Might just be from turning on, first bit of power that goes to it, did you try turning it on without the head unit on and see if it still thumps?
__________________
2006 F150 XLT Supercrew 5.4L
1994 XLT 4.0L
1997 XL 4.0L
Brandons is offline   Reply With Quote
Old 08-20-2006, 05:03 PM   #5
DOZIER
Fultondale, Alabama
DOZIER's Avatar
2001 explorer sport
Vehicle Specs
I had the problem along time ago and I was told that the preamptive outputs were bad in my head unit. I replaced the head unit and problem solved.
__________________
If you can't convince them...Confuse them.
DOZIER is offline   Reply With Quote
Old 08-20-2006, 07:56 PM   #6
nvrenufedge
Boise, ID
'05 XLT
Vehicle Specs
If you've already tried unplugging the RCA's, the only thing I can come up with is there is something wrong with the amp.
__________________
The Family Hauler
Alpine INA-W900 w/navigation
Yakima hitch-mount bike rack
More to come....
nvrenufedge is offline   Reply With Quote
Old 08-20-2006, 10:13 PM   #7
ajr2000
Trumbull, CT
ajr2000's Avatar
93 XLT
Vehicle Specs
In pro audio, the thump, or in the case of pro-audio, pop, is caused by the amp being on before the audio source, in this case the headunit.
In this case I would say your amp is screwed up however.
__________________
-Andy
93 Ford Explorer XLT, 4.0L OHV - Conical filter intake, custom intake tube, BBK 66mm Throttle body, Flowmaster 40 delta exhaust, Aluminum dash bezel, All Jensen sound system, throttle cable mod, Clear Corners
My Cardomain
ajr2000 is offline   Reply With Quote
Old 08-20-2006, 10:15 PM   #8
Brandons
Ontario, Canada
Brandons's Avatar
06 F150 SC 5.4
Vehicle Specs
Id be curious to know if it happens to thump if you just turn the amp on manually (jump the amp on wire?).
__________________
1994 XLT 4.0L
1997 XL 4.0L
Old 08-21-2006, 05:56 PM   #9
davesexplorer
Central PA
davesexplorer's Avatar
2001 F350 7.3
Vehicle Specs
I'd venture a guess that it comes from the "meshing" of sorts between the aftermarket head unit giving the factory amp turn on power, whilst the factory amp is already turned on on. The remote signal delay from the Alpine would be fine for aftermarket amps designed for it, but if what im thinkin is happening is that the factory amp is on before that.
__________________
2001 F350 Extended Cab Long Bed Lariat 7.3 Powerstroke 4x4
1999 Mustang GT 5spd vert
davesexplorer is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
