Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Offroad Tech Forums > Offroad Explorer - Ranger Projects
Notices
Offroad Explorer - Ranger Projects Big projects... Lifts, Swaps, etc... IMPORTANT As the subject use your name, or the name of your truck, and the name of the project. Such as Superlift 5.5" installation, Dana 44 conversion, etc.
Lifeguard's sas.
Reply
Thread Tools
Old 01-10-2007, 01:48 AM   #81
lifeguard379
sacremento,ca
lifeguard379's Avatar
93 eddie bauer 2 door
Vehicle Specs
(Original Poster)
Thanks guys. i never thought of looking on there lol.
__________________
93 2 door eddy Bauer HP44 and Big bearing 9 and 4.88 My elite registry
http://www.explorerforum.com/forums/...d.php?t=153392
sas thread
http://www.explorerforum.com/forums/...d.php?t=165147
sas registry
http://www.explorerforum.com/forums/...d.php?t=244780
lifeguard379 is offline   Reply With Quote
Old 01-31-2007, 07:44 PM   #82
lifeguard379
sacremento,ca
Vehicle Specs
(Original Poster)
Ok. small update. on friday i will be picking up a hp dana 44 and 9" dont think ima use the 9" tho. but they come as a pair so get it to. will have pics on friday
__________________
sas thread
sas registry
Old 02-03-2007, 07:17 PM   #83
lifeguard379
sacremento,ca
Vehicle Specs
(Original Poster)
ok ther hear. my new axles. HP Dana 44 and a big bearing 9" what do you think?
__________________
sas thread
sas registry
Old 02-03-2007, 07:26 PM   #84
zainyD
Lakeland, FL
zainyD's Avatar
'96 Ranger 4x4 XLT
Vehicle Specs
It's a good start.
__________________
'96 Ranger 4x4 XLT with some stuff....and more to come when I actually have some money
zainyD is offline   Reply With Quote
Old 02-03-2007, 08:19 PM   #85
Savage Wolf
Mount Airy, Maryland
'93 Sport v8 5.0
Vehicle Specs
Nice, looks like a 78-79' F-150 HP D44 and 9" same axle I am using (cept mine is narrowed) as for steering ya may wanna check out the route I am going with mine (and pretty sure a few others have done the same steer setup already as well) well soon as my tube inserts show up but at the least I have a write up on which TRE's to use
__________________
~Wolf
2012 F550 Tux Black Lariat Supercab 186" WB , 4x4 6.7, 19.5GVW
'98 Ranger XLT ExCab 4x2 2.5L "Pimped out shop beater"
'93 Explorer Sport - 5.0L v8, 4R70W trans, Atlas II 3.8:1, D44 SAS, 2" body lift, 33x12.50x15
Savage Wolf is offline   Reply With Quote
Old 02-04-2007, 04:18 PM   #86
lifeguard379
sacremento,ca
Vehicle Specs
(Original Poster)
can any one school me on the 9" the guy said it has 30 spline axles stock but i thought they where all 28 spline? and how are people getting drive shafts to work? do i need a new one or dose the 8.8 flange fit on the 9" pinion? thanks
__________________
sas thread
sas registry
Old 02-04-2007, 08:42 PM   #87
zainyD
Lakeland, FL
zainyD's Avatar
'96 Ranger 4x4 XLT
Vehicle Specs
You'll need to get a different driveshaft built. If the 9" is from the same vehicle as the D44 it should have 31 spline axles and it is the big bearing variety.
__________________
Old 02-04-2007, 09:45 PM   #88
bmxking5
Rollover Posse Member
Monroe, GA
bmxking5's Avatar
'93 Sport & '96 XLT
Vehicle Specs
Depending with the yoke that is on it, it might work. Mine had a 1310 yoke (uses same u-joint as stock 8.8 Explorer), so I just had to pull off the u-joint flange adapter. Since I had so much lift, I also had to have it extended. Measure the yoke and see if yours will work. If not, you can either have a new end put on it when you get it lengthened or put in a conversion/bastard u-joint.
__________________
Weekend Toy: '93 Explorer 2dr - Full-width D44/9" swap, disc f/r, 37" Nittos, 4.88s locked rear, hi steer
'96 Explorer 5.0 - Lifted, Magnaflow, Mac, TMH, 33s, TOTALLED!!
New DD: '01 F150 Supercrew 4x4 - Magnaflow Hi-Flow cats & Muffler, powdercoated FX4 wheels, leveling kit
bmxking5 is offline   Reply With Quote
Old 02-05-2007, 08:16 PM   #89
lifeguard379
sacremento,ca
Vehicle Specs
(Original Poster)
thanks for the input. think a 4 door drive shaft will be long enough?
__________________
sas thread
sas registry
Old 02-05-2007, 08:22 PM   #90
Mud Bug 94
Bloomingdale, N J
Mud Bug 94's Avatar
94 XLT-367k miles
Vehicle Specs
how long is urs now?
__________________
94 xlt 4 door, 32's 4 inch shackles and custom tube bumpers with tire carrier
Mud Bug 94 is offline   Reply With Quote
Old 02-05-2007, 09:24 PM   #91
lifeguard379
sacremento,ca
Vehicle Specs
(Original Poster)
right now its the stock 2 door one, but with the soa it has about an inch of slip left, and i plan on putting the aal's back in. so it will be to short.
__________________
sas thread
sas registry
Old 02-05-2007, 09:26 PM   #92
Burns
EF Late Night Crew
Memphis, TN
Burns's Avatar
1991 Explorer/2002 F-250
Vehicle Specs
If i am correct i had to have my drive shaft out of my 4dr extended 3.5 to 4 inches....
__________________
Jonathan Burns
Moderator of the Feature Truck Forum
Owner of the "Lime"
Forum Rules and Usage
Burns is offline   Reply With Quote
Old 02-05-2007, 09:32 PM   #93
Mud Bug 94
Bloomingdale, N J
Mud Bug 94's Avatar
94 XLT-367k miles
Vehicle Specs
Wouldnt even drive it with an inch left of slip yoke thats just asking to play FROGER.... i think a stock 4dr would be just right or very close.Try making one i made mine 7 inches lnger with a 1 ton bottom yoke and its .25 inch wall gas pipe
__________________
Old 02-12-2007, 09:08 PM   #94
lifeguard379
sacremento,ca
Vehicle Specs
(Original Poster)
Angry well my ex was totaled today
came out to go to work, and found it was broken in to. stole the head unit sub and amp. but it now needs a new dash, driver door, lock, interior trim and more. i am going to buy it back and us the left over to finish the sas
hear are some pics
="Photobucket - Video and Image Hosting"></a>
__________________
sas thread
sas registry
Old 02-12-2007, 09:16 PM   #95
IZwack
Germantown, MD
IZwack's Avatar
Vehicle Specs
aww man so sorry to hear that -- those bastards
__________________
»»»»»...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 02-12-2007, 09:21 PM   #96
Burns
EF Late Night Crew
Memphis, TN
Burns's Avatar
Vehicle Specs
That stinks
__________________
Jonathan Burns
Owner of the "Lime"
Old 02-12-2007, 09:26 PM   #97
SkanlaxJMO
Syracuse, New York
96 XLT
Vehicle Specs
that sucks man
__________________
2005 F-150
SkanlaxJMO is offline   Reply With Quote
Old 02-12-2007, 09:50 PM   #98
lifeguard379
sacremento,ca
Vehicle Specs
(Original Poster)
ya. there is close to 3k in damage. depending on what the buy back is i might come out a head. still a hassle tho.
__________________
sas thread
sas registry
Old 02-12-2007, 11:33 PM   #99
'97 V8
Lima, Ohio
'97 V8's Avatar
'97 mounty 5.0 4x4 baby!!
Vehicle Specs
that is of the homosexual.
__________________
1997 Mercury Mountaineer 4x4 V8
3" bl, manual t-case.
Dana 60/14 bolt combo with 36x13.5x17 iroks on H2 rims. 5.13's.
Future plan: 3.9 or 5.9 Turbo diesel cummins
'97 V8 is offline   Reply With Quote
Old 02-20-2007, 06:42 PM   #100
lifeguard379
sacremento,ca
Vehicle Specs
(Original Poster)
ok well i should be getting my check soon and will be using it to finish the swap. my new plan is to run 37's and 5.13's but my buddy's think that 5.13 is to much for a car that is still my dd. any input on this?
for coils I think I'm going with the cage 5.5, and i want to extend the ra's
Think the 2" aal will level it out?
thanks for any input.
__________________
sas thread
sas registry
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
