Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Outer Tie Rod Ends?
Reply
Thread Tools
Old 08-21-2006, 07:28 PM   #1
Lazzman
Massachusetts
1998 Sport 4wd- V6 Sohc
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
Outer Tie Rod Ends?
Before I install the Moog outer Tie Rod ends on my Explorer does anyone know what the torque specs are for the Castle nuts?
Also how much grease should be pumped in? I have a standard lever action grease gun and am worried that I might break the seal if I pump in to much. Is there an easy way to do this?
Thanks for any help or advice.
__________________
1998 Sport, 4x4, K&N Filter, E3 Diamond Fire Plugs, Magnecore 8mm Wires, Screamin Demon Coil, 2.5" Flowmaster Catback, 255/70/16 tires, Performance 5R55E VB, Royal Purple synthetic lubricants, Zabteck breather bypass, 4.10 gears, Warrior Shackles, EBC Brakes.
Lazzman is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-21-2006, 07:46 PM   #2
ncc
Manchester, NH
ncc's Avatar
'97 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
I've never really used a torque wrench for tie-rod ends. Using a torque wrench could leave the nut in a position where the cotter-pin hole is inaccessible. Then you'd have to back off the nut to line up the hole which would make the torqued value irrelevant.
It's more a matter of getting a good tight fit on the nut and then lining up the castellations with the cotter-pin hole.
As far as the grease goes, just give it a few good pumps. You'll know when you've got enough as a fine line of grease will begin oozing out of the joint. That's when you stop.
Good luck!
Jeremy
'97 Eddie Bauer 4.0L SOHC
ncc is offline   Reply With Quote
Old 08-21-2006, 08:27 PM   #3
Homerexplorer
Upstate NY
99 XLT 4WD
Vehicle Specs
Quoted: 0 Post(s)
45-60 ft-lbs
Homerexplorer is offline   Reply With Quote
Old 08-21-2006, 08:32 PM   #4
UtahX
Grand Junction, Colorado
2000 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
I thought you said you were going to sell this truck. If so, why all the work into it?
__________________
2000 XLT 4.0 SOHC 4x4 (Oxford White), 5R55E, 3.73
MODS: 31" BFG AT/KOs, SilverStars, Diamond Clear's, Rancho RS5000, Cragar 15x8 Soft 8, MagnaFlow (2.5" Pipe), K&N FIPK II, Trans Cooler (Stock), PowerSlot, Hawk Performance Ceramic, Yellow Top
My X
UtahX is offline   Reply With Quote
Old 08-21-2006, 11:42 PM   #5
Lazzman
Massachusetts
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
Nah, I love this truck. I get frustrated sometimes but it is still my boy. Can't beat it, change something or fix something and its as good as new.
Thanks for all the excellent replies.
__________________
Old 08-22-2006, 08:02 AM   #6
UtahX
2000 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
Glad to hear you are keeping it.
__________________
My X
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
