transfer case motor & possable transfer case swap
I have a 98 explorer & both 4wd high & low flash, & the transfer case wont shift out of 4wd low. I read that there is a 4wd fuse, could this be the problem & where is the fuse located.
I dismounted the transfer case shift motor & had my wife move the shift lever switch with the vehicle running in park & I didn't have any movement from the shift motor.
Until I get a new shift motor I plan to disconnect the front driveline & set the transfer case manually into 4wd high.
There is two sensor's at the back of transfer case that I will probably replace also, but my main concern about them is that the wiring for them is also part of the wiring connection for the transfer case shift motor.
How does one separate the wiring?
Can a 2wd/4wd high/4wd low transfer case from a Ranger work with the current wiring in a explorer being as my explorer has the Auto/4wd high/4wd low?
Thanks in advance for the replies
