Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Projects - Hobbies and Additional Topics > Projects - Hobbies - DIY > Tools and Garage
Notices
Tools and Garage A forum to discuss tools and shop setup.
New Garage in Process (pics inside)
Reply
Thread Tools
Old 09-18-2006, 11:26 PM   #21
old mechanic
R.I.
92 xlt
Vehicle Specs
Quote:
Originally Posted by KillerB74
Warm!! HAHA. I am up in Saskatchewan! We get winter from October to May sometimes with weeks of -30 and often down to -40 or colder for several days. The code here does not require a grade beam for a dettached garage. Only if it was attached to the house would we have to dig it down with pilings.
And the frost won't lift it? Better than the BULL$HIT we have to do here for a very rare -1 degree day.
I'm thinking that maybe your ground is frozen enough all the time so it does not thaw and lift the cement up and down?
__________________
1992 Explorer 155HP-220TQ-ON AIR & GAS.
PENTIUM-D 930- 3.0Ghz O/CLOCKED TO 4.0Ghz ON AIR.
old mechanic is offline   Reply With Quote
Old 09-18-2006, 11:27 PM   #22
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Many years ago, in late 1991 to early 1992 to be a little more exact, I had a job in upstate NY that used all of this kind of stuff. Now I don't see this kind of material locally used too much. I don't know if it is still being used in upstate NY. Plywood, and steel beams, with steel joists are much more common. They still make furniture, kitchen, and bathroom cabinets out of particle board. They have very strict fire codes now, so steel joists are more common. You could still buy 2X4, and 2X3 wood. They also sell interlocking waferboard floor boards, and prefinished particle board shelving.
BrooklynBay is offline   Reply With Quote
Old 09-19-2006, 12:07 AM   #23
old mechanic
R.I.
92 xlt
Vehicle Specs
Quote:
Originally Posted by RockRanger
Not to get to off topic but why do you ask about the use of OSB? It is pretty standard out here in cali to use this stuff instead of plywood. Just wondering if you dont use back east. Is it becase it expands more when wet or? Just kind of curius is all.
I 'm a contractor and I live in N England and its common to see other products besides plywood being used. The metal buildings have been around for years. One of the first to produce them was Butler. Funny, 40? years later most of us still call them Butler buildings. Kinda like when Oldsmobile came out with the auto transmission they called it Hydromatic and for a long time people called all automatics Hydromatics.
__________________
Old 09-19-2006, 08:53 AM   #24
KillerB74
Saskatoon, Saskatchewan
KillerB74's Avatar
'92 XLT
Vehicle Specs
(Original Poster)
Quote:
Originally Posted by BrooklynBay
I see that you used waferboard, not plywood, and wood beams, not steel beams. Are there different codes for building with certain materials? Are you going to cover it with roofing paper, and siding, or styrofaom sheeting, and stucco? Is it going to have a flat roof, or a sloped, pitched roof?
Wood is a very typical building material here. Way cheaper than steel and less thermal bridging to the interior when we hit those -40 temps. My OH door header is a purpose built wood laminated beam specifically for this application as the door is in the supporting wall.
The roof will be a sloped roof, with roofing paper and 25 year ashphalt shingles. The walls will be wraped in a building wrap and then vinyl siding installed.
__________________
1992 XLT, 5sp
AAL, F-150 Spacers, custom built shackles, 3" Body Lift, Lock-Rite in front axle, 31x10.5 Cooper AT3's
2007 EB, 4.6L V8
K&N CAI with Amsoil filter, Flowmaster 70 Series, Steeda Under Drive Pulley, Henson Performance Tune
KillerB74 is offline   Reply With Quote
Old 09-19-2006, 05:42 PM   #25
RockRanger
Elite Ranger
Fresno CA
RockRanger's Avatar
86 ranger no more
Vehicle Specs
Why just one window? Seems like a good time to add a few more to add some more natural light. I am jelous you will have a nice place to work in.
__________________
93 ranger rock stock.
RockRanger is offline   Reply With Quote
Old 09-19-2006, 10:51 PM   #26
KillerB74
KillerB74's Avatar
'92 XLT
Vehicle Specs
(Original Poster)
I have mixed feelings about windows. The natural light would be great, but they also create more break and enter points. Also, insulated walls hold the heat better at -40 and in the winter it gets dark at 4:30pm!
The roof is now on! All the neighbors are stopping by to admire the size of it. Most them have smaller attached garages and all ask why I would want to have a 10' wall with an 8' door. I tell them there will be more room for a lifted vehicle to go in and out of!
__________________
1992 XLT, 5sp
2007 EB, 4.6L V8
Old 09-19-2006, 10:57 PM   #27
BrooklynBay
Brooklyn, NY
Vehicle Specs
You might want to consider glass blocks as an alternative to windows. They are more secure, and better insulated.
Old 09-20-2006, 05:23 AM   #28
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
Are you installing an alarm system in the new garage?
In mine, I have CO2, smoke, and heat detectors as well as bugged all entry points.
__________________
Al Franklin
My truck
My Quest for 30
RIP Al Franklin! 1947-2010. Gone but not forgotten! :(
aldive is offline   Reply With Quote
Old 09-20-2006, 09:22 AM   #29
BrooklynBay
Brooklyn, NY
Vehicle Specs
You could always install a steel gate in front of the window.
Old 09-20-2006, 12:16 PM   #30
KillerB74
KillerB74's Avatar
'92 XLT
Vehicle Specs
(Original Poster)
After the window talk I have decided to upgrade the door with a row windows. You guys are correct, you can never have too much light. I am getting a full row of windows in one panel (6 windows). That adds about $500 to the price of the door . Oh well its only the banks money
__________________
1992 XLT, 5sp
2007 EB, 4.6L V8
Old 09-25-2006, 11:12 PM   #31
KillerB74
KillerB74's Avatar
'92 XLT
Vehicle Specs
(Original Poster)
Updated with new pictures, please see the first post for the on going construction story!
__________________
1992 XLT, 5sp
2007 EB, 4.6L V8
Old 09-26-2006, 04:38 PM   #32
rookieshooter
Martinsburg WV
rookieshooter's Avatar
84 BII "Li'l Samson"
Vehicle Specs
Cut a door in that side of the house that faces the side of garage. Then a door in the garage directly in front of living room door. I assume it's your living room. Then it's only one step and your in your garage. Wife may not like it though. LOL Easy to get in garage on those super cold and snowy days. Then again that breezway might be drifted with snow.
Brooklyn, that type construction seems to me is just your basic meat and potatoes garage. Only thing I question is the no footings. Seems thawing and freezing could cause that slab to crack. But there is a lot of re-bar in that slab.
__________________
"2012 & 2011Truck Nationals" At Carlisle Extreme 4x4" First Place winner.
"2012 &2011 All Ford Nationals" At Carlisle First place winner Bronco Trail Truck
Featured in 2012 Bronco Driver Mag.
Petersen's 4Wheel mag ROTM. Voted 2008 Bronco II of Year
rookieshooter is offline   Reply With Quote
Old 09-26-2006, 04:41 PM   #33
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
Looks very nice.
Be sure to post some pictures when you "fill it up".
__________________
Al Franklin
My truck
My Quest for 30
Old 09-26-2006, 08:51 PM   #34
BrooklynBay
Brooklyn, NY
Vehicle Specs
Are you planning on putting in shelving, and work benches? Did you think about sky lights? You could get a lot of light without having windows on the ground level where people could look in.
Old 09-27-2006, 08:58 AM   #35
KillerB74
KillerB74's Avatar
'92 XLT
Vehicle Specs
(Original Poster)
A skylight has crossed my mind, but it is becoming a matter of budget now. I just bought the electrical supplies and they were $750 without any light fixtures. 6/3 NMWU is $16/meter ($4.90/ft), 50ft cost $250 alone! So far I have spent more than $15,000 without insulation and sheeting the inside.
A work bench is in the plan for sure. I am still deciding what kind to build. A friend of mine made one out of 2x4's glued and screwed stacked on edge, basically making a butcher block type of top. I am considering trying that.
__________________
1992 XLT, 5sp
2007 EB, 4.6L V8
Old 09-27-2006, 09:10 AM   #36
KillerB74
KillerB74's Avatar
'92 XLT
Vehicle Specs
(Original Poster)
Luckily the door on the back of the house is very close as well. You come out the back door onto the deck, walk about 10' and you are at the garage. That is good idea though, I will have to put it in the future enhancments category for now!
I am not sure why we are allowed a slab with a thickened edge on a detached garage. My dad has had his for about 25yrs now and the slab is still in excellent condition. I am guessing that we don't have too many freeze thaw cycles. It gets cold in the winter and stays cold and frozen for 5 months. I suppose like all construction it also depends on what you do with the runoff water, if you have good drainage you should have very little extra water under the concrete to cause problems.
__________________
1992 XLT, 5sp
2007 EB, 4.6L V8
Old 09-27-2006, 09:12 AM   #37
rhyno
Potomac, MD
rhyno's Avatar
1997 EB
Vehicle Specs
What happens when small objects get stuck between the 2x4's? They are not perfectly square on the edges. Wouldnt it be better to build a heavy duty frame and have a flat top board?
Garage looks great by the way.
__________________
2002 Limited
1997 Eddie (SOLD)
rhyno is offline   Reply With Quote
Old 09-27-2006, 11:25 AM   #38
BrooklynBay
Brooklyn, NY
Vehicle Specs
With the cold weather slowly approaching up, you might want to install a heating system in there. Check my thread for some ideas: http://www.explorerforum.com/forums/...d.php?t=148195
Old 10-09-2006, 11:47 PM   #39
BrooklynBay
Brooklyn, NY
Vehicle Specs
Do you have an update on the progress since last month (any new pictures)? How cold is it where you are? Most people where I live will start to run their boiler in a couple of weeks.
Old 10-10-2006, 11:11 PM   #40
Charlie's_93EB
Cat 3 Hurricane Rated
Venice florida
Charlie's_93EB's Avatar
1993 Eddie Bauer
Vehicle Specs
wow that looks good so far.
__________________
1993 Eddie Bauer Member of Ranger roll over posse
Fix your 4x4 herehttp://www.explorerforum.com/forums/...ansfer+rebuild
Charlie's_93EB is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
