Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
heater doesnt work
Reply
Thread Tools
Old 09-06-2006, 09:40 PM   #1
xlt007
Cheyenne Wy
'00 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
heater doesnt work
ok my heater just stopped working, it blows cold air but it wont blow hot air.. i dsont know why can anyone help?? its a 2000 explorer xlt 4.0 sohc
xlt007 is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-07-2006, 06:08 AM   #2
NHale623
Eliot, Maine
95 XLT
Vehicle Specs
Quoted: 0 Post(s)
Do you have hot water flowing through the heater core?
Is your engines temperature instrument reading normally?
NHale623 is offline   Reply With Quote
Old 09-07-2006, 11:30 AM   #3
fobrnno
toronto, canada
98 xlt, 94xlt
Vehicle Specs
Quoted: 0 Post(s)
do a search for blend door is seams to be a commom problem.
fobrnno is offline   Reply With Quote
Old 09-07-2006, 12:30 PM   #4
ma96782
Vancouver, WA
'94 XLT, 4dr
Vehicle Specs
Quoted: 0 Post(s)
IMHO......check the engine temp......sometimes it's "T-stat that is stuck open"............replace it. Or clogged heater........so, flush it.
And,
Sometimes, it's a stuck blend door or it's the Ac/Heater, "head unit."
Aloha, Mark
ma96782 is offline   Reply With Quote
Old 09-08-2006, 11:49 AM   #5
David Suesz
SE PA
1997 Mountaineer
Vehicle Specs
Quoted: 3 Post(s)
US You need to verify whether the
heater blend door is broken, after checking the easy stuff like the hot water valve. Apparently, the failure rate of this door is 100%, and if that's where you are, you need to read my thread on this repair:
http://www.explorerforum.com/forums/...d.php?t=161208
David Suesz is offline   Reply With Quote
Old 09-08-2006, 12:11 PM   #6
n0xdw
Akron Co
n0xdw's Avatar
85 Bronco II
Vehicle Specs
Quoted: 0 Post(s)
Heater tests
Quote:
Couple checks, first verify that your antifreeze is up to level. If you are quite low on coolant it will not circulate through the heater core. Also verify as you move the control from full hot to cold you should be able to hear a slight difference in the sound especially if the fan is on high.
I see while i was responding someone else also mentioned verify the operation of the door...
Having done that verify that your engine is warming up properly.. Stuck thermostat? Then put your hands on the two heater hoses with it warmed up and running. If both of them are not hot, you have a circulation problem. Check to make sure the water valve did not get stuck off. If the valve is ok then the Heater core may be plugged. Let us know your results.
n0xdw is offline   Reply With Quote
Old 09-08-2006, 12:59 PM   #7
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 3 Post(s)
not 100% my 96 has the OEM door and it has never failed nor been repaired, 153K miles
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 09-08-2006, 01:35 PM   #8
David Suesz
SE PA
1997 Mountaineer
Vehicle Specs
Quoted: 3 Post(s)
US Yet.
The door is a mediocre design, molded in the cheapest possible plastic. The aftermarket Chinese-made replacement door is easily three times the strength, due to the use of fiber-impregnated plastic. I can tell you this, since it is stiffer, it seals better at full cold and full hot than the OE door ever did.
Old 09-08-2006, 01:49 PM   #9
ma96782
Vancouver, WA
'94 XLT, 4dr
Vehicle Specs
Quoted: 0 Post(s)
I "thought" the heater blend door issue was for the 2nd Gen. Ford Explorers......cause, FORD installed the "wrong" part??
Quote:
I'm pretty sure the problem with the defective one is that, during manufacturing, they put the wrong door in. They used the one for the auto climate control with the manual control setup. The door was not the right size and falls over causing it to jam or break. The replacement has the right door in it.
This is what Ford told me.
Aloha, Mark
PS..............I read it on the internet (the above quote)..............anyway, here is the thread on HOW TO FIX THE DOOR:
http://www.explorerforum.com/forums/...ght=blend+door
Old 09-08-2006, 03:16 PM   #10
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 414 Post(s)
Check the vacuum lines for leakage. The controls for the blend door require vacuum to function properly. Those color coded plastic lines crack after a while.
BrooklynBay is online now   Reply With Quote
Old 09-08-2006, 03:26 PM   #11
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 414 Post(s)
According to this thread: http://www.blenddoorfix.netfirms.com/, it appears that the blend door is electrically actuated.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
