Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Ranger - Mazda B-Series Forum > Ford Ranger - Mazda B-Series Forum
Notices
Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well.
Oil Consumption,2006 Ranger
Reply
Thread Tools
Old 09-20-2006, 03:42 AM   #1
AndyF
Ontario,Canada
Ranger 2006
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
I use 5W20 regular in my 3 litre engine(automatic) as recommended in the manual.
I do my own lite maintenance and I changed the oil at 5000 kms. I've got 10000 kms on it now and it's down a litre. The Ford guy couldn't explain the oil consumption but was persistant that I stay with this, I call, "sewing machine oil".
I think the truck is screaming for 30 weight, as I do a lot of highway, but I never overload and I'm easy on driving, and drive at 60 MPH. I never accelarate quickly, and I allow the tranny to shift without pulling to hard. Basically I baby the truck as I'm not a trader and need to get max life out of it.
Should I go up to 5W30, or maybe switch to synthetic? What happens to the warranty with the weight change?
Thanks
AndyF is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-20-2006, 05:56 AM   #2
ExplorerDMB
Moderator/Technician
Mechanicsville, Virginia
2004 Acura TL
Vehicle Specs
Quoted: 0 Post(s)
Well...if you change to 5w30 and something happens to that motor, Ford will EASILY void that warranty. My Explorer calls for 5w-30 - You should be able to use it just fine. Make sure it's nothing small like not tightening the drain plug tight enough or oil filter and it allows to leak slowly. Or maybe your drain plug is leaking because of a bad gasket on it - just look for leaks too.
-Drew
__________________
My Useful Threads (38 Entries and Growing)
ExplorerDMB is offline   Reply With Quote
Old 09-23-2006, 08:32 PM   #3
JohnnyO
Moderator Emeritus
Pittsburgh, PA
JohnnyO's Avatar
'08 Sport Trac
Vehicle Specs
Quoted: 13 Post(s)
5w-30 will probably void the warranty, but I seriously doubt it will actually hurt anything. Because I'm one of those nutty people who sends their old oil to a lab for testing, I can tell you that 5w-20 after 5000 miles in my wife's 3.0 Taurus came back perfectly fine and the wear metals were all very low. In fact the results were pretty much identical with Mobil 1 and the Motorcraft blend that costs half as much.
If it would make you feel better, drop $20 per at Blackstone for UOA's on the 20 and 30 both and see what they tell you.
www.blackstone-labs.com
Anything else is just speculation.
__________________
'08 Sport Trac, Gibson exhaust, Firestone Destination A/T's, Steelers swag.
"It is not the multitude of ale-houses that occasions a general disposition to drunkenness among the common people; but that disposition arising from other causes necessarily gives employment to a multitude of ale-houses." -- Adam Smith, 1776
JohnnyO is offline   Reply With Quote
Old 09-25-2006, 05:29 PM   #4
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
Vehicle Specs
Quoted: 10 Post(s)
For the record, Ford has it in writing that anything less than 1 quart every 900 miles is just fine. (I'm not saying I agree with it, but that's the spec anyways).
Check it often and top it off as necessary.
-Joe
__________________
-98 Explorer Sport, 4.0 SOHC, K&N drop-in, LEMON in progress!
-'00 F-150, mucho mods
"We need to allow Darwinism take it's course and let the idiots weed themselves out of existance." ~ Rick Horwitz
We must believe in free will we have no choice.
~ Isaac Bashevis Singer
I'm not smart, just a resourceful idiot. ~ Me
gijoecam is offline   Reply With Quote
Old 09-25-2006, 06:07 PM   #5
rookieshooter
Moderator Emeritus
Martinsburg WV
rookieshooter's Avatar
84 BII "Li'l Samson"
Vehicle Specs
Quoted: 2 Post(s)
I bet you have a small leak somewhere. Put some newspaper under the truck when you park it for the night. Check next day.
__________________
"2013,2012 & 2011Truck Nationals" At Carlisle Extreme 4x4" First Place winner.
2013,2012,2011 All Ford Nationals winner. 2X first 1X second
Featured in 2012 Bronco Driver Mag.
Petersen's 4Wheel mag ROTM. Voted 2008 Bronco II of Year
rookieshooter is offline   Reply With Quote
Old 09-25-2006, 09:28 PM   #6
hunterdan
Fairless Hills, Pa
2010 Chevy Silverado
Vehicle Specs
Quoted: 6 Post(s)
Stick with the 5W-20 if its what the motor calls for. Yes the oil is thinner, but it is what is required to get to where it needs to be. 5W-20 is thick enough to support the loads the engine is placing on it. All bearings that are under oil pressure ride on a film of oil, if that film is too thick, it will not flow where it should, if its too thin, the film will not be able to support the load. Theres a lot involved for the engineers to determine proper oil. While the 30 wt may work, your motor is still new and tolerances are still tight and I wouldn't chance it. Look at all the new imports, most of them are running the same oil and get well over 100,000 miles out of the motors with no problems. Stick with the recommended oil, its recommended for a reason.
Dan
__________________
Dan
Current:2010 Chevy Silverado Crew Cab 4.8 V-8, 4x4, rear locker (stock for now)
Traded: 2008 Nissan Frontier 4x4, Intake, Exhaust, Programmer
Gone: 1998 Ford Explorer Sport, lifted with all the cool stuff
hunterdan is offline   Reply With Quote
Old 09-26-2006, 06:57 AM   #7
AndyF
Ontario,Canada
Ranger 2006
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Quote:
Dan
Thanks everyone for the tips.!!!!
The wife's 05 Echo calls for 5W30 every 5000 miles(8000KMs), can't figure it. The big six would seem like a heavier worker than the 4 banger.
I agree with the tolerances and such, just doesn't seem right.
Andy
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
