Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Modified 1995-2001 Explorers
Notices
Modified 1995-2001 Explorers Questions related to modified 1995-2001 Explorer, Mountaineer, Ranger and 2002+ Sports (2dr). Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, torsion twist, lift kits, engine swap, transmission swap.
Engine squeak/chirp from top rear of engine.
Reply
Thread Tools
Old 10-02-2006, 08:28 PM   #1
4xmadness
Calgary, Alberta,
'98
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hi all I have been chasing this noise for a couple of months now. Has any one else run into this and found a fix,(See below)
Issue:
"When the engine is cold, I hear a repeating metallic squeaking or chirping coming from the area of the rear of the engine. This is the 4.0L OHV V6.
After
about 5-10 min of driving, it goes away. Sometimes, it's gone even for
several days - even when cold.
The chirping goes about 400 - 450 times a minute as the engine is idling at about 800-900 RPM. That tells me the chirping is happening at half
crankshaft speed. The spark plugs, fuel injectors, and valves all do
their
thing at half the speed of crank rotation, so I suppose any are suspect.
Using a Mechanics stethoscope against-the-engine block head and intake, I hear nothing inside like a clattering valve or bearing, and no chirping.
But can still hear the chirp when just standing there listening.
I listen with the stethoscope to the injectors and you can clearly hear the rapid tic-tic-tic-tic-tic of the injectors (that's normal). But I don't hear the chirp, only from the back of the engine without the stethoscope, as
if it's external to the engine. The ticking of the injectors is in
sync to
the chirp repeating, so that verified for me that it's at half crank speed.
Seems to regular to be a rubbing part on the outside of the engine.
It's not the serpentine belt - we even pulled it off and started the engine for a couple second without the belt - and we still hear the chirping.
So
that rules out any of the belt-driven accessories and the idler pulley and tensioner, as well ruling out the water pump.
Question is, can a fuel injector squeak? I can't imagine it's the cam
or
the lifters or the valve guides, as they are all bathed well in oil.
Plenty
of oil per the dipstick, and plenty of oil pressure per the OP gauge. "
Thanks for any clues...
Myk
__________________
4xmadness
4xmadness is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-02-2006, 08:51 PM   #2
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 685 Post(s)
This will get you down the right path
http://www.explorerforum.com/forums/...ght=bird+chirp
__________________
Jon
9 mile skid, on a ten mile ride. Hot as a pistol but cool inside.
2000 Mountaineer
1998 Mountaineer "Turdle"-gone
1993 Convertible "Vitamin D Wagon" Sold also
Turdle is offline   Reply With Quote
Old 10-03-2006, 11:57 AM   #3
justanother1
Dover, PA
96 XLT; 97 XLT
Vehicle Specs
Quoted: 9 Post(s)
4xmadness, I had gone through this on our 96X with the 4.0 OHV. I had purchased the complete cam synchroizer from RockAuto but could not get it to work. I had taken the original one apart and clean it but this only last 1 day of no noise. Please see this thread. This may help even though this was originally for the 5.0L.
justanother1 is offline   Reply With Quote
Old 09-13-2007, 07:48 PM   #4
4xmadness
Calgary, Alberta,
'98
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks to all who replied, I did order the DORMAN OEM REPLACEMENT CAMSHAFT SYNCHRONIZER from Auto value, it was $90.00 Canadian, it came with a complete syncro assembly, camshaft position sensor and alignment tool. I opted to replace the upper and lower intake gaskets at this time as it made for much easier access and there was a slight leak at the front of the intake, worked great, you could feel the bearing was shot in the old Syncro
__________________
4xmadness
Old 05-15-2008, 11:19 AM   #5
Turbozombie
Calgary,AB,
1997 XL
Vehicle Specs
Quoted: 0 Post(s)
Quote:
How long ago did you do this repair? I'm in Calgary as well and may require some advice on the repair.
Turbozombie is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
