Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2006 - 2010 Explorer Mountaineer 4th Generation > Stock 2006 -2010 Explorers
Notices
Stock 2006 -2010 Explorers Stock 2006 -2010 Ford Explorer Forum. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Can the DRLs be disabled on an '06?
Reply
Thread Tools
Old 10-09-2006, 09:24 AM   #1
aowRS
Ellicott City. MD
Vehicle Specs
(Original Poster)
Hello,
I am asking this question on behalf of my father who recently purchased an '06 Explorer 4WD XLT. Is there a way to disable the daytime running lights, either by relay/fuse removal, or other clean methods?
On my '01 4Runner, this involved the cutting of one wire, and was thus reversible.
Thank you in advance.
Andreas
aowRS is offline   Reply With Quote
Old 10-09-2006, 09:32 AM   #2
bentley
New Jersey
bentley's Avatar
98 Sport & 06 Limited
Vehicle Specs
thats strange. i dont have DRL's in my 06.
__________________
Formally a 06 Limited & 98 Sport
Currently 08 Laser Red Saab 9-3 6sp Manual.
bentley is offline   Reply With Quote
Old 10-15-2006, 05:01 PM   #3
fatboy11
gastonia, nc
2006 XLT
Vehicle Specs
I also have a 06 with DRL. I like to fish and hunt and there are times I want my lights off. I looked uder the right front wheel as was suggested in some of the earlyer models? I didn's see anything but a lage group of wires all wraped together. [U]I need HELP TOO!
fatboy11 is offline   Reply With Quote
Old 10-16-2006, 12:59 AM   #4
groovyone
Houston, TX
2006 EB V8
Vehicle Specs
Mine has the automatic headlight setting, but I haven't noticed any DRLs either.
groovyone is offline   Reply With Quote
Old 10-16-2006, 02:02 AM   #5
Brian_B
Mountain Home, AR
Brian_B's Avatar
2000 mounty / 56 f-100
Vehicle Specs
Have any of you with them tried to set your E-brake and see if they go off? I am just curious. Someone told me that "the other brand" did this. It sounded fishy to me, but who knows.
__________________
56 f-100, short bed, 272 "Y" block V8, 3 speed standard, 3.73 rear gears.
Oh...I have a 2000 mountaineer as well.
Brian_B is offline   Reply With Quote
Old 10-16-2006, 07:54 AM   #6
m6500
Richmond,Va
97 XLT SOHC 4X4
Vehicle Specs
the drl module plugs into a connector that is below and behind the dirvers side headlight assembly. It's a box a little larger than a pack of cigs. If you remove the module you will need the plug that was removed to install the module in the connector. I expect you would have no trouble finding one at the junk yard as the vehicles were not shipped with the module in the US, however the feature could be obtained by removing the plug from the connector and inserting the module. The plug not only protects the connector from dirt but also provides proper electrical jumpers for the headlight circuit.
m6500 is offline   Reply With Quote
Old 10-16-2006, 07:27 PM   #7
fatboy11
gastonia, nc
2006 XLT
Vehicle Specs
I did try the emergency brake and it didn't turn them off, even if I pushed it to the floor and put it in gear. LIGHTS ON!
I will look for the cig pack size modulule behind the head light as suggested by m6500. It,s raining in NC tonight but I will check it out tomorrow. I apreciate the suggestion.
Old 10-17-2006, 08:11 AM   #8
m6500
Richmond,Va
97 XLT SOHC 4X4
Vehicle Specs
fatboy11, I don't know if the 06 is different from my 97 and must be as depressing the parking brake does turn the drl's off on the 97. Since yours doesn't something is different
Old 10-27-2006, 07:25 AM   #9
ffdemoss
Little Rock, AR
2005 XLT
Vehicle Specs
Are your park lights on with your "drl"? IF so, those aren't drl...that is the auot-headlights. True DRL will not turn on the parklights.
ffdemoss is offline   Reply With Quote
Old 11-04-2006, 09:29 AM   #10
rpr
Smith Mountain Lake, VA
2006 Limited
Vehicle Specs
Very strange. My '06 Limited does not have DRL's. I previously asked my dealer about this and they told me the '06 X's don't have DRL's.
So I can orderr this module from my dealer and get DRL's?
aowRS: If you don't want your module, I'll take it.
rpr is offline   Reply With Quote
Old 11-05-2006, 05:48 AM   #11
Crankcase
Moderator Emeritus
Vancouver B.C, Canada
Crankcase's Avatar
1992 XL Ex-Police
Vehicle Specs
CAN
Quote:
Ford trucks in Canada have had DRLS's since 1990, and the E-brake has been used to turn them off since way back then.....
__________________
*Explorer Family*
1992 XL Mine 1992 XL Sisters
1992 XL Dads 1994 XL Moms
Ex-Moderator: Modified Explorations Drivelines
New Member Forum
***Guest star poster....
Crankcase is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
