| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Sport Trac and Sport use the 1995-2001 forum. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Seattle
Verify my wiring on 791xv
Hi, I am here trying to help and get helped.
This is how to hook 791xv to your 04-05 Explorer. After alot of research, I came up with this wiring diagram and wondering If some one can look it up and correct me if I am wrong in any wires. Plus I don't know How to connect extra sensors to the alarm and not 100% sure about the window roll up & down. Thanks In advance and Happy holidays H1 12 ORANGE Planning to connect 530T window roll up with 87 relay. 11 white ---------------- BROWN (+) HEADLIGHT SWITCH, GRAY Plug 10 WHITE/BLUE Not used 9 BLACK/WHITE - Not used 8 Green--------------------------------BLACK/LIGHT BLUE (+) Door trigger input 7 Blue----------------------------------PINK/ORANGE - Trunk trigger input 6 Violet Not used 5 Black/Ground CHASSIS GROUND POINT 4 Empty 3 Brown Siren output + I hooked this wire up to the red wire that comes off your siren. 2 Red 12 VOLT CONSTANT Yellow IGNITION SWITCH HARNESS, BLACK Plug 1 Red/White---------------------------ORANGE/LIGHT GREEN (+) or PURPLE/YELLOW (+), Requires Part #87 Relay H2 1 L. Blue 200a (-) This is if your car have to push once to unlock and 2nd to unlock the rest of the doors 2 White/ Black 200a(-) channel 5 output Can I connect this to the Tilt sensor 3 VIOLET/BLACK - 200a(-) channel 4 output Can I connect to the glass sensor 4 Green/White FACTORY REARM Not used in ford 5 Gray/Black Not used in ford 6 L Green/ Black (-) factory disarm (GREEN/VIOLET - "HARNESS UNDER DRIVERS SIDE DOOR SILL PLATE) Door Lock Harness, 3-pin Connector 1 GREEN ---------------------------PINK/YELLOW Lock + 2 Empty 3 Blue +------------------------------PINK/LIGHT GREEN Unlock – Remote Start Primary Harness, 7-pin Connector This connector plugs into the relay satelight and then into the alarm. 1 PURPLE(+) ------------------------RED ( Strarter side) 2 GREEN------------------------------RED ( Key side) 3&6 RED(+)--------------------------YELLOW (+) 4 ORANGE(+)------------------------DARK GREEN/L GREEN (+)Accessory circuit 5 PINK(+)------------------------------RED/LIGHT GREEN (+) Primary ignition 7 PINK/WHITE(+) -------------------Not Used 8 RED/WHITE(+) -------------------Not Used H3 1 blue/white----------------------------GRAY/BLUE - Defoger - REAR DEFROST SWITCH 2 GRAY(-)------------------------------Hood pinswich Input, zone 1 3 BROWN(+)---------------------------TAN/BLACK (+) or LIGHT GREEN (+) brake shutdown wire 4 VIOLET/WHITE I don’t know what wire to hook up Need help May be (PINK/WHITE) in IGNITION COIL PACK 5 BLACK/WHITE(-)-------------------Planning to Ground it. H4 1 brown(-)----------------------------YELLOW/LIGHT GREEN (-) or YELLOW/LIGHT BLUE (-) 2 Orange/Black Not Used |
| Sponsored Links (Less Ads) |
#2 |
Seattle
Can you tell me if I am missing any relay too. Thanks
#3 |
Seattle
Seems like no one can help!!!!!!!!!!
| Thread Tools | |
