Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Elite Explorer 911!
Notices
Elite Explorer 911! 911! is for situations where your truck is currently out of commission and the owner is in a crisis situation. Members will try to answer your questions asap, no time frame is guaranteed. Only Elite Explorers can post new threads in this forum
thermostat and sensor housing- do they crack?
Reply
Thread Tools
Old 12-10-2006, 03:29 PM   #1
robrike40
Elizabethton, TN
robrike40's Avatar
98 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hi,
98 XLT SOHC V-6
Kind of an emergency, need to get this on the road ASAP. Car was leaking coolant in the thermostat vicinity so I pulled the upper intake, drained the coolant and pulled the thermostat to replace the O ring. I did this about 18 months ago also. With the stat out and top cover off I was looking at the two sensors that screw into the housing by the heater hose. One of the sensors on the left looking from the front will not turn like it is loose but will give a bit when pressed on, as in the plastic and washer flex. I am thinking this is not normal and is the source of my leak. The other sensor next to it is rock solid, no play. There is a wire that runs from the lower intake area down to the bottom that makes getting in there tough. Do those plastic housing that the sensors screw into crack or is some flex normal? Trying to decide whether to put it all back together and see what I get or avoid doing it twice and replace the upper housing. Any thoughts?
Thanks,
Rob
robrike40 is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-12-2006, 12:41 AM   #2
pj8847
N.Y.C.
'95 XLT 4x4 4.0L OHV
Vehicle Specs
Quoted: 0 Post(s)
The plastic housings sure can crack. The sensors can also develop a leak as well due to bad manufacturing, cracking, age, heat, etc... around the "base", if you will. Sometimes it's not apparent until the cooling system builds up pressure.
You shouldn't have any movement in the sensors at all as far as I know, Could be where your problem lies. Since you have it all apart, I'd look it over and inspect everything thoroughly now anyways, and replace what you have to, if you have to. No sense in putting it back together, just to rip it apart again at a later date.
__________________
"No good deed goes unpunished."
'95 Explorer XLT 4x4, Fully loaded, CHERRY RED! | 31x11.50 R15's on factory teardrops | K&N drop in filter | 6000K HID's & Custom 6000K HID fogs | Pioneer AVIC D3X HU, factory amp/speakers | Pioneer 6 CD changer | custom amp/sub setup
pj8847 is offline   Reply With Quote
Old 12-12-2006, 11:11 AM   #3
robrike40
Elizabethton, TN
robrike40's Avatar
98 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hey,
I appreciate the reply. I think I will go ahead and pull the housing and check everything out. There are a couple of wires in the way that will probably prove to be the hardest part of removing it but it looks like 3 bolts after the 3 for the thermostat top are out.
I will check it over and let you know what I find. I definetly don't want to be going back in once it is back together.
Thanks,
Rob
Old 12-16-2006, 12:25 PM   #4
robrike40
Elizabethton, TN
robrike40's Avatar
98 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Finally got around to pulling the lower thermostat housing off today. The bushing for the sensor on the left side of the housing is stripped/screwed/trashed/slightly dislodged. I suspect that is where the leak was and when I tried to unscrew it I may have stripped it more. The plastic under the bushing is broken. Just ordered a new one for$136 at the dealer along with the O ring that goes below it. Should be in Tuesday.
That thing can be a pain to get off. I took the upper and lower intake off but the wiring harness runs above it and makes things tricky.
Thanks again,
Rob
Old 12-19-2006, 06:03 PM   #5
robrike40
Elizabethton, TN
robrike40's Avatar
98 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
anyone know a part number or source online for this part? Just got my "part" in from the dealer and it is totally the wrong part and they gave me some line about Ford parts system numbers being cruddy. Mine is a 98 XLT with 4.0 SOHC and it is the plastic housing that the thermostat goes in and also has two sensors screwed into it and a connection to a heater hose. The thermostat rest in it and has a top cover and o ring that the upper hose connoects to.
Thanks,
Rob
Old 12-26-2006, 11:00 PM   #6
robrike40
Elizabethton, TN
robrike40's Avatar
98 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Final answer is they do and it stinks!!! $206 part from the dealer and no aftermarket. Seems the leak develops when the brass bushing strips from the plastic housing as you try to remove the ECT sensor or coolant temp. sensor. There are two on the housing, one for the gauge and one for the computer. Sensor corrodes to the bushing and just breaks it lose in the plastic to leak from. I did the timing chain tensioner a half year ago and wonder if when removing the sensor I damaged it then? The leak only recently started that I can tell but there was some old looking crusty coolant around it.
Be careful in there!
Rob
Old 08-29-2009, 09:58 AM   #7
buckyray
houston texas
1998 v-6 shoc 4.0liter
Vehicle Specs
Quoted: 0 Post(s)
Hi, i'm Johnny. I am from Houston,TX in need of thermostat housing for 1998 Ford Explorer V6 4.0 liter SOHC. Does anyone know where i can purchase one online? or any website that sales one for this vehicle?
buckyray is offline   Reply With Quote
Old 08-29-2009, 11:01 AM   #8
kevinspann
Richmond, VA
1997 EB
Vehicle Specs
Quoted: 21 Post(s)
Quote:
You can do a replacement for less, but it requires some parts gathering. You'll need the lower housing from a later Sport Trac ('03 or so), the two sensors, and the clips that hold the sensors in. You can reuse the upper portion that you currently have, you just need to pop out the bushings in the three holes.
kevinspann is offline   Reply With Quote
Old 08-29-2009, 04:43 PM   #9
buckyray
houston texas
Vehicle Specs
Quoted: 0 Post(s)
Old 08-29-2009, 04:52 PM   #10
Blee1099
Evil Asian
Elkridge, MD
Blee1099's Avatar
91
Vehicle Specs
Quoted: 10 Post(s)
Have you tried rockauto.com? I recall seeing them on there.
Blee1099 is offline   Reply With Quote
Old 08-31-2009, 12:35 PM   #11
buckyray
houston texas
Vehicle Specs
Quoted: 0 Post(s)
where do i get clips for sensors on thermostat housing for1998explorer v6 4.0liter sohc
Old 03-08-2010, 09:27 PM   #12
dtill
1997
Vehicle Specs
Quoted: 0 Post(s)
Need thermostat housing for Ford Explorer 1997 6.0 cylinder SOHC
I live in the Phoenix Arizona area and my thermostat housing is cracked and I'm looking for a replacement. Dealer price is $240. My mechanic tells me I can get one from a junk yard for $30 or so. Does anyone have one or know where I can get this part today?
dtill is offline   Reply With Quote
Old 06-28-2010, 12:55 PM   #13
compdoc777
Cypress, TX
95 EB, 98 EB, 01 Exped EB
Vehicle Specs
Quoted: 0 Post(s)
My answer to this is $5 Platic epoxy 3600 Psi goo and a $10 sensor.
The answer to Fords $310 replacement part.
I am going to pop that ring out and clean it up and glue it back in with the plastic epoxy.
You know Ford designed this to break exactly how it does. They want to make bank off the replacement part.
Funny I called my dealer today 6-28-2010 and asked about the part and they had everything for me ready to go with plenty in stock. I told him they were probably going to continue to have a great supply at that price!
I'll post up pics of the fix.
__________________
Krazy Explorer upgrade in progress.
compdoc777 is offline   Reply With Quote
Old 06-28-2010, 10:19 PM   #14
xplorercrazy
Kilgore, Texas
xplorercrazy's Avatar
'02 Limited
Vehicle Specs
Quoted: 0 Post(s)
Dorman also makes a replacement housing for the 97-01 4.0 SOHC motors which is about half the price of the Ford one. Part #902-204. It also is possible to replace this housing without taking off the lower or upper intake manifolds. We see these all the time at the shop I work at and it happens on the 4.0 SOHC motor all the way up until at least '07-'08 model Explorers
__________________
2002 Limited V8 4X4 FloPro muffler, K&N FIPK intake 1999 Ranger 4.0 OHV 4X4 4 Door ext. cab, 5 Speed manual 1997 Thunderbird LX Sport V8 Dual Flowmasters with Magnaflow cats, Custom air filter setup, B&M ShiftPlus Electronic shift improver, 17" Cobra R rims, Kenwood head unit
xplorercrazy is offline   Reply With Quote
Old 06-30-2010, 09:02 AM   #15
96eb96
Albany, NY
96 EB V6 OHV 4WD
Vehicle Specs
Quoted: 32 Post(s)
Quote:
Anything made by Dorman concerns me. I installed a dorman diff cover for someone and after a few rains(no salt) it looks like its 10 years old, lots of rust. We ended up putting grease on it.
96eb96 is offline   Reply With Quote
Old 07-12-2010, 12:09 PM   #16
96eb96
Albany, NY
96 EB V6 OHV 4WD
Vehicle Specs
Quoted: 32 Post(s)
To Follow up: Dorman really cares about their customers and gave me 100% satisfaction on the issues I had with their products. I wouldn't hesitate to buy this brand again. Seems they are trying to rectify any issues they had in the past.
Old 08-31-2010, 05:28 PM   #17
1967misschris
tampa fl
2003
Vehicle Specs
Quoted: 0 Post(s)
having a hard time getting the clip back in place on the new 03 thermo housing..any ideas...stuck on the side of the road now ..
1967misschris is offline   Reply With Quote
Old 09-02-2010, 10:45 AM   #18
wajjlj95
MS
2004 XLT
Vehicle Specs
Quoted: 0 Post(s)
I'm having the very same problem with my '04.O'Reilly's has the bottom thermostat housing for about 65 bucks.
wajjlj95 is offline   Reply With Quote
Old 12-04-2010, 12:00 PM   #19
XLTmodifire
Nor*Cal
99' XLT (B4 Autumn Brown)
Vehicle Specs
Quoted: 0 Post(s)
I have been told my 99 XLT has a leak at the ECT sensor, as well as the thermostat, and timing cover gasket.
Is the ECT sensor easy to replace? From this thread it appears it is an expensive part, and I do not want to take a chance in damaging it.
Thank you.
XLTmodifire is offline   Reply With Quote
Old 12-05-2010, 07:52 PM   #20
ucluglee
Greenville, SC
'00 XLT
Vehicle Specs
Quoted: 0 Post(s)
I just replaced my '00 4.0 SOHC yesterday. It CAN be done without removing the upper intake, but you have to fight the vacuum lines and the crank sensor wire. I found that removing the crank sensor connector and bracket it made the job a bit easier, but it was still a PITA to do. I have one image of the engine with the housing removed. Mine was leaking from the bottom housing-to-engine seal and both sensors. I got a new housing, 2 sensors, throttle body to intake plate and plate to intake O ring all for $150 (bro-in-law works for Carmax and he has connections). The entire process took about 3.5 hours.
__________________
Previous
1984 Bronco II 2.8 V6 312k miles
1992 Ranger 3.0 V6 394k miles
Currently
2000 Explorer XLT 4DR 2WD
4.0 V6 SOHC 217k miles
ucluglee is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
