EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Street Truck & Performance Forums > Street Trucks > Need for Speed!
Notices
Need for Speed! Explorer, Ranger, Mountaineer 4.0 - 4.6 - 5.0 Nitrous, Superchargers, Camshafts, Head Work, Stroker Kits... DRAG RACING. Explorers, Mountaineers and Rangers CAN move!
4.0 OHV & SOHC Go Fast Goodies!!
Reply
Thread Tools
Old 10-19-2007, 10:05 PM   #21
I Need $
Bellflower, California
99 xlt
Vehicle Specs
Yeah I didn't learn about the sites before today they are really good. But I still am pretty clueless about some of that stuff. Like the short blocks would everything line up together, or would it be too much of a headache to even think about doing something like that. Because i would like to have the 400 or 500 hp engine in there.
__________________
99 XLT 4.0 SOHC. Want alot but can't afford it. Hence the name.
I Need $ is offline   Reply With Quote
Old 12-10-2008, 02:08 AM   #22
DieselDean89
Columbus,Ohio
1999 XLT 4.0L SOHC
Vehicle Specs
this is probobly a really dumb question here but its been bothering me for a while now: is the mustang 4.0L SOCH and the X 4.0L SOCH the same engine?
DieselDean89 is offline   Reply With Quote
Old 05-05-2009, 03:43 PM   #23
98sohcxlt
Wallkill, Ny
1998 4.0sohc xlt
Vehicle Specs
I cant wait for my airforce signing bonus =D 13k and i want to put most of it into a fully built sohc engine to replace my current 195k 4.0
__________________
1998 Ford Explorer XLT: 4.0 sohc engine, close to 190k, hoping to turn into a supercharged xp6 replica
98sohcxlt is offline   Reply With Quote
Old 01-05-2010, 09:25 PM   #24
tjsxplodr
New Mexico
1994 Ford Explorer XLT
Vehicle Specs
This is a really old thread I'm bringing back up, but aren't there more sites out there for the 4.0L OHV Explorers?
tjsxplodr is offline   Reply With Quote
Old 01-27-2010, 02:42 PM   #25
2000XPLORERSPORT
lambertville,mi.
2000 FORD EXPLORER SPORT
Vehicle Specs
Quote:
yea i agree! if so, please post some.
__________________
http://www.cardomain.com/ride/2429989
4.0l ohv red taylor 8.8mm spiro pro wires, motorcraft platinum plugs,royal purple 5w-30 oil,k&n oil filter,valvoline synthetic brake fluid,red top optima battery under the hood.volant cai,helix throttle body spacer,2 1/2" pipe ran into turbo 2 muffler with no cats,adjusted tps to .96volts,lowered 3"
2000XPLORERSPORT is offline   Reply With Quote
Old 01-27-2010, 04:52 PM   #26
arco777
Anchorage, AK / Little Rock AFB, Arkansas
arco777's Avatar
2x 1994 4x4
Vehicle Specs
Quote:
Never got answered...
Answer is yes, basically. Same block, same general design and all that, but the SOHC has increased in power output somewhat over the years so I'd expect different heads/cams/etc to have been used depending on the year and application. Still, the 4.0 SOHC in the new Mustangs makes many performance options available for OHV and SOHC Explorers.
__________________
-1994 Explorer 2DR 4x4 - EE swaybars/shocks, Optima Yellow Top, modified throttle body, intake. Paxton supercharger on the workbench...
-1994 Explorer 4DR 4x4 - exhaust, brush guard, modified throttle body, intake, 2" lift, disc rear axle swap + L/S, 31.5" tires on 16" Sport Trac wheels.
-2008 Mustang GT Bullitt #5560 - Brenspeed tuned
arco777 is offline   Reply With Quote
Old 02-09-2010, 09:44 AM   #27
tjsxplodr
New Mexico
Vehicle Specs
Bumping this up once again!
Old 02-09-2010, 08:05 PM   #28
Jakee
Huntsville, Texas
Jakee's Avatar
01 Sport
Vehicle Specs
I'll give a hint...
morana v6 racing
__________________
STS turbo charged
Jakee is offline   Reply With Quote
Old 02-09-2010, 09:37 PM   #29
tjsxplodr
New Mexico
Vehicle Specs
I'll check it out thanks.
Old 02-09-2010, 09:39 PM   #30
tjsxplodr
New Mexico
Vehicle Specs
Would it be better to rebuild my OHV 4.0L and install better guts/heads or would I benefit from upgrading to the SOHC 4.0L for a SC build?
Old 02-10-2010, 07:42 PM   #31
Jakee
Huntsville, Texas
Jakee's Avatar
01 Sport
Vehicle Specs
I would go with a 4.0 SOHC but that's me.
__________________
STS turbo charged
Old 02-10-2010, 08:42 PM   #32
tjsxplodr
New Mexico
Vehicle Specs
So with that engine, I would not have to build it up to put in a SC? How strong is it?
Old 02-10-2010, 10:28 PM   #33
briwayjones
Sykesville, MD
briwayjones's Avatar
'00 XLS, '03 Sport
Vehicle Specs
What exactly is this super charger and how does it differ from a regular one? And why is it only a $150?
http://www.moranav6racing.com/catego...?CategoryID=43
__________________
2000 XLS, 4DR, 4x4, OHV, Manual ; 2003 Sport, 2DR, 2WD, SOHC, Manual
Mobil 1 & Amsoil Synthetic Fluids, 2WD switch Brown wire mod, KKM air intake, overhead console, lighted sunvisors, custom 2nd HU install, '03 Ranger Fog lights, Hurst short-shifter, 75MM MAF, BBK 66MM Throttle Body
My 2000 Explorer
briwayjones is offline   Reply With Quote
Old 02-11-2010, 07:28 PM   #34
tjsxplodr
New Mexico
Vehicle Specs
I dont think its a supercharger....its says supercharger plate.
Old 02-12-2010, 06:44 PM   #35
Jakee
Huntsville, Texas
Jakee's Avatar
01 Sport
Vehicle Specs
It all depends on how far you want to push the motor. For a roots type blower running under 8 LBS and tuned correctly, you shouldn't have a problem with a stock 4.0 SOHC. For the root's blower your enemy will be the intake charge heating up. The further you push the power adder out of its range, the more the air charge will heat, which in return can cause the engine to start detonating. (the explosion happens before it's supposed to and while the piston is on the way up) You want the explosion to happen at a point where the piston will not bind in the cylinder.....anyways, I don’t want to ramble off topic too much in this thread.
__________________
STS turbo charged
Old 02-15-2010, 12:37 PM   #36
tjsxplodr
New Mexico
Vehicle Specs
Ok, so what about the stock OHV motor? Is it the same as the SOHC? What's the differences in it?
Old 02-17-2010, 07:55 PM   #37
Jakee
Huntsville, Texas
Jakee's Avatar
01 Sport
Vehicle Specs
I'm not 100% about the actual type of rod in the ohv but one thing in your favor is the ohv has a 9.1:0 CR where the SOHC has a 9.7:0 CR. The lower CR will resist detonation a little better but it won't make the same power as the SOHC at the same level of boost. (the sohc will be a little more powerful)
If you already have an OHV then it would be easier to stick with it. Just state your goals and someone can direct you better.
EDIT - something doesn't look right in this post. Who can find it?
__________________
STS turbo charged
Old 02-17-2010, 08:19 PM   #38
tjsxplodr
New Mexico
Vehicle Specs
Yes, I have a 1991 OHV engine that's on its final leg. Its got one or more lifters knocking, and its getting louder.
Since I am unsure what the stock power is in the OHV's, I'm kinda not real sure what HP levels I'm wanting. Once I know stock power, then I can go from there. I can't imagine it being very much like 200 HP, if that. I'm wanting a get-up-and-go SUV, that not only has speed but more power. I'm not a speed demon, nor do I go off-roading. I just want more power in my engine, without having to go thru the pains of a V8 swap.
I think supercharger vs turbo would be better? I want the power all the time. I also want to be able to work on it myself.
Old 02-17-2010, 11:15 PM   #39
Jakee
Huntsville, Texas
Jakee's Avatar
01 Sport
Vehicle Specs
A roots type blower would be easier to install, if you had the SOHC, because RPCaster has a kit on ebay. I don't think he has a 0hv version.
The turbo would give you more power but the tradeoff against a charger is; it's harder to install; not quit the same throttle response; and a different sound.
You could search a name "Doug904" (AKA bama chips owner) and you'll come up with a lot of hits. He's one of the only I know about that has really made some power with the ohv back in the day. I believe he built the motor and ran nitrous.
It's up to you but if you just want more power without breaking the bank then the OHV does have potential. You can also use a SOHC oil pan to strengthen the bottom end a bit. Not to mention Morana has a girddle for it.
__________________
STS turbo charged
Old 02-18-2010, 12:04 AM   #40
tjsxplodr
New Mexico
Vehicle Specs
I won't use nitrous, period. If I'm gonna make power, I want to do it right. So noone out there makes a sc for the ohv's??
What does a girddle do?
Posted via Mobile Device
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
