Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
5R55W - P0775 code
Reply
Thread Tools
Old 12-28-2006, 04:16 PM   #1
ddelong1
Asheville, NC
2003 NBX V8 4x4
Vehicle Specs
(Original Poster)
5R55W - P0775 code
Hi all, I've got a 2003 Explorer that recently has developed a transmission issue on our Christmas vacation. While driving down the highway with the cruise control on the truck downshifted to maintain speed on an uphill climb. At the top of the rise, the truck wouldn't shift back into 5th gear and the overdrive light started flashing. The truck is now unable to shift into 5th gear and on the 1-2 shift it holds first up to approximately 4500 rpm. I took the truck back home and pulled the following codes:
P0732 - Gear 2 Incorrect Ratio
P0735 - Gear 5 Incorrect Ratio
P0775 - Pressure Control Solenoid B
I've done quite a bit of searching on this forum and it looks to me like it's a problem with the solenoid body. I was planning on heading to the dealership tomorrow to pick up a new one and do the repair myself following some of the detailed threads on this site. Please let me know if you think there is anything else I should check.
Thanks!
ddelong1 is offline   Reply With Quote
Old 12-28-2006, 06:09 PM   #2
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Welcome to this forum! Those solenoid blocks on the 5R55W seem to fail around 60k miles. How many miles do you have? Glacier991 has a solenoid block for sale.
BrooklynBay is offline   Reply With Quote
Old 12-28-2006, 06:15 PM   #3
ddelong1
Asheville, NC
2003 NBX V8 4x4
Vehicle Specs
(Original Poster)
The truck just turned over 50,000 right about the time of failure.
btw - I researched transmission type and decided this is a 5R55W because it's a V8 4x4 with the trailer tow package. Does that look right?
Old 12-28-2006, 06:19 PM   #4
BrooklynBay
Brooklyn, NY
Vehicle Specs
Is it a 5 speed? If not, maybe it's the 4R70W. Check the Explorer specs section.
Old 12-28-2006, 06:26 PM   #5
ddelong1
Asheville, NC
2003 NBX V8 4x4
Vehicle Specs
(Original Poster)
Well, it's a 4-speed at the moment, but it used to be a 5-speed!
The specs section lists 5R55W as the only choice for the 2003 model year.
Old 12-28-2006, 06:27 PM   #6
BrooklynBay
Brooklyn, NY
Vehicle Specs
I thought it was the 5R55W, but I just wanted to make sure when you said it was a V8.
Old 12-28-2006, 06:41 PM   #7
Bent Bolt
Edmonton,Alberta
Think Canadian ,eh !!!!
Vehicle Specs
CAN
Hate to tell you but your trans just broke it's O/D band. It applies in 2nd and 5th gears. There is a small chance that it's just the servo piston but experiance is telling me otherwise.
Bent Bolt is offline   Reply With Quote
Old 12-28-2006, 06:46 PM   #8
BrooklynBay
Brooklyn, NY
Vehicle Specs
Do you think it's a combination of the overdrive band, and the valve body since the code refers to the EPC?
Old 12-28-2006, 11:31 PM   #9
Bent Bolt
Edmonton,Alberta
Vehicle Specs
P0732**
SSA, SSB, SSC or internal parts .2nd gear ratio error 2nd gear not commanded.
Correct gear ratio not achieved for commanded gear. Shift errors may also be due to other transmission concerns (stuck valves, damaged friction material). Engine rpm could be higher or lower than expected. May flash TCIL. REFER to the Solenoid On/Off Charts. Then Go To Pinpoint Test A.
P0735
SSA, SSB, SSC, SSD or internal parts 5th gear ratio error 5th gear not commanded. Correct gear ratio not achieved for commanded gear. Shift errors may also be due to other transmission concerns (stuck valves, damaged friction material). Engine rpm could be higher or lower than expected. May flash TCIL. REFER to the Solenoid On/Off Chart. Then Go To Pinpoint Test A
P0755*
SSB SSB solenoid circuit failure SSB circuit fails to provide voltage drop across solenoid. Circuit open or shorted or PCM driver failure during on-board diagnostic. No first gear (short) or no third gear (open). Will turn on MIL. Go To Pinpoint Test A.
Here is something you can try. Back off the locknut on the band adjusters.Then screw in the adjusters. One will not "bottom out" if it is broken.
Next, clear the DTC's and then do KOEO and KOER. P0755 will return if there is a hard fault in that circuit. I'd replace the solenoid assy if in doubt and for sure if you overhaul the trans.
Old 12-30-2006, 08:09 AM   #10
ddelong1
Asheville, NC
2003 NBX V8 4x4
Vehicle Specs
(Original Poster)
Update - I decided to take it over to the local Ford dealer to let them do a diagnostic on it and see what their thoughts were. They said it is possibly the solenoid and could also be a broken or burned band. After some discussion, they offered to change the solenoid block for $300 (parts and labor) so I gave them the approval. If that doesn't fix it, the next step is to do a teardown to inspect and repair the bands. The $300 seemed like a pretty good price and saves me the hassle of doing it myself (I didn't really want to mess with the whole drain/refill process) so I figure it's worth a shot.
Unfortunately, they can't get back to it until Tuesday but once they do I'll let you know what they find. I'll be keeping my fingers crossed that the solenoid block fixes the problem.
Old 12-30-2006, 12:30 PM   #11
Bent Bolt
Edmonton,Alberta
Vehicle Specs
Parts must be soooo much cheaper down there in the US !!! I'm kinda jealous. Here that solenoid assy is about $350 alone plus diag and labour and ATF. Good luck and let us know what happens.
Old 01-04-2007, 08:05 PM   #12
ddelong1
Asheville, NC
2003 NBX V8 4x4
Vehicle Specs
(Original Poster)
Update #2 -
I picked up the truck Tuesday afternoon after the repair and it's been fine so far. The paperwork states they replaced the overdrive servo, part number 4W4Z-7D201-LA. The part cost was $20.34 and the labor came to $260 for the diagnostic and repair work. I'm not sure what piece that is exactly, but I feel like I got off pretty cheap so I'm pleased. Hopefully nothing else will come up anytime soon.
Old 01-04-2007, 08:10 PM   #13
BrooklynBay
Brooklyn, NY
Vehicle Specs
They should have replaced both servos while they were working in that area. Did you check to see if they put back the heat shield? Did they replace the solenoid block?
Old 01-04-2007, 09:22 PM   #14
Bent Bolt
Edmonton,Alberta
Vehicle Specs
Update #2 -
Good deal!! I've only seen one servo piston fail in those things. It gives the same symptoms as a broken band.
Old 05-11-2007, 02:48 PM   #15
MRStace84
Vehicle Specs
Can anyone tell me how you change the O/D servo? Or at least check it to see if it's bad?
MRStace84 is offline   Reply With Quote
Old 05-11-2007, 02:59 PM   #16
BrooklynBay
Brooklyn, NY
Vehicle Specs
The servos are hard to get to when they are in the vehicle since the catalytic converter is in front of them. They have a snap ring holding thre covers in place. It's hard to determine if the servos are leaking other than perform an air leak test with a special adapter plate which goes in the area the valve body is connected to. Look at the pictures in the Project Frankentranny thread (I think that might be the thread which I saw them in). They have a pipe tap connection on the servo covers to monitor each servo with a separate gauge.
Old 05-11-2007, 03:08 PM   #17
MRStace84
Vehicle Specs
Ok, how about just changing it out? Is it a big job?
Old 05-11-2007, 03:12 PM   #18
BrooklynBay
Brooklyn, NY
Vehicle Specs
You could do it a couple of different ways. One way is to remove the catalytic converter, snap ring, and servo pistons (watch out for those springs behind the servo). They make a special servo installation tool, but if you don't have one you could also do it with a C clamp Vise Grip which is used for welding. You have to drop the pan to hold the other side. The special tool gets connected to the pan bolts so that would be easier. Another way to get to the servos is to fold back the carpet, and lift up the access panel on the floor. You have to remove the front seats for this. The access panel is really made for a manual transmission, but the vehicle comes with it either way.
Old 05-11-2007, 03:27 PM   #19
MRStace84
Vehicle Specs
Ok, thanks. When you drop the pan, do you have to also drop the valve body to get to the back side of the servo?
Unless I am misunderstand the access cover in the floor board. It sounds like that cat would still be in the way, and the pan would need to be dropped also? I am imagining that this just allows you to reach in from the top instead of crawling underneath.
Thanks again for all you info....
Old 05-11-2007, 03:30 PM   #20
BrooklynBay
Brooklyn, NY
Vehicle Specs
There is a little space between the catalytic converter, and the servos. It might be better to remove the catalytic converter, especially if you have to drop the pan. The valve body doesn't have to be removed to replace the servos.
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
