#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Location of the Fuel Filter
Reply
Thread Tools
Old 01-01-2007, 05:39 PM   #1
cyearns
Grandview, MO
2002 Mercury Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
From what I have been reading on this forum there seems to be some confusion on where the fuel filter is located on an 02 Mountaineer.
Some people say that is is located under the passenger seat (which is a typical location for Ford products) I see a panel that is covering the fuel lines but there doesn't seem to be a filter behind it (unless I am blind).
The other location some people have said on this forum is that it is on top of the gas tank. If this is so, what is the best way to get to it? Is there access from inside the car, or do you still get to it from underneath?
Once I find it I should be good to change it, I've changed a few before and I have the disconnect tools and know to pull the fuse to the pump to relive the fuel pressure.
Thanks for the help guys!
cyearns is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-01-2007, 05:56 PM   #2
chris2002
Vehicle Specs
Quoted: 0 Post(s)
from the bottom of the vehicle about right where the passenger feet would be is a shroud held on with i believe 10m bolts. Very hard to see but that is where it is
chris2002 is offline   Reply With Quote
Old 01-01-2007, 06:09 PM   #3
cyearns
Grandview, MO
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
That's what I thought too and I started to take that off but the plastic from the wheel well and the running boards prevent it from coming off. It didn't look like anything was behind it. Is there a trick to taking it off?
BTW, they are 8 mm bolts. :-)
Old 01-01-2007, 06:56 PM   #4
chris2002
Vehicle Specs
Quoted: 0 Post(s)
sounds to me like you are close but in the wrong spot. Look inside the frame rail just forward of the fuel tank. Away from the wheel well and running board. Really close to the exhaust pipe you'll see a heat shield. That is where it is. If you look close you'll see the 2 red inlet lines. I have a pic and will post when i figure out how to do it.
Old 01-01-2007, 08:10 PM   #5
cyearns
Grandview, MO
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I'll be looking forward to the pic, thanks!
Old 02-02-2007, 02:27 PM   #6
97&67_Stang
Vehicle Specs
Quoted: 0 Post(s)
Ford's Procedure
Fuel Filter
Removal and Installation
1. Relieve the fuel pressure.
2. Raise the vehicle on a hoist.
3. Remove the fuel filter shield.
Remove the nuts.
Remove the shield.
4. Remove the fuel filter (9155).
Disconnect the fuel lines.
Remove the fuel filter from the fuel filter support.
5. To install, reverse the removal procedure.
I have Pictures - but cant figure out how to post them. Email me and I can forward them to you.
donnagel@msn.com
97&67_Stang is offline   Reply With Quote
Old 02-02-2007, 03:18 PM   #7
dlw992
Northwest, Ohio
2002 ELT Explorer
Vehicle Specs
Quoted: 0 Post(s)
Do you know if special tools are needed to disconnect the fuel lines attached to the filter on a 2002?
dlw992 is offline   Reply With Quote
Old 02-02-2007, 09:42 PM   #8
97&67_Stang
Vehicle Specs
Quoted: 0 Post(s)
Yes - if you email me I have pictures of the tools too.
DCN
Old 11-03-2009, 10:36 PM   #9
mjp3262
Rhode Island
02 XLT 4.6L V8
Vehicle Specs
Quoted: 2 Post(s)
Sounds like a stupid question and everyone just says relieve fuel pressure. So just how do you relieve the fuel pressure ?
mjp3262 is offline   Reply With Quote
Old 11-04-2009, 10:12 AM   #10
RickM
'02 Explorer 4.6 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
Quote:
This question is answered in the sticky at the top of the forum....best method seems to be to allow the truck to sit overnight and remove the gas cap in the morn when initiating the job.
Regarding the tool here is what seems to work best: http://www.explorerforum.com/forums/...2&postcount=49
RickM is offline   Reply With Quote
Old 11-04-2009, 07:03 PM   #11
mjp3262
Rhode Island
02 XLT 4.6L V8
Vehicle Specs
Quoted: 2 Post(s)
Taking the gas cap off is gonna relieve the fuel pressure built up from the fuel pump? That pressure is in the fuel lines, not in the gas tank right? How will removing the gas cap remove pressure in the fuel lines? That's what I mean, everyone says relieve the pressure but there doesn't seem to be a set way . I'm confused
Old 11-04-2009, 09:15 PM   #12
Limited02
Gardner, KS
Limited02's Avatar
'02 Limited V8
Vehicle Specs
Quoted: 99 Post(s)
Don't worry about relieving pressure, I changed mine 30 minutes after I drove it. You'll just need to keep your head out of the way when you pop the line off Don't break the red plastic tabs!!! Read the sticky and you should be set. Also, look under the passenger floorboard inside the frame rail. There is a tin looking shroud that protects it. Look for fuel lines and then you'll find it. Good luck!
__________________
"Spending money I don't have, on parts I don't need, to impress people I don't know"
Sold 12/31/2015 - 2002 4.6 4x4, K&N CAI, Henson tuned, FM70 and 20" Boss 306's
Limited02 is offline   Reply With Quote
Old 08-28-2011, 07:06 PM   #13
TThomason
Rochester, MN
2002 Ford Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
Dk Exp Fuel fileter and PVC Value 2002 Ford explorer
OK, I just spend 30 minutes + crawling under my explorer, 1). looking for the fuel filet, I bought one and thought it would be pretty easy. cannot find it, some say it is under the passenger side, outside to get to it?
2). The other is the PVC value, I took off the air filter and the big black cover of the carburetor, still can't find it. Anyone know where it is?
TThomason is offline   Reply With Quote
Old 08-28-2011, 08:19 PM   #14
tower
Millbury, MA
03 Limited centennial
Vehicle Specs
Quoted: 2 Post(s)
Well the PVC is on the drivers side valve cover on the end by the firewall, between the firewall and valve cover. You can't really see it but if you put your hand back there you will find it.
Now tell me where is the carburetor?
__________________
2002 XLT 4.0 Flex - yard truck
2003 Limited Centennial Edition
tower is offline   Reply With Quote
Old 08-29-2011, 12:59 AM   #15
Black Dynomite
Wellington, New Zealand
2005 Ltd 4.6L
Vehicle Specs
Quoted: 3 Post(s)
Instead of digging up an old thread over 2 years old, perhaps you could just use the stickied thread aptly titled Fuel Filter replacement w/pics. http://www.explorerforum.com/forums/...d.php?t=198626
And tower is assuming you have a 4.0. The PCV (not PVC) is on the passengers side valve cover if you have the 4.6
__________________
: K&N FIPK, 2.5" Cat Back w/ Turboflow Muffler, SCT Tuned, Underdrive Pulleys, EFan, 275/45 20, Stripped rack, Black Head/Corner lights, Black Mesh Grille Upper/Lower, Black Emblems, Amsoil fluids, TorquePro.
Ammo Box IED
Last edited by Black Dynomite; 08-30-2011 at 04:46 PM. Reason: Updated 4.6 PCV location for majority LHD owners.
Black Dynomite is offline   Reply With Quote
Old 08-29-2011, 11:01 AM   #16
esclamada
KCMO
'02 Mountaineer AWD V8
Vehicle Specs
Quoted: 28 Post(s)
on a 2002 4.6 V8, the PCV valve is on the passenger side valve cover, just below the air intake tube.
http://www.facebook.com/media/set/?s...2348605&type=1
MY MOUNTY
http://www.facebook.com/diyfordexplorer
esclamada is offline   Reply With Quote
Old 08-29-2011, 11:39 AM   #17
tower
Millbury, MA
Vehicle Specs
Quoted: 2 Post(s)
Quote:
And tower is assuming you have a 4.0. The PCV (not PVC) is on the drivers side valve cover if you have the 4.6
Yes I met for a 4.0
Oh and that thanks for pointing out a typo you are my hero
__________________
Old 08-29-2011, 02:16 PM   #18
dwcopple
bay city, MI
'04 Mounty
Vehicle Specs
Quoted: 0 Post(s)
*meant not met...now am I your hero too?
__________________
2004 Mercury Mountaineer Premier V8 AWD
modified airbox, 3rd cat delete, 2.5" custom cat-back exhaust with Flo-Pro baffle pack resonator and DynoMax Super Turbo muffler, roof rack delete, always Motorcraft filters.
dwcopple is offline   Reply With Quote
Old 08-30-2011, 01:38 PM   #19
tower
Millbury, MA
Vehicle Specs
Quoted: 2 Post(s)
Wow, you guys are excellent proof readers.
To answer your question NO.
__________________
Old 08-30-2011, 04:44 PM   #20
Black Dynomite
2005 Ltd 4.6L
Vehicle Specs
Quoted: 3 Post(s)
Actually tower, to be fair, the typo originally belongs to TThomason. But I dont mind a bit of hero worship now and then, just dont get too carried away. Baked goods on the doorstep is fine.
__________________
Ammo Box IED
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
