Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Ranger - Mazda B-Series Forum > Ford Ranger - Mazda B-Series Forum
Notices
Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well.
Dome light staying on when door is closed
Reply
Thread Tools
Old 01-14-2007, 02:04 PM   #1
99ranger2.5l
Hamilton,OH
99 xlt ranger
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Question Dome light staying on when door is closed
I own a 99 2.5l ranger 5 speed, Only sometimes when i close my passenger door the dome light stays on...what can i do about this? and i have no clue where the sensor to the door being shut is...have looked and looked
help please
99ranger2.5l is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-14-2007, 02:35 PM   #2
prerunner02
Sacramento, CA
'02 XLT 4X4 V8
Vehicle Specs
Quoted: 0 Post(s)
the switch is integrated in the latch
prerunner02 is offline   Reply With Quote
Old 01-14-2007, 03:09 PM   #3
MyRanger4x
NJ
1994 Ranger XLT
Vehicle Specs
Quoted: 0 Post(s)
You may find the answer you are looking for in the thread called "Cab Light". It was only the 10th thread down in the Ranger forum when I posted this message.
__________________
1994 Ford Ranger Super Cab - 4.0L V-6, custom paint, 4-inch Trailmaster suspension lift, 2-inch Trailmaster body lift, Eagle Alloy wheels, 35-inch BFG Mud-Terrains, dual exhaust (Flowmaster)...more
MyRanger4x is offline   Reply With Quote
Old 01-14-2007, 05:51 PM   #4
99ranger2.5l
Hamilton,OH
99 xlt ranger
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
thank you..i kind of figured it was but really didn't know for sure
Old 01-14-2007, 07:13 PM   #5
MyRanger4x
NJ
1994 Ranger XLT
Vehicle Specs
Quoted: 0 Post(s)
Good luck, hope that works for you.
__________________
Old 01-21-2007, 12:03 PM   #6
Ranger Al
Fresno, California
'00 FX4 Ranger
Vehicle Specs
Quoted: 0 Post(s)
I had the same problem. The driver side door latch seem to be the most prone to this problem. I guessed everytime the truck is being use you need to open the driverside door. I tried spraying with electrical cleaner, silicone sprayer and as well as WD 40. They were all temp fix. There only two ways to fix this, go to the dealer and buy another latch and hope it will last till you sell the truck or just cut the wire going to the switch and tape up the wire. If you ever want to use the light on the dome just turn the on the switch above your head or if you have passenger the passenger door will turn on the light. I chose option 2 which work very well for me.
Ranger Al
__________________
1. XLT Ranger 4dr 4.0 5 spd 4X4-> K&N filter, grill insert, Stainless steel skid plate, 98 Mountaineer front axles swap, factory motor transplanted and new clutch kit, 3" Flowmaster 40 dual outlet, hard bedcover, JamesDuff traction bars, Bilstien shocks.
2. 1999 K1200RS BMW motorcycle <fast German technology>
3. 2005 Suzuki XL 7, the only small SUV with 7 passengers I could effort under $15K
4. 1970 VW project -needs exhaust, interior, extrical parts..
Ranger Al is offline   Reply With Quote
Old 01-25-2007, 09:05 PM   #7
rd_turbo
Mississauga, ON
'98 B3000 4X4
Vehicle Specs
Quoted: 0 Post(s)
WD40 worked like a champ on both sides for me. I'd opt for that first, even if you have to do it a couple of times. I wasn't concerned about the excess running down or into the door...it can only do the body good
__________________
'98 B-Series 4WD MT
'94 Mazda RX7 TT, MT
'01 Sport Trac 2WD AT - Sold
rd_turbo is offline   Reply With Quote
Old 12-09-2009, 10:53 PM   #8
CaymanGreen
Pittsburgh
'97 Ranger 4.0 XtCab 5spd
Vehicle Specs
Quoted: 0 Post(s)
WD40 worked for me six yrs ago, and I haven't had to repeat it.
CaymanGreen is offline   Reply With Quote
Old 12-11-2009, 12:10 PM   #9
5.0
In the Middle
'97 Ranger 5.0
Vehicle Specs
Quoted: 0 Post(s)
Holy old thread!
Is the switch itself not replaceable? Or do you need the whole latch assembly?
5.0 is offline   Reply With Quote
Old 12-11-2009, 05:14 PM   #10
CaymanGreen
Pittsburgh
Vehicle Specs
Quoted: 0 Post(s)
They're replaceable, but given the choice between buying the switch and then tearing the door apart to swap it out vs. a short spraying with WD40...
As an experiment I tried the same approach on my turn signal switch a couple wks ago - it's acted erratic/sluggish/nonfunctional in cold weather for the last couple yrs till the cab warms up, and all the posts I could find here talked about replacing the switch. So far it's acting completely normal. Wahoo!!
Old 12-14-2009, 07:12 AM   #11
Moranger1
New Brunswick Canada
06' Ranger Sport
Vehicle Specs
Quoted: 0 Post(s)
Hi Folks, I'm new to this.
My 2006 Ranger has had this problem for awhile now, the door ajar light comes on as I'm driving or going around corners, had a close look at it today and it seems that the rear drivers door is not latching at the bottom. Tried the wd40 and antiseize, lots of rust draining out (not good!) but still not latching. Any hints?
Moranger1 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
