Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
How tight do I make the wheel bearing nuts??
Reply
Thread Tools
Old 07-26-2000, 02:45 PM   #1
Empty Pockets
Smithtown, NY (Long Island)
'04 EB V8
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Question how tight do I make my front wheel bearing nuts?
On my '94 EB there's a keyway on the front wheel bearing nuts and it seems like the slots make it either too tight or too loose.
What do you think I should do?
[Edited by Empty Pockets on 07-26-2000 at 12:49 PM]
Empty Pockets is offline   Reply With Quote
( Join the Elite Explorers )
Old 07-27-2000, 04:26 PM   #2
ExploreMinnesota
Rochester, Minnesota
1991 Eddie Bauer 4x4
Vehicle Specs
Quoted: 0 Post(s)
After Packing the bearings and installing them, you should initially tighten them very tight. Don't leave them like that though. Back them off just enough to allow the wheel to turn nicely . . . not too lose, but not too tight either. From there, use the closest key slot.
Hope that helps.
__________________
ExploreMinnesota
91 EB 4x4 Stock
92 XLT 4x4 Stock
2008 EB 4x4 Stock
ExploreMinnesota is offline   Reply With Quote
Old 07-27-2000, 09:42 PM   #3
Brian1
Albuquerque, NM
Brian1's Avatar
1991 XLT
Vehicle Specs
Quoted: 89 Post(s)
I think it is like this: tighten it to 35 ft# and then back it off 90 degrees. Then re-torque to 16 ft#. This is for if you have manual hubs. I think the autos are probably the same.
Brian1 is online now   Reply With Quote
Old 07-27-2000, 11:25 PM   #4
Ira
Northeast Tennessee
91 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
I still have the auto hubs on mine, and thought I would never get it straightened out. Every time I torqued mine according to the book, and the way they explained above, my wheel still felt loose. I could grab the wheel at the top and bottom and it would still have wobble in it. I finally tightened it one slot in the keyway farther than you would think it should be, and it took care of the problem.
Hope this helps.
__________________
Ira
91 XLT 4x4
You're just jealous because the voices only talk to me.
Ira is offline   Reply With Quote
Old 07-27-2000, 11:32 PM   #5
Waverider
Washington, NC
'93 XLT
Vehicle Specs
Quoted: 0 Post(s)
With the Wheel Bearing nut you tighten it firmly and back off just enough to get the lock pin in. Remember to pack the mess out of the bearings.
Waverider is offline   Reply With Quote
Old 07-28-2000, 07:30 AM   #6
Empty Pockets
'04 EB V8
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thumbs up Thanks guys
This all makes sense, that's what I did it just still feels too loose. I guess that's the way to go.
Old 06-19-2011, 04:55 PM   #7
crispy925
Chicago
96 Ranger XLT
Vehicle Specs
Quoted: 0 Post(s)
ball play
After I replaced my ball joints (which can cause play when you grab the top and bottom of the wheel and shake) on the front axle, I had to put the spindle nut back one.
BEFORE you put the brake rotor on, make sure to feel how much play there is when you shake the wheel. Shaking the hub up and down will show how much play there is in the ball joints, while shaking the hub side to side will show how much play there is in the steering joint.
crispy925 is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
how tight to torque wheel bearing nut? HeyZeus Elite Explorer 911! 7 06-23-2008 12:26 PM
Wheel bearing replacement? bigdaddykarl Offroad Drivelines 13 02-03-2004 08:51 PM
blew out wheel bearing. kontinu1 Ford Explorer - Ranger Tires & Wheels 1 04-22-2003 11:32 PM
How tight do I make the front wheel bearing nuts?? Empty Pockets Ford Explorer - Ranger Tires & Wheels 1 07-27-2000 12:16 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
