Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > 2006 - 2010 Explorer Mountaineer > Stock 2006+ Explorers
Notices
Reply
Thread Tools
Old 02-08-2007, 09:48 PM   #1
msams89
Cincinnati, OH
'04 XLT, '07 XLT ironman
Vehicle Specs
Heater producing enough heat?
Hi,
I just picked up my '07 Explorer last Friday. I must say this is a nice vehicle. I do have to remark on the heater. When I have it set to blow only on my feet, it feels as if it is hardly coming out. Is this correct?
As I recall, my '04 Explorer could chase you out of there. The new one won't.
TIA.
msams89 is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 02-09-2007, 12:05 AM   #2
shaker1
Algonquin, IL
2006 Explorer XLT 4X4 4.0
Vehicle Specs
My V-6 generates heat very quickly and it gets plenty hot. With the temps here around -5 it will be fully warmed up in less than 5 minutes.
However, if it is set to "floor only" it seems rather weak. But the center dash vents will get plenty hot.
shaker1 is offline   Reply With Quote
Old 02-09-2007, 07:02 AM   #3
msams89
Cincinnati, OH
Vehicle Specs
Thanks for the reply. I'll give the center vents a shot this morning.
Mine is a V8 by the way. I don't think that should matter too much.
Old 02-09-2007, 10:11 AM   #4
BBinNH
Exeter NH
2006 XLT
Vehicle Specs
Heat on floor
I have an 2006 w/V8, and I have noticed the same thing - not enough heat on floor when just set to floor
BBinNH is offline   Reply With Quote
Old 02-12-2007, 12:16 PM   #5
V8Pete
Cupertino, CA
'06 XLT 2WD V8
Vehicle Specs
Here, too. I notice I also have to crank the temp dial to at least 12:00.
__________________
'06 XLT 2WD V8, Gibson exhaust, K&N drop-in, modified airbox, TSW Bremma 18 x 8s, Toyo Proxes S/T II 255/60s, '02 XLT rocker moldings, debadged
'06 Dodge Magnum SRT8
Sold at 182K miles: '96 XLT V8 2WD, bunch o' mods
V8Pete is offline   Reply With Quote
Old 02-14-2007, 08:55 AM   #6
oconnells
Chesapeake, VA
07 XLT
Vehicle Specs
I have also noticed the same thing. I think the problem is that unlike other cars I've owned the heat is coming from further down the side of the center console, and not from vents closer to the firewall where your feet normally are. My wife in the passenger seat will generally keep her feet closer to the car seat, and complains that it gets very hot.
__________________
2007 Explorer XLT(Redfire Metalic with appearance package)
1999 Ford Mustang GT Conv.
oconnells is offline   Reply With Quote
Old 02-15-2007, 11:28 PM   #7
shaker1
Algonquin, IL
Vehicle Specs
Quote:
Originally Posted by oconnells View Post
...I think the problem is that unlike other cars I've owned the heat is coming from further down the side of the center console, and not from vents closer to the firewall where your feet normally are...
That is exactly what I think too! Also, the dash vents closest to the doors are kind of weak for some reason.
Old 02-22-2007, 10:01 PM   #8
steve6534
Mount Holly, NJ
'06 EB V8
Vehicle Specs
Has anyone else with the automatic climate control noticed that after the cabin is in the set temperature range the lower console (floor) vents continue to blow warm air softly but the window defrost vents blow ice cold air ? This is pretty annoying as your arm starts to freeze ! I wasn't sure if this was a design thing or if I have something wrong going on.
Steve
steve6534 is offline   Reply With Quote
Old 02-22-2007, 10:24 PM   #9
trucku
Queens, New York
trucku's Avatar
2002 Explorer XLS 4.0 4x4
Vehicle Specs
I used to have weak heat or air out of the center console going to the back. My wife and daughter was either never getting enough heat or cold.When working on my truck and pulled the console and noticed the foam they used to but up two pieces of ducting shrunk pretty good and moved. So I was loosing air into the center console. I stuffed all the open seams with rolled up napkins (what I had at moment) and air out the back is great. Maybe this could be the same issue??? I know its a new truck maybe the something is loose and air is escaping someplace else.
my half cent...
__________________
2002 XLS 4.0 SOHC 4x4. Frantz Bypass filter, Mobil 1 5W30.Perma-cool dual remote (2 full flow PureOne PL30001). Perma-cool remote transmission filter (Pure One PL30001). Scanguage II, Sunpro Oil Pressure Guage
Gen 4 mirrors
"The More Complex The Mind, The Greater The Need For The Simplicity Of Play"
trucku is offline   Reply With Quote
Old 02-23-2007, 09:21 AM   #10
steve6534
Mount Holly, NJ
'06 EB V8
Vehicle Specs
Quote:
my half cent...
In my case I don't think this is the issue. The air is definitely coming from the system (blows harder when the fan speed is increased) and the air is warm before the truck is warmed up inside. It almost acts as if there's an additional blend door just for the defrost vents.
Steve
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
Copyright 2010 - 1996 Rick Horwitz Photography
