#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
How To: Installing a Transmission Temperature Gauge
Reply
Thread Tools
Old 02-21-2007, 11:37 AM   #1
ExploringNC
Hickory, NC
'98 XLT, '91 EB
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Parts needed and cost:
SunPro Water/Oil Temp Guage(Advance Auto) $16.96
3/8 Galvanized Tee $3.50+/-
3/8 Flare(male)/3/8 Pipe Thread(male) Connector $1.49 x2
3/8 Flare Nut $ .79 x2
Wire splice connector
Tools Needed:
Drill
Tubing Cutter
Tubing Flare Tool
In this pic I have fittings to connect to the rubber hose coming from secondary cooler. This location did not give very accurate reading so I moved location of sensor to before main radiator.
Remove center console compartment area by just it pulling up. Drill hole in upper compartment large enough to get sending unit threw. Run cable and wires threw hole and mount guage. On '98 XLT there is a wire harness connector behind console compartment. Locate red wire with black strip, this goes to dimmer switch. Use a wire splice connector and attach red wire from guage to the red w/black strip wire. Attach ground wire from guage to metal bracket that holds side of center console. Run cable from guage threw back of console and out by gas pedal.
Run cable up and over brake pedal and steering column. Locate where emergancy brake cable goes threw firewall. Remove rubber gromet from firewall and make a small cut, run sending unit and nut threw gromet.
Locate where cable went threw firewall under the hood. Look directly under brake master cylinder. Pull excess cable threw firewall (you may want help feeding cable from inside so as not to kink line).
Remove tranny lines from radiator, you need to remove both so you can pull upper line up enough to cut. You may want to use a small pan to catch tranny fluid that will leak from lower line. With tubing cutter cut upper line about 3in from lower bend. On lower part of line that was just cut cut again about 2in down.
On both ends of line install Flare Nut and use flare tool for 3/8 tubing and flare ends. Lowe's has flare tool for around $10.
Use pipe tape on all threads. Insert the 3/8 Flare(male)/3/8 Pipe Thread(male) Connector into tee. Insert 3/8 adapter that comes with guage for the sending unit. Install tee on lower line and then install upper part of line onto tee. Reattach tranny lines to radiator. Insert sending unit into tee (be carefull not to overtighten, adapter that comes with guage is very soft brass, I stripped it and had to but another guage just for the adapter). Use wire ties to secure cable from guage.
Go for a short drive to warm transmission and check level of tranny fluid.
Let me know if this is helpfull and if I need to change anything.
__________________
'91 EB 4.0 OHV 4x4
31x10.5 Maxxis Bighorn's
Uwharrie 2010
BrooklynBay's List of Useful Threads
ExploringNC is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-21-2007, 12:38 PM   #2
Xpl0rer
Ionia,Mi
92 Xplorer xlt 168k
Vehicle Specs
Quoted: 0 Post(s)
nice write up man ill be doing this after i get my tranny situation under control...
Xpl0rer is offline   Reply With Quote
Old 02-21-2007, 12:52 PM   #3
Gatorblazer
Moody, AL
Gatorblazer's Avatar
2002 Explorer, 2004 MPV
Vehicle Specs
Quoted: 3 Post(s)
Maybe Im missing something, but you say to install flare fittings, but Im looking at barb fittings in your pics. Using these barb fitting, couldnt you install this temp gauge in line with the aux cooler. Mine are done with rubber hose so....
__________________
Remember, some people are alive simply because it is illegal to shoot them.
southernhammockcamping.com
Gatorblazer is offline   Reply With Quote
Old 02-21-2007, 02:02 PM   #4
rookieshooter
Moderator Emeritus
Martinsburg WV
rookieshooter's Avatar
84 BII "Li'l Samson"
Vehicle Specs
Quoted: 2 Post(s)
Where you have the sensor, is that in the line that goes back to trany or coming from trany?
__________________
"2013,2012 & 2011Truck Nationals" At Carlisle Extreme 4x4" First Place winner.
2013,2012,2011 All Ford Nationals winner. 2X first 1X second
Featured in 2012 Bronco Driver Mag.
Petersen's 4Wheel mag ROTM. Voted 2008 Bronco II of Year
rookieshooter is offline   Reply With Quote
Old 02-21-2007, 06:11 PM   #5
Gatorblazer
Moody, AL
Vehicle Specs
Quoted: 3 Post(s)
http://www.explorerforum.com/forums/...ion+temp+gauge
Ok, it can be done either way it looks like.
__________________
Old 02-21-2007, 06:23 PM   #6
Glacier991
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Vehicle Specs
Quoted: 4 Post(s)
THANKS. I always appreciate a good photo illustrated how to thread !!
Gonna sticky this a bit to insure it gets adequate exposure for the work you put into it!
Glacier991 is offline   Reply With Quote
Old 02-22-2007, 02:40 AM   #7
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Nice write up! Why did you use a galvanized tee instead of a brass tee? All of the fittings going into it are brass.
BrooklynBay is offline   Reply With Quote
Old 02-22-2007, 09:44 AM   #8
ExploringNC
Hickory, NC
'98 XLT, '91 EB
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
I explained in thread that I first installed it at the secondary cooler but could not get an accurate reading(temp. was too cold on the downside of both coolers to get reading on guage). I moved it upstream of the radiator and know I get the temp coming out of the tranny.
I had to use the galvonized tee in order to get clearence for the sending unit to allow better flow threw the tee. The 3/8 galvonized tee is bigger than the 3/8 brass tee.
__________________
'91 EB 4.0 OHV 4x4
Uwharrie 2010
Old 02-22-2007, 10:06 AM   #9
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 653 Post(s)
Quote:
Yeah, the brass "probe manifold" T is an expensive part--about 25 bux, It has to have a real deep center neck for the probe.
Good idea!!!!
__________________
Jon
9 mile skid, on a ten mile ride. Hot as a pistol but cool inside.
2000 Mountaineer
1998 Mountaineer "Turdle"-gone
1993 Convertible "Vitamin D Wagon" Sold also
Turdle is offline   Reply With Quote
Old 02-22-2007, 10:40 AM   #10
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 380 Post(s)
They make extension couplings which could be used, but they add to the cost, and bulk of the project.
Old 02-22-2007, 10:56 AM   #11
trucku
Queens, New York and living in Budd Lake, NJ now.
trucku's Avatar
2002 Explorer XLS 4.0 4x4
Vehicle Specs
Quoted: 0 Post(s)
Great write up.
__________________
2002 XLS 4.0 SOHC 4x4. Frantz Bypass filter, Mobil 1 5W30.Perma-cool dual remote (2 full flow PureOne PL30001). Perma-cool remote transmission filter (Pure One PL30001). Scanguage II, Sunpro Oil Pressure Guage
Gen 4 mirrors
"The More Complex The Mind, The Greater The Need For The Simplicity Of Play"
trucku is offline   Reply With Quote
Old 02-22-2007, 11:17 AM   #12
Positive Vibes
Santa Cruz, Ca
Positive Vibes's Avatar
'94 XLT
Vehicle Specs
Quoted: 0 Post(s)
Great write up! Love the pics!
__________________
'94 XLT, 5.5" superlift, cat back flowmaster, KKM, custom rocksliders, 33X12.5 XTerrains, 4.10's, custom bumpers, Detroit in 8.8, on board air, ARB locker in front winch,etc.
What is greater than God, More evil than the devil, The poor have it, The rich need it, And if you eat it, you'll die?
Positive Vibes is offline   Reply With Quote
Old 03-01-2007, 07:02 PM   #13
colindo94
Cameron Park, CA
94' XLT
Vehicle Specs
Quoted: 0 Post(s)
Good write up. Mines going in once I finish the tranny leak. Would the pan have a more accurate reading then in the tranny line like your set up.
__________________
Full width Dana 44/8.8, 36x12.5 TSL radials
Ostman Bros. Fab Shop
colindo94 is offline   Reply With Quote
Old 03-01-2007, 08:31 PM   #14
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 380 Post(s)
The pan would be more accurate but it requires more work to install the sensor.
Old 03-01-2007, 08:40 PM   #15
dirtyXplorer
Arizona and Colorado
93 XLT 4dr
Vehicle Specs
Quoted: 1 Post(s)
ExploreingNC, Is the gauge you used mechanical or electric? Great deal for $16
__________________
93' X on 35" MTRs
FOR SALE!Here
93 TOY 4runner....the DD
dirtyXplorer is offline   Reply With Quote
Old 03-01-2007, 08:42 PM   #16
MountaineerGreen
Towing Moderator
North East Arkansas
MountaineerGreen's Avatar
2012 F150 4x4
Vehicle Specs
Quoted: 8 Post(s)
I'm guessing it is mechanical- the cable that goes from the gauge looks pretty big. Mine is electric, didn't include a cable or wire, I had to run my own.
MountaineerGreen is offline   Reply With Quote
Old 03-12-2009, 08:30 AM   #17
wingnutt550
Cresent Beach FL.
1996XLT 4X4, 2006 LIMITED
Vehicle Specs
Quoted: 0 Post(s)
Transmission temp?
It looks like you have it figured out. What is the avreage temp the transmission should run at? I will be pulling a trailer with my 96 4 X 4,anyone know what is concidered a safe max temp would be?
thanks, Steve
wingnutt550 is offline   Reply With Quote
Old 03-12-2009, 09:20 AM   #18
ExploringNC
Hickory, NC
'98 XLT, '91 EB
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
thanks, Steve
Somewhere on this site they is a chart but I can't find it right now. I think normal temp. is 150-190.
__________________
'91 EB 4.0 OHV 4x4
Uwharrie 2010
Old 03-12-2009, 11:11 AM   #19
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 2 Post(s)
many race trucks/cars or hotrods will run a before and aft trans temp sensor, so you can see the temp in the pan, then aft the coolers, to get an idea of how well its being cooled
Your 96+ trucks have a factory trans temp sensor in the pans, with the correct electric gage you can tap into the stock wire, no need to add a sensor to your pan.
I did it anyway LOL I use the port for my pan temp sensor as a drain plug also
Nice work!
$20 peace of mind = priceless!
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 04-13-2009, 07:10 PM   #20
wingnutt550
Cresent Beach FL.
Vehicle Specs
Quoted: 0 Post(s)
well I purchased a B&M gauge kit, it came with sender, wire, T-adpter fitting and a plastic gauge mount the blended well on the steering collum. The instructions for mounting the sender has it going in the return line, the phone tech at B&M states that is the closest in accuracy to pan mounting. what I have found for temp is as follows; ambient air temp is 75 to 78deg and not pulling a trailer, after about 5 miles of warm up the temp comes up to about 125deg. and that is speeds around town less than 45mph. On the highway at 65 to 70 or a constant speed of 55 and above it drops to right at 100deg. My gauge readings are close to accual pan temp I checked the pan temp with a infered temp gun after pulling in to the garage and it shows about 135 deg. My question to the trany tech's out their is; I under stand that my coolers are working "testing the return fluid" but if my coolers, the factory one in the radiator and the aftermarket one I installed are reducing fluid temp to 125deg. What temp does the transmission heat the oil to and shouldn't that be a more accurate measure of oil wear tear. After all if the cooler scrubs 200deg off of the temp the oil still gets burnt. After all if you burned your french fries and cooled the oil your next batch of fries will still taste burnt. I am going to set up a sender on the transmission output line and will let you all know what readings i get. If anyone has already tried this please let me know what readings you have found.
thanks, steve
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
