#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger - Computers, Chips, Tuning
Notices
Explorer, Ranger - Computers, Chips, Tuning Programmers, chips, modules, dyno tuning for the Ford Explorer, Ranger, Mercury Mountaineer, Bronco II and Mazda Navajo.
drive cycle to clear computer
Reply
Thread Tools
Old 02-22-2007, 07:43 PM   #1
JJScorpio
1997 and 1999 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Does anyone know what the drive cycle is to clear the computer to get the vehicle inspected? I fixed the problem that kicked on the check engine light, and need to cycle it to get the light off to pass. Is there a shortcut?
JJScorpio is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-22-2007, 09:08 PM   #2
ExplorerDMB
Moderator/Technician
Mechanicsville, Virginia
2004 Acura TL
Vehicle Specs
Quoted: 0 Post(s)
Nope - all the monitors have to run. They will go in with the scanner and make sure all the monitors ran. Just drive it about 500 miles
-Drew
__________________
My Useful Threads (38 Entries and Growing)
ExplorerDMB is offline   Reply With Quote
Old 02-22-2007, 11:19 PM   #3
JJScorpio
1997 and 1999 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thx for the reply. I have an appt for an inspection tomorrow and was hoping that someone from Ford had leaked a shortcut, lol. All I can get for info is you have to drive a certain amt of miles at 55, so many under 40 and that stuff. I guess I will just keep driving....Sorry for the double post. I wasn't sure which forum to put the question in...
Old 02-23-2007, 06:25 AM   #4
NHale623
Eliot, Maine
95 XLT
Vehicle Specs
Quoted: 0 Post(s)
Quote:
How do you know you fixed the problem that set the CEL?
__________________
1995 Explorer XLT 4 Door
1931 Model A Tudor Sedan
NHale623 is offline   Reply With Quote
Old 02-23-2007, 03:37 PM   #5
JJScorpio
1997 and 1999 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I wanted to post this on here because a Ford technician was nice enough to give me this information. Here is what needs to be done to load all the parameters in your computer so your vehicle will pass inspection after your check engine light problem has been fixed. This will work for all explorers 1996 and up. Here is what you do. This will save you from having to drive 3 or 4 hundred miles to load the computer.....
1. The gas has to be between 1/4 and 3/4 full. Not above or below.
2. Start the vehicle and put it in drive and hold the brake.
3. Turn on the air conditioner and the rear defroster.
4. Sit in drive for 2 minutes.
5. Turn off AC and rear defroster.
6. Drive the vehicle up to 55 mph.
7. Decellerate down to 20 MPH, do not touch the gas or the brake.
8. You must do this 3 times and let the vehicle get cold between cycles.
I did this today and my vehicle passed inspection. I hope this helps others that need to get their rigs inspected and dont want to drive around for a couple hundred miles.....
Old 02-23-2007, 03:38 PM   #6
JJScorpio
1997 and 1999 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
If the problem is not fixed, the check engine light will kick back on again....
Old 08-06-2009, 11:43 PM   #7
partimer
96
Vehicle Specs
Quoted: 0 Post(s)
I had an exhaust put on my 96 Explorer and now the check engine light is on.
I'll give this a try before the inspection, Thanks
partimer is offline   Reply With Quote
Old 08-07-2009, 11:42 PM   #8
partimer
96
Vehicle Specs
Quoted: 0 Post(s)
Update -
It worked and the light is off
THANK YOU !!
Old 04-14-2012, 11:00 PM   #9
NJ99Explorer
New Jersey
1999 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
The manual states
In some localities, it may be a legal requirement to pass an I/M test of
the on-board diagnostic (OBD-II) system. If your “Check Engine/Service
Engine Soon” light is on, refer to the description in theWarning Lights
and Chimessection of theInstrumentationchapter. Your vehicle may
not pass the I/M test with the “Check Engine/Service Engine Soon” light
on.
If the vehicle’s powertrain system or its battery has just been serviced,
the OBD-II system is reset to a “not ready for I/M test” condition. To
ready the OBD-II system for I/M testing, a minimum of 30 minutes of city
and highway driving is necessary as described below:
²First, at least 10 minutes of driving on an expressway or highway.
²Next, at least 20 minutes driving in stop-and-go, city-type traffic with
at least four idle periods.
Allow the vehicle to sit for at least eight hours without starting the
engine. Then, start the engine and complete the above driving cycle. The
engine must warm up to its normal operating temperature. Once started,
do not turn off the engine until the above driving cycle is complete.[
B][/B]
NJ99Explorer is offline   Reply With Quote
Old 11-20-2013, 01:37 AM   #10
Trip966
Northfield, MN
1999 Explorer Limited
Vehicle Specs
Quoted: 0 Post(s)
I have access to complete drive cycle through M+. PM email and I can send entire thing
Trip966 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
