Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Fuse and relay locations--2nd generation power distribution box Layout-
Closed Thread
Thread Tools
Old 03-02-2007, 12:08 PM   #1
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 685 Post(s)
(Original Poster)
I think this is a good sticky candidate--
Fuses are listed here
* = maxi fuse
1*=50A I/P fuse panel
2*=40A blower motor relay
3*= 50A 4 wheel ABS module
4*=20a Main light switch-Instrument cluster
5*=50A Ignition switch, starter relay
6*=20A Transfer case relay
7*= NOT USED
8*=20A Auto Ride Control Switch/on off switch
9*=40A Auto Ride Control relay
10*=30A PCM power relay
mini fuses
1=10A A/C relay
2=20A Aux power point
3= not used
4=15A Fog lamps-Daytime lamps
5=10A Air Bag diagnostic monitor
6=10A Powertrain Control Module (PCM)
7=30A 4WABS module
8=30A PCM relay
9=20A Fuel Pump relay and RAP module
10= 15A Horn relay
11=15A Park Lamp relay-Main Light Switch
12=30A Main light switch--Multi Function switch
13=15A Heated O2 sensors, EGR Vacuum Regulator, EVR solenoid,Camshaft position (CMP) Sensor,
Cannister Vent Solenoid, A4LD Auto Transmission
14=30A Generator-Voltage regulator
Interior fuse panel (mini fuses)
1=7.5A Power mirror switch
2=7.5A Blower motor relay,PAD module,Air Bag diagnostic monitor
3=7.5A Trailer tow connector
4=10A Left headlamp
5=10A Data link connector (DLC)
6=7.5A Air bag diagnostic monitor, Blower motor relay, Passive deactivation Module (PAD)
7=7.5A Trailer Tow connector
8=10A Right headlamp, Daytime running lamps (DRL) module, Foglight relay
9=7.5A Stop Lamp switch
10= 7.5A Speed control-amplifier assembly,Brake pressure switch, Generic electronoc Module (GEM)
Shift lock actuator, Blend door actuator, Main light switch, RABS resistor, A/C heater assembly
Flasher
11= 7.5A Instrument cluster, Main light switch, RABS resistor
12= 10A Power window relay, Washer pump relay
13= 20A Stop lamp switch, Brake pressure switch
14= 20A Rear Anti Lock Brake system (RABS) module
**10A 4WABS module**
15=7.5A Instrument cluster
16= 30A Windshield wiper Motor, Wiper Hi-lo relay, wiper run/park relay
17=7.5A Cig lighter
18=15A Drivers unlock relay-All unlock relay
19=25A PCM power diode
20=7.5A RAP module GEM module, Radio
21=15A Flasher (hazard)
22=20A Aux power socket
23=15A Turn signals
24===not used
25= 7.5A GEM module, Instrument cluster
26= 10A Battery saver relay, Electronic Shift relay, Interior lamp relay
Power window relay,Electronic shift control module, transmission control
27=15A Switch,DRL, Backup lamp switch, DTR sensor,Instrument illumination dimming control module
Dome/map lamp, GEM,electronic shift,Interior lights,Glove box lamp and switch
28=7.5A GEM module-Radio
29= 15A Radio
30=15A Park lamps, trailer Tow relay
31===not used
32=10A rear blower
33=15A Headlamps, DRL module, Instrument cluster
34=7.5A Rear integrated control panel, CD
35=10A RABS test connector
36=7.5A CD, rear integrated control panel, memory seat, Message center
__________________
Jon
9 mile skid, on a ten mile ride. Hot as a pistol but cool inside.
2000 Mountaineer
1998 Mountaineer "Turdle"-gone
1993 Convertible "Vitamin D Wagon" Sold also
Turdle is online now
( Join the Elite Explorers )
Old 03-02-2007, 06:19 PM   #2
ExplorerDMB
Moderator/Technician
Mechanicsville, Virginia
2004 Acura TL
Vehicle Specs
Quoted: 0 Post(s)
Description of the fuses?
-Drew
__________________
My Useful Threads (38 Entries and Growing)
ExplorerDMB is offline
Old 03-02-2007, 06:32 PM   #3
CDW6212R
Knoxville, TN
CDW6212R's Avatar
98 Mountaineer AWD
Vehicle Specs
Quoted: 211 Post(s)
There are two boxes for 95-01's, my 99(narrower) is different than my 98 model.
__________________
Don
91 Lincoln LSC/SE/GTC, 99/93 Explorer Limited 4WD, 98 AWD Mounty, 98 Limited with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors.
The best thing that could help us all, is the Fair Tax Plan.
Be American, Buy American (Manufacturer)
CDW6212R is online now
Old 03-02-2007, 06:36 PM   #4
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 3 Post(s)
the later ones have the starter solenoid built into them dont they? The 96-95 has the fender mounted solenoid
the 98 Mounty I parted out had a diff box so I think its 95-96 are same,. 97+ diff
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline
Old 03-02-2007, 06:44 PM   #5
CDW6212R
Knoxville, TN
CDW6212R's Avatar
98 Mountaineer AWD
Vehicle Specs
Quoted: 211 Post(s)
The 99 starter solenoid is on my starter. The number of fuses and relays is similar, but my 98 harness had more odd relays elsewhere under hood.
__________________
Don
Old 03-04-2007, 11:35 AM   #6
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 685 Post(s)
(Original Poster)
Quote:
-Drew
I edited it--
This is from my 98---
__________________
Jon
2000 Mountaineer
Old 03-05-2007, 05:45 PM   #7
ExplorerDMB
2004 Acura TL
Vehicle Specs
Quoted: 0 Post(s)
I put it in the List of Useful Threads
-Drew
__________________
Old 08-03-2007, 10:45 PM   #8
TR_TX
Texas
1996
Vehicle Specs
Quoted: 0 Post(s)
Thanks sense blower motor works then I will need to begin checking out these do-hickies.
__________________
1996 Explorer SUV
V8 gas engine, = Mine
Husband - owns several Ford trucks
We always need answers to some question concerning Fords.
TR_TX is offline
Old 10-14-2007, 08:01 PM   #9
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 415 Post(s)
Sorry Jon. Looking back at the thread, it was for the 1st gen. Here's the thread: http://www.explorerforum.com/forums/...d.php?t=196294. The information is still useful.
BrooklynBay is offline
Old 10-14-2007, 08:05 PM   #10
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 685 Post(s)
(Original Poster)
I don't trust autozone's diagram's-if you look in the 98 explorer for example it mentions a WOT relay.
there is no such thing as a WOT relay, in a 2nd gen explorer anyway. lol
__________________
Jon
2000 Mountaineer
Old 10-14-2007, 08:09 PM   #11
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 415 Post(s)
I know that their diagrams are from Alldata. I guess any company could have printing mistakes. I saw in other threads quotes from Haynes, and Chilton manuals stating wrong bolt torque values, and relay, sensor, and battery locations.
Old 02-07-2008, 11:37 AM   #12
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 685 Post(s)
(Original Poster)
If you guys with 95,96,97,99,00,and 01 owners manuals could please scan and post the same in here, or email them to me-I'd sure appreciate it
Not to sound picky,(I am) but I don't want anything from an on line source here-I don't really trust them.
There are differences from year to year-and I think this would be very helpful.
Thanks
__________________
Jon
2000 Mountaineer
Old 02-07-2008, 04:18 PM   #13
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 685 Post(s)
(Original Poster)
Quote:
Originally Posted by Charlie View Post
Before I walk -all the way to my truck- and grab it, scan it, -walk all the way back- and put it back, is there anything else you would want scanned while it is here?
naw
thanks
\I'll delete these posts also-trying to keep this info tidy
__________________
Jon
2000 Mountaineer
Old 04-29-2008, 04:48 AM   #14
juggaloscorpio
Sherman, Texas
1995 XLT
Vehicle Specs
Quoted: 0 Post(s)
can someone scan in a pic and add description of the power dist. box and interior fuse box for 95 and 96 xlt thanks ahead of time
juggaloscorpio is offline
Old 06-11-2008, 05:59 AM   #15
jwrezz
Elite Snow Shoveler
Parsippany, NJ
jwrezz's Avatar
1996 XLT
Vehicle Specs
Quoted: 1 Post(s)
Here ya go:
__________________
John- 1996 XLT- newly Rebuilt 4.0 OHV .030 over, Comp Cams 49-422, BBK headers/TB, SCT/Bama tune, OME 2"springs/ TT & OME shocks, PA 3" body lift, 33*12.5*15 Kumho MT's
jwrezz is offline
Old 05-02-2009, 12:19 AM   #16
redlined_man
Southwest Wisconsin
1999 XLT
Vehicle Specs
Quoted: 0 Post(s)
I have read this post and thought I figured out my problem on my 1999 Explorer. However, when I plug my trailer lights into it my 3rd brake light comes on right away when I have the head lights on, and I have no left side blinkers or brake lights on my trailer but both tail lights work. Does anyone know why this could be happening? Any quick info would be great since I need to use my trailer in about 12 hours. Thanks in advance.
redlined_man is offline
Old 05-02-2009, 08:16 AM   #17
jwrezz
Elite Snow Shoveler
Parsippany, NJ
jwrezz's Avatar
1996 XLT
Vehicle Specs
Quoted: 1 Post(s)
Do the explorer's lites work fine when the trailer harness is NOT plugged in? If so, it sounds like something is shorting in the harness only. Or maybe even a mismatched harness? Seems like the tail lites are shorting to your 3rd break lite some where in there, and break/blinkers are not even reaching the trailer. Do the explorers signals/break lites work w/ the harness plugged in and headlamps off? This just seems like a bad harness, or improper harness installation.
__________________
jwrezz is offline
Old 05-03-2009, 10:29 AM   #18
redlined_man
Southwest Wisconsin
1999 XLT
Vehicle Specs
Quoted: 0 Post(s)
Thanks for the reply jwrezz. It was really odd on how i got it fixed, I had to replace the #7 fuse, which was blown, and that got me to the problems that I explained in the above post. I then took the wiring off the tow dolly and started over, since everything seemed to work great at the pigtail on the Explorer. I found some bad spots in the wiring on the dolly so I replaced that and still had no brake lights or turn signals on the right side with the headlights on. Just on a thought I replaced the right 1157 bulb on my dolly and now everything works great. There was also a bad ground so I got a better ground and everything is good. Thanks again for the reply.
Old 06-06-2009, 05:27 PM   #19
bilbo99
Redding, Ca
2000 EB
Vehicle Specs
Quoted: 0 Post(s)
2000 Ford Explorer Eddie Bauer Fuse Pages
I have been trying to trace a dead DLC (Data Link Connector or OBD-II port) and saw people were posting scans of their owners manual fuse info.
I have a 2000 Ford Explorer Eddie Bauer with 5.0 V8 and here are the pages...#192-199 in my manual:
Sorry, not the best scanner...
bilbo99 is offline
Old 12-06-2009, 01:07 AM   #20
ivrb
southern cal
2000 xls
Vehicle Specs
Quoted: 0 Post(s)
other fuse box
my 2000 has another fuse box just below battery, What are they for?
Quote:
Originally Posted by jwrezz View Post
Here ya go:
ivrb is offline
Closed Thread
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
