Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Projects - Hobbies and Additional Topics > Projects - Hobbies - DIY > Home Improvement
Notices
Home Improvement Working on a project around the house, condo, or apartment? Questions about a home improvment project? This is the place!
Bathroom remodel..
Reply
Thread Tools
Old 03-12-2007, 11:18 PM   #1
tdavis
Linux Guru
Jack of All Trades
Pinole, CA
tdavis's Avatar
2001 F250/XLT Superduty
Vehicle Specs
(Original Poster)
Bathroom remodel..
So, I've decided to wreck.. er remodel my master bath.
Before I started, the know problems was:
1) Low, non-existant hot water flow.
2) Floor had a slope - almost 4" in 10ft.
3) Poorly installed whirpool tub.
4) Badly installed shower enclosure.
5) Mis-installed vent fan (flapper valve installed upside down.. so it open when not being used, and closed when your turned on the air.. if the tube it was on was actually attached to the fan box.
So, here's some pictures of the starting point. It's hard to see, but the closet door doesn't work, and it's all scratched up - yea, they installed it, THEN did the dry wall work.
__________________
Thomas Davis
Chased vehicle -> Honda VFR800
Tow vehicle -> Ford F250 Superduty
Frankenstein Rock Crawler - > Suzuki Samurai (sold, onto the next project..)
tdavis is offline   Reply With Quote
Old 03-12-2007, 11:24 PM   #2
tdavis
Linux Guru
Jack of All Trades
Pinole, CA
tdavis's Avatar
Vehicle Specs
(Original Poster)
These pictures are how NOT to install a drop in whirlpool tub. Yes, that's correct, I will have to use a jackhammer to break it out. So, that means this tub is probably destroyed.
It also wasn't positioned properly. It should of been centered in the bench, instead of pushed to one side and then back. They do make a tile flange kit for this tub.... BUT, the contractor decided to use grout and fill in.
Yea, the new tub will be moved to the center, and the bench will probably get extended out 6-12". I plan to re-install a whirlpool type tub, with a roman style faucet with a personal hand shower in the deck. Funny, that last sentence means about $1500 in materials..
__________________
Thomas Davis
Old 03-12-2007, 11:25 PM   #3
tdavis
Linux Guru
Jack of All Trades
Pinole, CA
tdavis's Avatar
Vehicle Specs
(Original Poster)
But this is the fun part of removing the tub.
The idiot cemented the drain in, so you can't take it apart - it has to be cut out, then jackhammered.
__________________
Thomas Davis
Old 03-12-2007, 11:29 PM   #4
tdavis
Linux Guru
Jack of All Trades
Pinole, CA
tdavis's Avatar
Vehicle Specs
(Original Poster)
I didn't take any pictures of the show stall - this is where I found the silicon trying to hold the walls on (didn't hold), and the shower base in the air with no support under (so it flexed and quickly cracked into pieces).
The good news - my neighbor does floors for a living, and says the slope can be easily fixed (self-leveling concrete). The water flow problem is a water deposit problem that can be fixed with replacement of the traps/filters/pressure flow valves. I will fix the fan when I replace the box with a better fan setup, and when I put up the new greenboard I will install a vapor barrier.
The tub is complete loss in my book already.
Only thing I'm keeping is the toilet - don't worry, he did screw that one up too, but that is also fixable.
__________________
Thomas Davis
Old 03-12-2007, 11:40 PM   #5
MountaineerGreen
Towing Moderator
North East Arkansas
MountaineerGreen's Avatar
2012 F150 4x4
Vehicle Specs
Ahh... I love builders who do really crappy work that makes no sense! Looks like you've got tons of fun ahead of you. I'm subscribing- will have to remodel a master bath before long with a baby blue tub.
MountaineerGreen is offline   Reply With Quote
Old 03-12-2007, 11:50 PM   #6
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
What brand is the tub? There are a lot of salvageable parts such as the pump motor, air actuated switch, vents/jets, etc. I could be wrong, but I think American Standard has a lifetime warranty on the motor. Check into this. By the way, how long ago did this contractor perform this botched up installation?
BrooklynBay is offline   Reply With Quote
Old 03-12-2007, 11:54 PM   #7
BrooklynBay
Brooklyn, NY
Vehicle Specs
That drain pipe looks like ABS plastic which is cheaper, lighter, and more fragile than PVC. The name of the leveling cement is called thinset. They come as either a premixed formula, or a powder which needs water.
Old 03-12-2007, 11:58 PM   #8
Burns
EF Late Night Crew
Memphis, TN
Burns's Avatar
1991 Explorer/2002 F-250
Vehicle Specs
Quote:
It does...Cheap worker and products im sure...
__________________
Jonathan Burns
Moderator of the Feature Truck Forum
Owner of the "Lime"
Forum Rules and Usage
Burns is offline   Reply With Quote
Old 03-13-2007, 12:04 AM   #9
BrooklynBay
Brooklyn, NY
Vehicle Specs
It looks like the Moen anti scald shower body. Am I correct? It's hard to tell from the picture. I only have part of it at an angle. You need a special tool to remove the cartridge to clean it out. I would recommend using cement board (Wonderboard) around the tub area. There is something new called Backerboard, but I've never used it yet. It is lighter, and flakes apart compared to cracking.
Old 03-13-2007, 12:35 AM   #10
tdavis
Linux Guru
Jack of All Trades
Pinole, CA
tdavis's Avatar
Vehicle Specs
(Original Poster)
The tub is the lowest, cheapest Home Depot/American Standard special - only like $300 from them. No great lost on the tub, it's out of warranty anyway due to the way it was installed, which occurred about 7 years ago anyway.
I'll sell the tub on Craigslist locally. Somebody will scarf it up in no time.
The parts to fix the shower valve - even though the whole valve was sold by Home Depot, you can't get the replacement parts needed to fix it. It's held together by 3 screws for the valve, and another 3 screws for the anti-scald portion. No special tools needed, other than one set of screws is slotted, and the other is a cross head..
Thinset is what you set tiles with; the neighbor who does floors will help me level and fix the floor at his cost for materials, and labor is a favor (he owes me a favor or two....
When I redo the walls, I plan to use cement board on 3/4" plywood for the decking, and cement board on the walls where I tile it up, and green board for the rest.
My neighbor had a shower installed that I want - made out of solid surface, with clear glass door and brushed nickel where ever metal shows.
__________________
Thomas Davis
Old 03-13-2007, 01:01 AM   #11
rizzjc
Scubajoe - Radio Mod
Garner, NC
rizzjc's Avatar
'97 AWD V8 XLT
Vehicle Specs
Hmmm, and interesting post to stumble upon right after returning from my Mom's house where I was turning off the water (valve corroded, had to call the city to turn it off at the street), draining the leaking water heater (water heater located in the ATTIC), and finding the areas where the water got (bathroom wall - conveniently running into the tub), and bedroom, on top of the door. Since it use to be my house, and I knew the pan under the wanter heater is only about an inch tall, I knew I was in trouble when she emailed asking where the water came from that was coming out the pipe at the back of the house.
Long story short, I feel your pain. Bathrooms are fun, and challenging, and make sure nothing leaks when you're done. Looking forward to the progress.
__________________
Joe, N1LVN
'97 XLT AWD V8 STOCK
Amsoil Synthetics throughout. Amsoil Ea air filter. Bilsteins. Scanguage.
Search ExplorerForum
rizzjc is offline   Reply With Quote
Old 03-13-2007, 01:21 AM   #12
tdavis
Linux Guru
Jack of All Trades
Pinole, CA
tdavis's Avatar
Vehicle Specs
(Original Poster)
I just found this. A little costly, but interesting..
__________________
Thomas Davis
Old 03-13-2007, 08:08 AM   #13
rizzjc
Garner, NC
rizzjc's Avatar
'97 AWD V8 XLT
Vehicle Specs
Definitely some new products out there that are easily to deal with, and better than the "old way". Looking forward to seeing the finished product.
__________________
Joe, N1LVN
Old 03-13-2007, 08:19 AM   #14
Turdle
Old and in the way
Humboldt, Kansas
Turdle's Avatar
2000 Mounty
Vehicle Specs
Thinset is indeed used to set tile--it is too thick to use as a leveler--however it can be used to create a slope for drainage-(shower pan)
You need an epoxy type product--like this
http://www.cgmbuildingproducts.com/pd1_f.htm
It will be a free flowing liquid, so be sure to build "dams"
__________________
Jon
2000 Mountaineer
Turdle-gone
Vitamin D Wagon Sold also
Turdle is online now   Reply With Quote
Old 03-14-2007, 12:17 PM   #15
tdavis
Linux Guru
Jack of All Trades
Pinole, CA
tdavis's Avatar
Vehicle Specs
(Original Poster)
I picked up samples of the colors for my shower last night. Dang, close to 20 different colors! This solid surface stuff is impressive, and not too costly - total for the shower (glass, surface, and fixtures will be in the $1700 - $2k range). But that is for something that has no grout lines to clean, no gloss to wear off, and little to no visible caulking. Best part is if you scratch/damage the surface, you can buff out the damage! FYI, the manufacturer's web page is at http://www.swanstone.com
Yes, when it comes to cleaning, I'm a lazy bastard.
I also found a set of patio french doors at the local homedepot that I like - aluminum outside, wood inside, loez glass, again not too $$$ - $800 for the door, plus lock hardware. So that is going to go replace a window in the bedroom wall, giving me access to the backyard. http://www.atriumpatiodoors.com/ is their website.
__________________
Thomas Davis
Old 03-14-2007, 05:48 PM   #16
tdavis
Linux Guru
Jack of All Trades
Pinole, CA
tdavis's Avatar
Vehicle Specs
(Original Poster)
Woo Hoo!
I found the water flow problem, and verified that is NOT a size/routing problem, but a debris problem.
I can fill my tub in about 5minutes, so I'm much happier now!
Next problem, finding the repair parts for the faucets. This has been a royal PITA, nobody around here really carries American Standard repair parts..
This part is full of garbage. I've been flushing the lines today, and did a test fill of the tub, trying to get all this crap out of the lines.
__________________
Thomas Davis
Old 03-14-2007, 06:14 PM   #17
Turdle
Old and in the way
Humboldt, Kansas
Turdle's Avatar
2000 Mounty
Vehicle Specs
http://www.lockesupply.com/Pages/Catalog.html
try these guys
__________________
Jon
2000 Mountaineer
Turdle-gone
Old 03-15-2007, 09:28 PM   #18
BrooklynBay
Brooklyn, NY
Vehicle Specs
This link has a lot of useful information on plumbing: http://www.diydata.com/plumbing/index.php
Old 03-15-2007, 09:42 PM   #19
BrooklynBay
Brooklyn, NY
Vehicle Specs
This link is about bathroom electrical wiring: http://www.diydata.com/electrics/bat..._electrics.php
Old 03-17-2007, 11:03 PM   #20
tdavis
Linux Guru
Jack of All Trades
Pinole, CA
tdavis's Avatar
Vehicle Specs
(Original Poster)
Well, my journey into the madness continues..
No vapor barrier installed, no stapling of the craft paper on the insulation to make one. The fan exhaust was just stuck into the vent, not attached, sealed or anything on it..
And, in the space over the closet, zip, zilch, nada - no insulation. No wonder that area was always so cold.
__________________
Thomas Davis
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
