Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Projects - Hobbies and Additional Topics > Projects - Hobbies - DIY > Home Improvement
Notices
Home Improvement Working on a project around the house, condo, or apartment? Questions about a home improvment project? This is the place!
Bathroom remodel..
Reply
Thread Tools
Old 03-21-2008, 08:13 PM   #141
Turdle
Old and in the way
Humboldt, Kansas
Turdle's Avatar
2000 Mounty
Vehicle Specs
You are really humping along-
What will you do with yourself when it's finished?
__________________
Jon
2000 Mountaineer
Turdle-gone
Vitamin D Wagon Sold also
Turdle is offline   Reply With Quote
Old 03-21-2008, 08:19 PM   #142
tdavis
Linux Guru
Jack of All Trades
Pinole, CA
tdavis's Avatar
2001 F250/XLT Superduty
Vehicle Specs
(Original Poster)
Quote:
Originally Posted by rizzjc View Post
Really, heat? That's what I'm looking for. We have a garden tub that's too small, and a shower that's too small. I want to remove both and put in a larger, jacuzzi, tub, and if it had heat, that would be a double bonus! Sounds like this thing is just the ticket! Who makes it?
It's made by Jacuzzi, and it's from Lowes.
I cheated, and got one of the 10% off moving coupons, and went in ordered/picked it up. I also picked up the shower walls and base, plus the fixtures for the tub all at the same time.
Do note - it will not warm the water up, it will simply maintain temperature.
Also, you need two dedicated GFCI 15amp circuits - one for the pump, one for the the heater.
As for what I'm going to do - plenty of yard work to do still..
__________________
Thomas Davis
Chased vehicle -> Honda VFR800
Tow vehicle -> Ford F250 Superduty
Frankenstein Rock Crawler - > Suzuki Samurai (sold, onto the next project..)
tdavis is offline   Reply With Quote
Old 03-21-2008, 08:30 PM   #143
tdavis
Linux Guru
Jack of All Trades
Pinole, CA
tdavis's Avatar
Vehicle Specs
(Original Poster)
So, this is an example of the wiring and boxes I pulled from the house.
The wire is known as 50c clothe jacketed - at 50degrees Celsius it starts to burn! It also had no ground wire. Also found a MBWC - multiple Branched wired circuit. That's when you share a neutral between circuits. I removed that sucker also! No shared neutrals in this house!
The new wire is 90c jacketed - so it's much, much higher temperature rating.
The boxes is also small - barely big enough for 2 wires, plus a fixture.
__________________
Thomas Davis
Old 03-21-2008, 09:08 PM   #144
rizzjc
Scubajoe - Radio Mod
Garner, NC
rizzjc's Avatar
'97 AWD V8 XLT
Vehicle Specs
Nice, thanks. I'll have to keep that in mind. Yeah, my wife complains that the water cools off too fast. Insulation sucks and they stuck the tub out in free space with open air under and in 2 sides. This would be nice!
__________________
Joe, N1LVN
'97 XLT AWD V8 STOCK
Amsoil Synthetics throughout. Amsoil Ea air filter. Bilsteins. Scanguage.
Search ExplorerForum
rizzjc is offline   Reply With Quote
Old 03-24-2008, 12:44 PM   #145
tdavis
Linux Guru
Jack of All Trades
Pinole, CA
tdavis's Avatar
Vehicle Specs
(Original Poster)
More signed off!
drywall - DONE.
stucco lathe - DONE.
stucco scratch - DONE.
Now, I need to find a earthquake shutoff valve for the gas line..
there is still:
drywall (nail & screw)
stucco lathe
stucco scratch
stucco brown
stucco final
final
I was signed off on:
rough frame
rough electrical
rough plumbing
rough mechanical
insulation (wall & ceiling)
__________________
Thomas Davis
Old 03-24-2008, 01:07 PM   #146
Tbars4
Offroad Moderator
anaheim hills,california
Tbars4's Avatar
95 ranger 4x4/ 91 X 4x4
Vehicle Specs
...check with your local gas company...they may supply it for you and/or install it for you...they have for me...if not, they can assist in locating it...
__________________
I have Rocks in my head. What's in yours?
'95 ranger xl 4x4 2.3L std cab, 2 sticks Ranger RegistryThe Squirrel
'91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's List
How to: Wheels,Tires, & Lifts...
Buy Explorerforum.com Items here
Tbars4 is offline   Reply With Quote
Old 03-25-2008, 01:54 PM   #147
tdavis
Linux Guru
Jack of All Trades
Pinole, CA
tdavis's Avatar
Vehicle Specs
(Original Poster)
Quote:
PGE will not help.
http://www.pge.com/myhome/edusafety/...ke/gasshutoff/
Quote:
If a customer installs an excess flow gas shutoff valve or earthquake actuated gas shutoff valve, it should be one that is certified by the State of California and it should be installed by a licensed plumbing contractor in accordance to the manufacturers instructions. PG&E does not install or service seismic actuated or excess flow gas shutoff valves, or recommend specific contractors for customer applications.
__________________
Thomas Davis
Old 03-25-2008, 07:06 PM   #148
Tbars4
Offroad Moderator
Tbars4's Avatar
Vehicle Specs
...wow, it doesn't seem like it was that long ago...
http://socalgas.com/safety/valves.shtml
What if I already have a valve installed on The Gas Company's side?
If you have a valve that was installed by The Gas Company or one of its authorized contractors on or before the February 10, 2002 cutoff date, with proper documentation your installation may be allowed to remain in place
__________________
Old 04-03-2008, 07:28 PM   #149
tdavis
Linux Guru
Jack of All Trades
Pinole, CA
tdavis's Avatar
Vehicle Specs
(Original Poster)
So, I continue the saga of pulling down drywall, so I can insulate, seal, and do earthquake safety repairs..
The fireplace mantel is brick, and it's all loose.. so it's coming off to be re-built - I'm leaning towards travatine, I think the color would be a good match. I also want to put a wood burning insert in the fireplace, and they usually are all black.
__________________
Thomas Davis
Old 04-03-2008, 07:29 PM   #150
tdavis
Linux Guru
Jack of All Trades
Pinole, CA
tdavis's Avatar
Vehicle Specs
(Original Poster)
This shows where I need to do the earthquake repair - the beam isn't really held in place, and can slide/move around.
__________________
Thomas Davis
Old 04-03-2008, 07:35 PM   #151
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
'93 XL
Vehicle Specs
Tom, you certainly don't go half assed on anything Looks like you are continuing to do a great job of restoring your place
__________________
Rick Horwitz, AB7FH "Serious Exploration's" Admin
Rick's '93/'98 Explorer "The Great Pumpkin"
Dodge Dart 512 Resto/Race 10.29 @ 129
2004 Mustang Mach 1
2003 Dodge Ram/Cummins Dually
Rick is offline   Reply With Quote
Old 04-03-2008, 08:07 PM   #152
tdavis
Linux Guru
Jack of All Trades
Pinole, CA
tdavis's Avatar
Vehicle Specs
(Original Poster)
Yea, I remember the line from This Old House - "once you open the walls, your in for a world of trouble."
And that is the TRUTH!
I'll have one the safest homes on the block, and it will be energy efficient too!
__________________
Thomas Davis
Old 04-03-2008, 10:49 PM   #153
TheJackal
Mandeville, LA
1999 Explorer XL 2WD
Vehicle Specs
Cool choice on the IKEA cabinets. I've been looking through the IKEA online catalog a bit and know when I move I'm going to order furniture from there.
How old was this house that it only had 2-conductor electric wire in it? Even my grandparent's house built in the late 1950s has a hot, neutral, and ground. The ground was connected to the metal electric boxes themselves, this was before the plastic ones. The outlets themselves were 2-prong.
TheJackal is offline   Reply With Quote
Old 05-02-2008, 01:58 PM   #154
tdavis
Linux Guru
Jack of All Trades
Pinole, CA
tdavis's Avatar
Vehicle Specs
(Original Poster)
The house was built around the fall of 1959. I know the exact age, because I found the original building permits!
Matt (Rockranger) and his wife Tracy stopped by, and gave me a helping hand last Sunday - Hanging corner bead is no fun by yourself!
Thanks Matt & Tracy!
I have since proceeded to sand the tip off of one of my fingers, and boy does it hurts..
Some pics, and the fireplace disaster..
Now, the hard part - choosing colors to paint with. The ceiling in here DOMINATES the colors, and I am NOT painting it - so it really does limit what colors I can choose.
__________________
Thomas Davis
Old 05-02-2008, 10:32 PM   #155
RockRanger
Elite Ranger
Fresno CA
RockRanger's Avatar
86 ranger no more
Vehicle Specs
Tracy and I were glad we were able to help you out. You are doing a great job and we can't wait to see the finished project.
RockRanger is offline   Reply With Quote
Old 05-03-2008, 09:48 AM   #156
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
'93 XL
Vehicle Specs
That's really coming along! Looks great
__________________
2004 Mustang Mach 1
Old 05-03-2008, 09:51 AM   #157
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
'93 XL
Vehicle Specs
That stuff was scary when it was brand new
__________________
2004 Mustang Mach 1
Old 05-03-2008, 10:06 AM   #158
Turdle
Old and in the way
Humboldt, Kansas
Turdle's Avatar
2000 Mounty
Vehicle Specs
I think any color would look good with a natural shade of wood-as long as it is a lighter shade.You could use the window trim to match the ceiling.
Looking good Tom.
__________________
Jon
2000 Mountaineer
Turdle-gone
Old 05-08-2008, 10:41 PM   #159
DB_1
Elite Ranger
La Quinta, Ca.
DB_1's Avatar
97 SC Ranger xlt
Vehicle Specs
Tom, I really wish I could've helped while I was up there but I had other crap to deal with back home
I'll be back up there around the 19th of this month to help out Matt again so hopefully I can find time to help you out as well if you can wait
I'll keep in touch
__________________
97 Ranger...what's left of it
DB_1 is offline   Reply With Quote
Old 05-09-2008, 12:52 AM   #160
tdavis
Linux Guru
Jack of All Trades
Pinole, CA
tdavis's Avatar
Vehicle Specs
(Original Poster)
I have the contractor back doing more drywall, and we will be ready to paint starting after next week...
I had them start to sand the old walls with the painted on texture, and that stuff is HARD. 36 grit sand paper with a palm sander, and it barely dents it. Then it gets skim coated, and the whole place is back to smooth wall.
__________________
Thomas Davis
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
