Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Performance Lighting
Notices
Performance Lighting Aftermarket lighting. Driving lights, fog lights, rock lights, HID, halogen. Make your Ford Explorer light up the night!!
Closed Thread
Thread Tools
Old 03-16-2007, 08:33 PM   #1
celly
psycho by choice
calgary
celly's Avatar
99 eb 5.0
Vehicle Specs
OEM fog light/fog lamp removal 1999
I scored some new OEM fog lights today for my '99 (i.e. the round ones). Mine were looking a bit worn. I really only wanted to replace the electrical connectors and bulb sockets but Ford doesn't sell them separaretely and no bone yards in town had any either.
There are three main bolts holding the unit in place (from the top). Two are very accessible via the wheel well. The third one isn't so accessible. What do I need to do to get at the third bolt? It's reachable by hand at a very awkward angle. I can get a socket on it, but just can't get the leverage to loosen it. I'm thinking the grille shell or maybe the bumper need to come out? I'm trying to avoid having to rip the whole front end fascia apart to get at it.
Any assistance from those that have done this before would be greatly appreciated.
__________________
5.0 V8, TMH, 1" Trick Flow UI spacer, Custom Volant based air intake (incl C&L MAF body), XC2 w/Henson tunes, Flo Pro catback, Iraggi 260 amp HO alt, EE swaybar and airdam, projector HIDs, Powdercoating by Turdle, other stuff.
Quote:
I know searching doesn't do anything for your post count....
celly is offline
Sponsored Links (Less Ads)
Old 03-17-2007, 04:41 PM   #2
celly
psycho by choice
calgary
celly's Avatar
99 eb 5.0
Vehicle Specs
ttt
__________________
celly is offline
Old 03-17-2007, 05:00 PM   #3
IAmTodd
IAmTodd's Avatar
2006 Saab 9-3 Aero
Vehicle Specs
Mine came out easily when I had the bumper off. Its only 4 bolts(21mm I think) and it comes right off. Its mainly plastic/fiberglass so its not to bad of a job.
IAmTodd is offline
Old 03-17-2007, 08:09 PM   #4
celly
psycho by choice
calgary
celly's Avatar
99 eb 5.0
Vehicle Specs
Thanks for the tip, Todd. I was hoping to avoid the bumper work and I did. I climbed underneath this afternoon and looked around. I had a hunch that if I removed the corner lights, I may be able to gain some sort of access to the bolt. My hunch was right. There are two holes right below the corners. One is almost perfectly lined up with the bolt. I used a long socket, two extensions and a swivel. I couldn't even get it with a ratchet. Had to use a straight screwdriverish handle (whatever you call it) and voila,it loosened. First one was a piece of cake. 2nd one took some effort but it came out. I quickly swapped out fogs and did NOT reinstall the troublesome bolt. The fogs are in there quite securely with just the 2.
While I was out there, I removed my Xenon Depot HID kit. I'm getting a setup installed by this local guy in Calgary. I think I mentioned it on the other site. He's putting in a 4300K hi/lo setup that he has had very good luck with. He's going to install the setup for me next week and is going to take a look at the fogs too. Now that I have a 2nd set of fogs, I can trash a set of plugs to mod the H1 bulb into it somehow. This guy is very accomoplished and it should be a piece of cake for him. He doesn't have any yellows in stock. I might try both a set of yellow and 4300K with the 4300K going in first. He has good prices on bulbs as it is ($150 CAD for a pair which works out to around $130 US, not bad for a brand name). I've asked him to knock some off the yellows which should be here in a few weeks.
I'm letting him do the install for a few reasons. He's pretty much throwing in a free install because I want to buy two sets. He's one of the best in town and will guarantee it will work. Also, he only warranties the bulbs if he installs them. Too many issues with people returning them because they don't know what they're doing. He's going to do it on my schedule and comes to me to do it. I know it will be done right and I'll pretty much have him to deal with any issues with it down the road. It's more expensive that doing it myself obviously, but I can live with that. I do OK work with electrical stuff, but I don't always route my wires in the most sighly fashion. I also want him to do it right, mount the ballasts etc.
I'm pretty stoked. I know how great HIDS are having used the XD kits for a year. I plan to sell that kit soon. I rarely use high beams anyhow, so even if this setup isn't perfect, I'm sure it will be fine. He also has a "flash to pass" setup only whereby the HID bulb is wired parallel to a narrow halogen tube. You don't get high beams but you still can flash someone who's doddling in front of you and it won't kill the HIDS when you do it. I opted for the full hi/lo option and I think it does flash to pass too. He told me he's sold many of these bulbs in the 6 months he's carried them and only one was returned. This was some oil guy in the Northwest Territories. The cold weather snapped part of the mechanism. but it was bitterly cold for a week when it happened. The good thing is, if there is a problem, he's right here in town to take care of it. His prices are veryfair, he has excellent expertise and he knows his stuff. His low beam kits use GE capsules and although the ballast manufacturer isn't as well known as Philips, they look to be great ballasts he uses. They actually provide for a cleaner install because of the way things plug into it.
gthid.ca if anyone's interested. I'm not sure if he does mailorder. Probably does. He seems to have his sh*t together.
__________________
celly is offline
Old 03-17-2007, 08:19 PM   #5
IAmTodd
IAmTodd's Avatar
2006 Saab 9-3 Aero
Vehicle Specs
Still sounds like you went through a lot of work to get them out. :P
Thats great that you found a quality place for HIDs. I really want to upgrade to a dual beam setup and get rid of my silly lights on the front bumper. Living in the country I find it necessary for high beams, especially in hunting season.
There was a set going around on the other site that were dual beam at an excellent price. However I heard an Audi owner was having ignition trouble when it was hot out. I don't want to mess around with the reliability of headlights. Mine work perfect and if I have to find a more low profile driving light I will.
Good luck and keep us updated.
IAmTodd is offline
Old 03-18-2007, 03:05 AM   #6
celly
psycho by choice
calgary
celly's Avatar
99 eb 5.0
Vehicle Specs
Quote:
At the end of the day, it wasn't too bad. I found a thread from '03 whereby the guy had the same problem and just gave up. I didn't want to do the bumper thing so at least I found a workable alternative.
I think your setup is great. I considered trying the same but realized I'd screw it up. The way I see it, this guy I'm dealing with has a great reputation. I also don't use high beams that often so wear and tear will be minimum. I'll be sure to let you know how the install goes.
__________________
celly is offline
Old 03-18-2007, 03:07 AM   #7
celly
psycho by choice
calgary
celly's Avatar
99 eb 5.0
Vehicle Specs
__________________
celly is offline
Old 03-31-2007, 09:54 PM   #8
KLW
Peabody, Kansas
2000 AWD 5.0
Vehicle Specs
I just replaced my fogs on a 2000 Explorer. Yes, the 3rd bolt was hard to get at but with a 1/4inch ratchet and deepwell 8mm socket they came out just fine. I wish someone offered just the glass lens for the lamps instead of having to buy the whole thing. I ended up getting some off of ebay for a total of around $72 and they looked like the original ones.
KLW is offline
Closed Thread
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
Copyright 2010 - 1996 Rick Horwitz Photography
